10-18-2020, 01:05 AM | #1 |
Rep 35
Ohlins R&T - UNDULATING AND BOUNCING
Hi Guys,
my f30 is on Ohlins R&T, 1 concern i have now is the cars is bouncy when crossing some undulation in the road surface. It feels as if the car would double bounce and if i encounter multiple undulation on the road surface, it's kinda uncomfortable at times especially in the freeways. Any idea how can this be dialed out? I've been trying to soften the struts to the max for front & rear, but it does not help. Should i actually be stiffening it up either the rear or front? Anyone encounter this and might be able to share what would be a better setup to counter this? |
10-18-2020, 07:57 AM | #2 |
Rep 1,934
It's pretty easy to adjust the firmness, so just try it first.
10-18-2020, 08:47 AM | #3 |
Rep 8,493
R&T uses parallel adjustment for bump and rebound.
From what you've described, you have the dampers set too soft. I run mine between 12 and 9 from full stiff, depending on my mood/preference.
10-18-2020, 09:58 AM | #4 |
Rep 55
I agree with Watsey, you need to dial in your compression and rebound damping.
I highly suggest studying and understanding these functions of suspension, simply thinking in terms of "stiff" and "soft" is not adequate to properly set things up. In basic setup, you want compression damping set open enough so that the shock can absorb impacts using the majority of it's stroke without bottoming out but not so soft that it continues to bounce afterwards. And you want rebound damping set closed enough so that it slows & controls the extension of the spring/shock after compression not causing it to pogo, but not so closed that the shock "packs up" over multiple impacts.
2018 340i X-Drive | M-Sport | MPPSK | Dinan Intake
Lancelot567.50 |
10-18-2020, 10:15 AM | #5 | |
Rep 1,934
10-18-2020, 10:23 AM | #6 | |
Rep 55
The Swedes know their stuff, they must have figured out a good ratio for comp and rebound so I guess you just have to find the sweet spot for your conditions (Just remember that clicks are counted backwards from fully closed)
10-18-2020, 04:02 PM | #7 |
Rep 8,493
@Freakystein also bear in mind that, as well as being parallel adjustable, the R&T have dual-flow valves.
These take the edge off secondary inputs which can cause a 'busy' ride, and allow you to focus more on controlling the suspension's response to the primary inputs i.e. run stiffer settings.
10-18-2020, 10:13 PM | #8 |
Rep 35
Hi guys, appreciate the feedback. I also suspected that the dampers might be set too soft, which causing the issue. I've stiffen up both the front n rear and see how it goes.
Btw, can we run slight stiffer rear to front or vice versa? Or do we need the front & rear to be the set at the same, E.g 10 clicks front & rear, or can i can do 10 clicks front, 7 clicks rear depending on my driving? |
10-19-2020, 02:08 AM | #9 | |
Rep 1,934
10-20-2020, 09:50 PM | #11 |
Rep 1,288
Stiffening up the back will help the car oversteer... you want it soft enough that it doesn't skip over bumps but firm enough it doesn't pogo/ wallow over bumps... that's the best I found so far for info... I'll be putting this reasoning to test very soon... I'm going to start off with 1/2 front 5/8 rear adjustment... I have a staggered set-up...
10-21-2020, 07:42 AM | #12 | |
Rep 35
10-21-2020, 08:32 AM | #13 |
Rep 8,493
Very stiff - I don't even run those settings on track.
10-21-2020, 11:19 AM | #14 | |
Rep 1,288
10-21-2020, 12:39 PM | #15 | ||
Rep 1,934
10-21-2020, 01:07 PM | #16 |
Rep 1,288
Yea... that's why I used 1/4 and 3/8 since all adjusting could be different.. I have 20 clicks of adjustment... so 5 front and 7 back I'll start off with from softest setting... That's with recommended tire pressure cold 32F/38R... we'll see how it goes.. the adjustment for the back is on the lower part of the shock... so easy to get to once your on your back...
Logicoeur991.00 |
10-21-2020, 01:09 PM | #17 | |
Rep 1,934
10-21-2020, 02:47 PM | #18 | |
Rep 8,493
For R&T my normal road settings are between 9-12 front and rear - I find the car rides evenly F/R in that range, and 'lands' well on roads which have larger primary undulations.
FastF30521.00 |
12-03-2020, 02:35 AM | #19 |
Rep 35
Currently i've tried with a stiffer setting, 8/8 for F&R and wow, it seems that the Ohlins R&T like stiffer damping to accommodate for the high spring rate. The whole car felt much more neutral and although is stiffer, but is not crashy or bumpy. The DFV is doing its job.
