12-31-2019, 03:29 AM | #2905 | |
Rep 190
Can you please post a photo from your info screen ? I installed it too but it seems that it is an older firmware. |
12-31-2019, 07:54 AM | #2906 | |
Rep 220
Drives: MINI Cooper, 2020 X1
docalex139.00 |
01-09-2020, 08:50 PM | #2908 |
Rep 18
Hi,
I download and unzip the file and try to install the update and when it reboot this screen show up can someone pls help |
01-10-2020, 05:51 AM | #2909 |
Rep 32
format your usb drive, copy the zip again and safely extract the usb
01-10-2020, 05:54 AM | #2910 |
Rep 32
This is my version of mcu, I think it is newer than the last version released. Do you know if there is a way to extract it to share with you ? I have a 1920x720 screen with snapdragon
01-10-2020, 06:52 AM | #2911 | ||
Rep 220
https://mega.nz/#!ccNjFSJT!xxvAk4cSY...SPOqnXP-38zRqE Quote:
2. Rockchip is not Snapdragon. 3. yours version of Android is 9, jc2000 s version of Android is 8 4. last version of yours Android 9 is 3.8.0 |
01-10-2020, 06:57 AM | #2912 | |
Rep 1,048
there is no possibility do "download" the update from the HU again, you would need to ask your seller for the file. As you have an Android 9 unit its probably better when you continue at the Android 9.0 Thread. this Thread is more dedicated to Android 7/8 , PX3/6 units. Kri |
01-10-2020, 07:31 AM | #2913 |
Rep 220
01-10-2020, 12:19 PM | #2914 |
Rep 190
Is that even possible?
01-11-2020, 02:29 AM | #2915 |
Rep 190
You said that in ID7 menu iDrive knob works as it should ?
When you are in main menu music tile highlighted when you move the knob left it goes to the vertical selection tiles? I can not do that. Knob rotates fine but it does not go further left to select the vertical tiles |
01-11-2020, 05:53 AM | #2916 | |
Rep 220
Switching between the tiles by rotation of the knob and switching between the tiles and the vertical column on the left by moving the knob to the left and right |
01-11-2020, 01:16 PM | #2920 |
Rep 1,048
01-11-2020, 02:03 PM | #2921 |
Rep 17
Nice working but there is a small problem in the factory xml in Turkish language option is not available in the android system because the Turkish language is turned off when I turn on German again
Last edited by hextek; 01-11-2020 at 02:15 PM.. Reason: solved add line to turkish language |
01-11-2020, 02:32 PM | #2922 | |
Rep 1,048
Kri |
01-11-2020, 05:04 PM | #2924 | |
Rep 190
But that's not a deal breaker for us ! I am trying to figure out what is the problem with CCC unit and idrive B. Because yours is CIC if i remember correctly. Any clues about that? |
01-12-2020, 01:51 AM | #2925 |
Rep 17
