06-08-2019, 07:46 PM | #23 |
BMW CCA Member
488
Rep 808
06-08-2019, 09:08 PM | #24 |
BMW CCA Member
488
Rep 808
Front end is 5-1/8 inches off the ground (front fender well lowest level)
Read end is 6-5/8 inches off the ground (rear fender well lowest level) Front finger is 5/8 inches Rear 2 fingers is 1-1/2 inches Last edited by exE36M3; 06-08-2019 at 09:28 PM.. |
06-08-2019, 10:56 PM | #26 |
Rep 3,535
What are the hub to fender measurements? That's one of the most consistent measurements to use when comparing ride heights.
06-09-2019, 11:43 AM | #27 | |
BMW CCA Member
488
Rep 808
Event stock the 435i sits a little higher in back... odd or engineering or both. |
06-09-2019, 11:44 AM | #28 |
BMW CCA Member
488
Rep 808
06-10-2019, 09:41 PM | #30 |
BMW CCA Member
488
Rep 808
Yes. I am running Amazon "Eurotech Werkshop" spacers ($86 for a set of 4, and came with extended bolts.). 12mm front and 15mm rear.
And the hub (middle of BMW logo cross-hairs) to fender distance... FRONT: 13-1/8" REAR: 14" |
FaRKle!4006.50 |
06-10-2019, 10:31 PM | #31 |
Rep 379
thanks, are the wheels flush with the fenders with those spacer specs?
06-11-2019, 09:12 AM | #33 |
Rep 379
10-13-2019, 12:35 AM | #35 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
My 435i xDrive with the Eibach pro-kit, 15mm spacers in the front and 20mm in the back. Stock 18" 441M wheels which I believe are ET34.
thatBimmerBloke872.50 |
02-12-2020, 09:35 AM | #37 |
Rep 1,079
That looks really good, is it the pro kit with B8 shocks and Eibach springs, part number E10-20-031-18-22? Definitely looks lower than the claimed 20mm/10mm front/rear lowering.
02-12-2020, 11:15 AM | #38 | |
E36fiend
285
Rep 637
02-12-2020, 11:21 AM | #39 |
Rep 1,079
Thanks, my bad. I'm curious how the springs pair with B8 shocks/struts. Apparently the drop is lesser. Can't find anyone who has the complete kit (B8 shocks + Eibach springs) installed on F32.
