03-02-2020, 11:18 PM | #2971 |
Rep 20
to sum up the situation
When i’m try to switch to bmw system, i have « no signal » but i have the sound and idrive works, steering wheel too. When i’m on the android system, i have no sound, the idrive and steering wheel works. i don’t have the same mainharness, i don’t have the CAN wire connection.like your photos … maybe the problem is here ? oh and avin say on the last mail : our engineers confirmed that your system is NBT system. |
03-03-2020, 05:44 AM | #2972 |
Rep 51
03-07-2020, 01:38 AM | #2973 | |
Rep 550
03-19-2020, 08:52 AM | #2974 |
Astronaut
514
Rep 732
Hey guys,
I've been trying to work with Avin about updating my 9.0 unit but I've been running into issues. Every time I run the update, I only get 3 UI (NBT, EVO, and something else I can't remember) Do we HAVE to upload the OEM file after installing a software update? When I upload the OEM file, the only UI I have is ID6. According to their pictures, I'm doing the update correctly. I don't have issues with the unit accepting my USB drive. I keep getting the same copy and paste from AVIN which is starting to get irritating at this point. They said if the update was done successfully, I should have AV8 UI. Can someone post a picture of what this interface looks like? |
03-21-2020, 09:58 AM | #2975 |
Rep 33
Hello all and nice to meet you.
Recently i bought an F30 and it has allready installed an android 10.25 inch display but with old version android 4.4.4 I saw that it doesnt have IDX (ID5/ID6/ID7) Inteface. as i search i think it is this or something like this : https://www.aliexpress.com/item/32812870863.html but on the menu it doesnt have the option for ID6 interface. So the question is can i upgrade the firmware? |
04-03-2020, 04:11 AM | #2976 |
Rep 40
thanks to Kri all the IDs were available at my unit after changing the factory_config.xml. But it was on a snapdragon unit with Android 9. Don´t know if these are also available for your unit.
04-12-2020, 09:41 PM | #2978 |
Rep 3
Hi everyone.
I just installed a new Avin 10.25 screen in my 2016 X1. The installation was a real pia. The factory HU barely pulls out enough to change the harness. It took me all day to figure out a way to pull it out enough and then I had to ask my wife to plug the new harness in since she has tiny hands. Anyways, it works now, but imo the trouble to install this thing is way underestimated for a 2016 X1. The original HU does not come out like in any of the install videos I watched. It actually does not come out at all! FYI So I bought: (North America) | Android 10 With 4GB RAM | 4G SIM Card Support | Qualcomm Snapdragon | Black Trim Bezel Also got the GPS splitter and the newest little black box for wireless carplay/android auto as I was potentially planing to use AA with it. My 2016 X1 is fully loaded. So I am coming from an 8.8 screen with NAV. I really just wanted Waze and Tidal and the ability to use my Plex server on my long trips back to my hometown. So I figured when I'm not going on long trips, I would use AA. I tested Plex and it does work on the Android side. Haven't done any type of long term testing. Really just got it up and running, installed AA and Waze and Plex on the Android side. I was however, quite disappointed with the resolution of AA. Is there a way to not have it stretched out for the whole 10.25''? Can I split screen it some how? Or change the resolution in a way. Maybe make the icons smaller? Adding more rows or something? What do you guys use the most? AA or simply stay on the Androiud side for Waze and Spotify? If you do stay on the Android side, am I correct to assume that I always have to hotspot from my phone? Don't want to get another sim card for my car. Unless that is the way to go? Also, is there a way to keep spotify or tidal going when I switch to the OEM side? Which Bluetooth settings do you guys have running? On OEM side VS Android. Alot to configure it seems. I also don't have the autoplay working right. I have to go in the apps section, select autoplay, then plug my phone in. I think I read somewhere that this can be changed though. |
04-27-2020, 04:13 PM | #2980 |
Rep 9
Drives: '13 328i
I just installed the 10.25 with Android 10 on it in my 328i non nav. I get audio out on the stock side of the system but when I switch over to the android side there is no audio out at all. Is there something I am missing?
05-13-2020, 09:52 AM | #2981 |
Rep 20
hi,
My problem is solve ... the unit wasn"t for my car, i sent it back for change. And now it works well ... but just one problem very annoing ... When i call people with carplay, they say the sound is very very bad Someone have the same problem ? Thank's a lot |
05-13-2020, 05:34 PM | #2982 | |
Rep 66
I fixed it using the normal BT of the car only for calls |
05-13-2020, 06:26 PM | #2983 |
Rep 20
Sorry foo2002
And a big thank's for your answer, my english is not good and i misunderstand what you say i tried it today and works very well !! later i tried to receive a call to see if carplay take it too Last edited by TiToyz; 05-15-2020 at 03:17 AM.. |
05-15-2020, 04:32 AM | #2984 | |
Rep 2
05-15-2020, 11:20 AM | #2985 |
Rep 2,989
Drives: 2019 M2 Competition
Hey yall.. if you have the snapdragon version of the display from Avin, you can now image update to android10! This is a big deal as really the first time you can change full OS versions without changing hardware.
If you have the Avin display, reach out to them directly and they will provide the download links. Here is my walkthrough of the update.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
LittleSamurai4.50 |
05-16-2020, 01:09 PM | #2986 | |
Rep 66
In the phone choose this old BT connection for calls |
05-20-2020, 06:50 AM | #2987 | |
Rep 1
I have tried these other settings and mine seems to still be wrong. I have tried to look everywhere for the cartype.xml file with the updated idrive display settings but cannot find it anywhere. Can anyone point me in the right direction or send me the correct file I need? Thanks in advance |
06-04-2020, 04:52 PM | #2988 |
Rep 1
Hazy screen?
Hey all - I've had my AVIN 7.1 system for about a year and a half now. Pretty much only use it for the backup camera capability, and otherwise use the BMW side for the most part. That said, my screen is super hazy and difficult to read. Has anyone seen the same? I've tried seeing if Avin is willing to do anything about it, but they keep asking me to update the software for some reason. Seems that the clear plastic in front of the screen has just discolored from sunlight and there probably isn't anything to be done about it.
Pauloxxi339.00 |
06-10-2020, 09:59 PM | #2989 |
Rep 6
Optical cable change or not
Hi. i have a BMW f30 with harman system, and yesterday i installed an 10.25 android-10 SD625 HU, but the original sound sounds very fidelity, when I use android applications I lose a lot of fidelity. i dident move the optical cable from the original harness. Will I have to move it to the harness that is connected to the harman or does it not matter Thanks.
06-14-2020, 01:54 AM | #2990 |
Rep 1
Hello i have android unit in my bmw x5 e70 its been 2 years now it was working fine .. last 2 days its stuck on boot only back camera working nothing else is working now screen stuck on bmw logo please help me out .. tell me wat to do
06-20-2020, 03:49 PM | #2991 | |
Rep 14
Originally Posted by 335i6SPDManual View Post So my android screen stuck at boot logo ! I was sad for few days ! Here is the restore instruction to make your unit work again: 1. You need an empty micro SD card 2. You need to follow the 3 links below and download them, 1st link is the instruction, please follow the instruction. 2nd link is the SDUpdater. 3rd link is the firmware file, i think the firmware is old dated back to december of 2017, you can request Avin USA for latest firmware. NOTE: the instruction said to click on "run_For_Ver2.XX_loader", DO NOT run that, just run the Application with name "SD_Firmware_Tool". 3. After you follow the instruction to format the firmware into the Micro SD Card. Take it and put it into your screen Micro SD slot. Then start your car. Your screen will display the OEM function, just press and hold Menu button on your I-drive controller for few seconds it will switch to the android screen and you will notice that the android screen is doing it restore. After 5-8 mins it done and it will tell you to remove the micro sd card. The screen will automatically restart when you take out the micro sd card. NOTE: You will have to reconfigure your screen like you install it for the first time. 1st Link: https://drive.google.com/file/d/0B5c...tvLWZDbms/view 2nd Link: https://drive.google.com/file/d/0B5c...VZWEpEd2M/view 3rd Link: https://drive.google.com/file/d/0B5c...5FSWVQMDg/view HOPE THIS HELP TO ANY ONE HAVING THIS ISSUE ! |
