07-01-2017, 09:39 AM | #155 |
Rep 233
07-02-2017, 12:39 AM | #156 |
Eric_Y
103
Rep 456
Drives: 2016 340i, 2010 E92 M3
07-02-2017, 12:44 AM | #157 | |
Rep 1,076
You are just getting the original speed that is in the map before the road work speed limit is posted. |
07-02-2017, 12:49 AM | #158 | ||
Eric_Y
103
Rep 456
07-02-2017, 12:51 AM | #159 |
Eric_Y
103
Rep 456
I just drove a 440i today, built in 08 2016. This car has SLI displaying on dash and hud. I was told by the sales that new model now has the front camera scanning road speed sign now.
07-02-2017, 09:05 AM | #160 | |
Schmollbraten
12512
Rep 1,985
So what? Thats the purpose of the SA reading all kind of traffic signs with the kamera. Thats not a sensation but a very useful add on to the car.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
07-05-2017, 01:09 PM | #161 |
Rep 2,180
My brother installed this PnP SLI (Chinaclone) in his 2017 F80 M3 and it just do not work. VO coded 8TH into KOMBI and HU_NBT2 to no avail -no dim circle at HUD, nothing at KOMBI is showing. Both displays were selected in the iDrive display, so coding was taken by the HU_NBT2, not sure of the KOMBI.
Is the circle supposed to show immediately (at HUD or intrument panel) after coding or the car must go to sleep first? |
07-05-2017, 01:33 PM | #162 | |
Rep 1,076
Also you need to enable it in the center console screen under what should be displayed when in the HUD menu. It should be a check box. Then when the sli unit is plugged in the red circle shows up. With the speed limit if you are on a road that has a speed limit and is on the map as a road that has traffic map on it. |
07-05-2017, 02:13 PM | #163 | |
Rep 2,180
Thanks... we figured it out: PSdZData was old. Updated it and then KOMBI got the coding. Strange as HU_NBT2 got the coding the first time.
Quite simple install after the snafu... thanks to all contributions in this thread. Quote:
07-05-2017, 07:24 PM | #165 |
Rep 1,076
07-06-2017, 06:18 AM | #166 |
Rep 16
Drives: '16 F30/328d M Sport
I got mine working successfully. As others have noted, the speed limit information displayed on KOMBI is the ECE white/red circle with kilometers per hour but correctly matches my local miles per hour.
For those of us in the U.S., if we could only figure out a way to display it in MPH...? |
07-06-2017, 07:19 AM | #167 | |
Rep 2,125
07-06-2017, 09:32 AM | #168 |
Rep 89
07-06-2017, 01:38 PM | #169 |
Rep 327
Interested as well. Will this work with US vehicles?
Edit: Did not read the post above me before I posted LOL
Mods: MHD Stage 2+ FlexFuel, xHP Stage 3, VRSF 5" HD Intercooler, VRSF Charge Pipe, CircuitWerks Catless DP, AFE Pro Dry S Intake filter, Eldor coils, NGK 97506 @ .026, Bilstein B14 coils.
07-06-2017, 01:48 PM | #170 |
Rep 1,076
07-06-2017, 04:50 PM | #171 |
Rep 524
The seller on eBay responded that he couldn't get it to work on a CIC. Any reason why that would be the case? Has anyone with a CIC and the extended cluster get this to work on their vehicle?
07-07-2017, 02:04 AM | #172 |
Schmollbraten
12512
Rep 1,985
You have to order this item into the correct setting for your country.
If you're not buying the part which is discussed at the beginning of this thread, I have no clue if there are jumpers to change the settings or not. I had NBT and extended cluster, was no problem. CIC I got no idea, sorry.
07-07-2017, 04:13 AM | #173 |
Rep 40
Great thread - I’ve just ordered the emulator linked on the top of page 6.
Has anyone managed to figure out how to get the signage display in the cluster to show as MPH instead of KPH? Andy |
07-07-2017, 05:28 AM | #174 | |
Rep 1,076
07-07-2017, 05:33 AM | #175 | |
Schmollbraten
12512
Rep 1,985
Second: If you consider to install a SLI-emulator you'll have to mention your desired country before ordering, that the jumpers are correct set. Hence the SLI-emulator holds no translator or other kind of transducer, a conversion of the units are impossible. As far as I know the Chinese clone are not be able to differ between metric and non-metric values. So maybe a few bucks more to spend for a proper emulator would be desireable? Thats one of the "features" if you're gonna buy an item maybe at first look more cheaper than the rest. I have no further words, man
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox Last edited by Dang3r; 07-07-2017 at 05:40 AM.. |
07-07-2017, 06:49 AM | #176 | ||
Rep 1,076
