10-24-2018, 09:50 AM | #1 |
Rep 15
BMW Rolls Royce chime issue.
Just started coding for the first time a few days ago. Everything has gone great and worked except when I tried to code in the Rolls Royce warning sound it doesn't work it just seems to disable the gong. I tried the BMWi chime and that worked but I was wondering if anyone has had the same issue with the Rolls Royce one. I'm using BimmerCode by the way and also I know it's not really necessary just curious. Thanks!
10-24-2018, 10:00 AM | #3 |
Rep 15
10-24-2018, 02:47 PM | #4 |
No 55mph
1621
Rep 8,476
Have it coded in my 2015 - works fine
10-25-2018, 04:13 PM | #5 |
New BMW owner
139
Rep 621
You need a professional unit for RR chime. Business Navigation won't be able to give the chime.
03-07-2020, 09:14 AM | #6 |
Rep 134
03-07-2020, 11:12 AM | #7 |
New BMW owner
139
Rep 621
Big screen navi
ROUTE navigation is not supported. You can use Bmw I or Mini sounds, Rolls Royce won’t work on your system if you have business. |
03-07-2020, 01:45 PM | #8 | |
Rep 134
But within bimmercode the rolls royce warning chime is not avail. The rolls royce startup animation is avail just not the sounds. I know this is trivial I am just trying to figure out what im working with. |
03-07-2020, 03:50 PM | #9 |
New BMW owner
139
Rep 621
Try on expert mode.
Sound_signal_set |
