06-20-2020, 06:02 PM | #1 |
Rep 41
Closest place to idrive controller to tap KCAN-2?
Hello.
I'm currently retrofitting an idrive touch controller and module, and my F31's factory idrive controller is on KCAN-1. Besides the back of the NBT HU, where's the closest place to the idrive controller and module, that I can get the two KCAN-2 wires taped to? Thank you very much. (It's my first retrofit involving cutting and soldering wiring so disregard the silliness of the question ) |
06-21-2020, 03:23 AM | #2 |
Rep 2,302
Here you can choose one.
https://www.newtis.info/tisv2/a/en/f...lim/1VnYamQFRQ I think the base plate should be the nearest. |
06-21-2020, 08:51 AM | #3 | |
Rep 41
By coincidence, a few days ago I removed the cradle because I had no use for it. I had one thing different from the tutorial that I followed: I only had one plug like red ellipse number 1 on picture 1 (tutorial unplugged two). The white plastic support is there for two plugs (removed in picture), but I only had one. I'm saying this because I cannot find any yellow/red and yellow/brown twisted wires (KCAN2) in the base plate area. Is my wiring different? The cradle is red rectangle number 2 in picture 1, and red rectangle number 3 is the detail of the plug on the cradle. Red rectangle number 4 is where red rectangle number 3 connects to, in the car. Red rectangle number 3 has 4 wires but red rectangle number 4 only has 2. View post on imgur.com If I don't have KCAN2 lines on the base plate, can I use for example the gear shift stick like on picture 2? Are those blue/white and yellow/white twisted wires, KCAN2 lines? View post on imgur.com Thank you. EDIT: I found the schematics: those are KCAN2 lines. https://www.newtis.info/tisv2/a/en/f...ons/1VnYHs0NJP So now I have a doubt: If my tap develops electromagnetic interference of some sort due to my vastly extense experience in wiring :P , is there a chance of the auto gearbox malfunctioning during normal driving? For example: can the auto gearbox receive a signal to go into reverse, when going 90 (kph or mph - irrelevant), and actually engaging the gears? Thank you. Last edited by SpilltheBimms; 06-21-2020 at 09:02 AM.. Reason: Answering my own question? |
06-21-2020, 11:00 AM | #4 | |
Rep 2,302
So don't use it. Next device should now be the headunit. |
06-21-2020, 11:14 AM | #5 | |
Rep 41
NBT HU it is then. Yesterday I noticed that the pins (9 and 11) already have wires connected to them. Can I use newtis.info to find out where those wires end up? Maybe I can connect closer to the idrive controller, instead of the back of the NBT HU. Thank you very much. Last edited by SpilltheBimms; 06-21-2020 at 11:15 AM.. Reason: Nothing relevant to make a note of. |
06-21-2020, 11:55 AM | #6 | |
Rep 2,302
I think the KCAN2 wires go from the headunit to the FEM. |
06-22-2020, 04:16 PM | #7 |
Rep 41
