BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY: Illuminated LCI AC/radio trim retrofit
      12-15-2015, 12:29 AM   #265
Dante
Enthusiast
Dante's Avatar
Drives: F87 M2 / F31 330d
Originally Posted by pentagon
Hi guys,
Does anyone know if the y adaptor will work with only 2 sets of wires (ground and orange led pin)? Since my car does not have the white led function, can I just skip the cable Altogether? Thanks
Hi,
Even if your car doesn't have the white ambient light, your car still has all 3 wires. But I think it will work without the wire for the white LED.
My guess is that all F30 have the same hardware and the white light option is just coding.
      12-15-2015, 05:16 AM   #266
shadowyman
shadowyman's Avatar
202
Drives: AY F82 MPE
What's the case with 2016 4 series?
      12-15-2015, 05:27 AM   #267
Dante
Enthusiast
Dante's Avatar
2016 4 series (F32/F33/F36) don't have the cupholder LED anymore.
Or more specific, all F3x cars built after 07/2015 are missing the cupholder LED, even with option Light Package.
      12-16-2015, 10:33 AM   #268
Mexbjk
Drives: F30 3.16i Sportline
Thanks for the these wonderful informations
I ordered led trim and y cable parts too..
I have a question, someone asked it but I want to know is there any detail picture or video for remove the radio and climate control parts from the trim ?
I dont start the installation yet but everyone talk about this is very hard to it
Thank you
      12-16-2015, 11:03 AM   #269
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
Thank you
Please refer to my post here on how to remove the radio and climate control parts:
http://f30.bimmerpost.com/forums/sho...&postcount=244
My build thread
2015 428i GC - Alpine White - Coral Red - M Sport
      12-16-2015, 11:07 AM   #270
Dante
Enthusiast
Dante's Avatar
Also check your new trim when you have it, there you see exactly where all clips are located. Makes it easier to remove the controls from the old trim.
      12-17-2015, 09:34 AM   #271
Mexbjk
Here it's..
thank you for everybody
For Y Cable Parts;
Y Cable;
Y Cable and Led Frame;
Installation Y Cable for Cup Holder Led and Led frame;
Ambience Classic;
Ambience Sport;
Day Time;
      12-18-2015, 10:40 PM   #272
pentagon
pentagon's Avatar
23
Drives: 2015 F30 328xi
Finally fitted the trim today, can confirm that it will work with only 2 cables (orange LED). However, i made the mistake of not shortening the wires enough on the Y adapter, so cramming everything under the cover was a pain in the ass.
      12-19-2015, 05:09 PM   #273
a803sgo
Drives: BMW 320D M-SPORT (F30)
Fitted mine today to a pre-LCI with the matt black dash so I Plastidipped the trim and moved the controls over.
This was easy using old bank cards all along the edge to unclip the controls, took minutes working alone.
Couldn't be bothered making up a cable so used some electrical connectors I had in the garage...
I've only got Business Nav so there's loads of space for all this in the cavity.
Works and looks great...
      12-21-2015, 09:07 PM   #274
Chew
Drives: 2016 F36
FYI, for those of us who do not have the cupholder LED, and thus can't perform this mod, I've figured out where to get a signaled power source (Orange and White) for the cupholder LED as well as the LCI LED radio cover.
I'm waiting on some parts to arrive before I can validate which wires are needed, but I'll create a DIY once it's done to show you guys.
Anyone have a good source in the USA for the materials of the original MOD? I'm going to need that as well as some additional items for this to work. (and it may not end up being exactly plug and play like the original one, a tapped line or two may be required)
I'll let you know when I have more info.
Chew
      12-21-2015, 11:21 PM   #275
cryptocar
cryptocar's Avatar
Drives: 13' F30 385xi VNV Speed Custom
Chew
I get all my OEM parts from getbmwparts. And have picked up dozens of sockets pins wires and connectors from them.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
      12-22-2015, 09:57 AM   #276
tboooe
tboooe's Avatar
925
Another option is ECS Tuning which is where I got my parts from. Their prices are usually better than any BMW dealer.
My build thread
      12-22-2015, 12:01 PM   #277
cryptocar
cryptocar's Avatar
ECS is good too I have picked up some things from them but in my experienced they are a bit more expensive than other options out there and don't carry the best aftermarket stuff. Their ZiZi LEDs for example were like double or triple the cost of the eBay CREEs I picked up and only about 1/3 or less of the output.
      12-22-2015, 01:22 PM   #278
Chew
Drives: 2016 F36
I've got all of the parts I think I'll need ready to order from ECS, however they're showing the Trim as backordered. Anyone know of a place that ships to the US at a reasonable cost so I can get playing making cables and my DIY for those of us who don't have the cupholder LED?
      12-29-2015, 06:57 AM   #279
BTT 335i
BTT 335i's Avatar
Drives: X5 F15 M Sport- F30 M Sport
Hello guys , somebody have one Y cable available for sell?
      12-29-2015, 09:28 AM   #280
tboooe
tboooe's Avatar
925
The cable really is very simple to make. You dont even need any special tools aside from a wire stripper. Let me know if you need any help.
My build thread
      12-31-2015, 12:14 PM   #281
Chew
Drives: 2016 F36
I've got all of the parts on order to retrofit the trim as well as cupholder LED for those who are missing it. I've hooked up with marcin23654 in order to source the Trim piece as it's nearly impossible to find in the states.
I'll keep you all updated once everything comes in and will make a detailed post with instructions. Dante do you want me to make a separate post for those who don't have the ability to follow your DIY? or would you rather consolidate under a single thread?
      12-31-2015, 12:31 PM   #282
Dante
Enthusiast
Dante's Avatar
Hi Chew,
I would appreciate if you'd post it here.
That would make it easier for others to find the information.
I'll gladly add your findings to page 1 of this thread.
      12-31-2015, 12:32 PM   #283
david51
david51's Avatar
France
538
Drives: bmw M3 F80
modification kit in blue lighting
      12-31-2015, 12:37 PM   #284
marcin23654
Drives: 2012 F30 320d N47D20C
Please tell us how to do that. I absolutely love it
      12-31-2015, 12:38 PM   #285
cryptocar
cryptocar's Avatar
Would look amazing with my promina blue LED dome and map lights. Please do tell this is done!
      12-31-2015, 01:11 PM   #286
Dante
Enthusiast
Dante's Avatar
Great Job, David!
He must have exchanged every amber (or white) LED for a blue one. Apart from the footwell, apparently.
