08-17-2020, 10:38 AM | #1 |
Rep 11
CEL - Active Autowerke catted downpipe for B58 (340i)
(Originally posted this in the General section, posting here also) Hey guys, so I paid a local shop to install the AA catted downpipe on my F30 340i. After 500ish miles, I got a CEL. I have MPPSK, no other tunes or mods. Just MPPSK and Active Autowerke’s catted downpipe. Anyone else experience a CEL? I’m really bummed because I spent $1k because of the no CEL guarantee... yet I still got one, and I’m short $300 on the install.
I’m open to any ideas on how to get rid of the CEL. I’m seeing mixed reviews on the O2 spacer (L and straight) on the B58. Some say it works, other say it doesn’t... The car has 47k miles and seems perfectly normal, no rough idling or misfires. By normal I mean since the CEL came on I can’t tell a difference in anything. And if anyone is curious, the catted downpipe makes the car significantly louder in sport mode and the burbles are almost too much/loud. The pops were pretty loud with just the MPPSK, with the AA catted downpipe they’re stupid loud. Sounds great though, and I love the exhaust note... just wish the pops aren’t as aggressive. Comfort mode is still pretty quiet. I also just ordered an OBD2 scanner so that I can diagnose the code, says it’ll arrive in a week. |
08-17-2020, 10:51 AM | #2 |
Rep 190,805
I think you are jumping the gun here by posting a thread about the downpipe when you do not even know what the code is and whether it was caused by the downpipe or not
the CEL normally pops up within 100 miles, you have been running with the pipe for 500 miles without any issues. Im not saying its impossible for the problem to happen after 500 miles but i recommend waiting till you get the OBD scanner before creating threads about it (you also posted about it on the AA downpipe thread)
08-17-2020, 10:56 AM | #3 |
Rep 519
Stop by an auto zone or something. They'll scan it for you...
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup |
08-17-2020, 01:41 PM | #4 |
Rep 11
Understood. I just wanted to see if anyone had a similar experience with the AA catted downpipe. Good point on not knowing the actual cause until I get a diagnosis. Will keep the thread updated with my findings.
08-17-2020, 03:38 PM | #5 |
PsyD
102
Rep 156
Drives: 2016 340i M-sport
No CEL with this DP - had it on since Jan/Feb of this year.
08-19-2020, 08:25 PM | #9 |
Rep 913
Drives: '17 F22,15 E84 M Sport,02 R53
I got the same code on my AA catted downpipe - I cleared it and it has not returned. If does I will be contacting AA.
Integrated Engineering engine mounts, Dinan CAI, AA catted DP, Remus resonated cat back.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
08-20-2020, 03:51 PM | #10 |
Rep 3,157
I suggest clearing the code and seeing how it goes. If there are any air leaks pre o2 sensor this can also cause a check engine light as well. Make sure its installed properly and everything is tight and sealed.. Any future issues just give me a call 305-233-9300 ext 227 and we will gladly help you out.
08-20-2020, 08:08 PM | #11 |
Rep 519
did the shop use a new gasket from turbo to DP or reuse the old one?
08-21-2020, 11:22 PM | #12 |
Rep 11
They used to new gasket that came with the downpipe. They reused the original v-clamp but there were no issues with that so I can’t imagine that would cause a leak. How you do even check for leaks? The car drives perfectly fine, and the installation looks spec perfect.
Btw, I cleared the code, and it came back within 200 miles... I’m going to try an L shaped spacer next. If that doesn’t work, I’m gonna replace the 2nd o2 sensor. |
08-24-2020, 10:37 AM | #13 | |
Rep 3,157
08-24-2020, 10:49 AM | #14 |
Rep 589
That is why you deal with Active Autowerkes folks! I have zero affiliation and don’t currently own any AA products, but I dealt with Mike and Karl Hugh (owners) in the early 2000’s on e36 M3 mods and they were pure class act. Great products that they stand behind and service to match.
tjbierman0.00 |
08-26-2020, 10:59 AM | #16 | |
Rep 11
I have not yet installed the spacer, but have reset the same CEL (P0420) twice now and it seems to come back every couple hundred miles. |
09-03-2020, 05:07 PM | #17 |
Rep 348
OP please update as you find a resolution! I recently installed this DP too because of the No CEL Guarantee. Good to see that Active has contacted you but seems like you're not the only one..... and for a $900 downpipe I really hope I don't have any issues with it either. I'm running it without tune and plan to keep it that way for a while.
Pure800 - DS2 HPFP - Nostrum S1 - ER Catless DP - Remus Non-Resonated Catback - BM3 Flex Fuel Kit - Ross V1 VTA PCV - Custom Tunes on MHD/BM3 - xHP Stage 3 - TCKline SA/DA Coils - Apex ARC8s - Vicrez Carbon Fiber CSL Trunk - ALP Laser System - Escort Max 360c with Blendmount + more... | IG: kianf22 |
09-03-2020, 09:50 PM | #18 |
Rep 348
Please update if you get it again
09-05-2020, 10:39 PM | #19 | |
Rep 327
2019 X3 M40i Alpine White/Black Vernasca stock
2015 435i Alpine White/Black Dakota FTP chargepipe, Dinan intercooler, M Performance exhaust, Carbahn Stage 2 tune |
09-06-2020, 12:00 AM | #20 | ||
Rep 348
09-06-2020, 12:12 AM | #21 | |||
Rep 327
kianf2264.00 |
10-03-2020, 08:55 PM | #22 |
Rep 348
Anyone experiencing lots of smell during cold start? Not happy with how much my DP smells. Bought this with the belief that it would BARELY smell if smell at all because it's a 300cel. I think my dealer will definitely notice it during service and that can be a source of a warranty claim denial for me...
active autowerke downpipe, b58 downpipe, downpipe cel |
