09-18-2020, 12:32 PM | #639 | |
Rep 742
https://www.amazon.com/Dasaita-Capac.../dp/B074P35T3M
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
09-21-2020, 08:30 AM | #640 |
Rep 21
Hi everyone,
I also have the same problem regarding the display of the "TRSVC" module in my SVT. My FEM module does not have any default wire on the K_CAN 51/52 pins (A173*8B). Once connected, I checked the voltage levels on the connector of my "TRSVC" module (A167*2B). All is OK I have 12V on pin 7 (Supply, terminal 15) 1.8V on pin 6 (K-CAN_L) 3.3V on pin 5 (K_CAN_H) Pin 1 is well connected to the ground plane. I add "3AG" in my FA code. Unfortunately I don't have a "TRSVC" module that appears in my SVT ... I have the fault error : E59449 No message (status, qualifier rear-view, 0x39B), REM receiver, TRSVC transmitter My car model is : 118i (F20) LCI (04/2018), I-step 17-11-540. The reference of my FEM is : 61358707677-01 ZB FEM LEAR V13 HW: D9.0, SW: 16.114.030 It's so strange because when I do a TAL calculating (with my Istep shipment), I get a TRSVC. So normally my TRSVC module should be recognized ... Only the hardware version is wrong between the TRSVC display by TAL calculating (HW: 10.003.000) and my TRVSC purchase (HW: 10.002.000). Does anyone have an explanation to this ? |
09-21-2020, 10:52 AM | #641 | |
Rep 2,302
https://www.newtis.info/tisv2/a/en/f...-2v/1VnXT4PbeT If you then have the same problem the TRSVC is defective i think. |
09-21-2020, 12:05 PM | #642 |
Rep 21
I just checked, I don't have anything on pin 33/34 (A173*7B).
I try to connect the bus to these 2 pins anyway ? The exacte wiring schematic is : https://www.newtis.info/tisv2/a/en/f...-2v/1VnXgq8kBl |
09-21-2020, 12:42 PM | #643 | |
Rep 2,302
You can anyway try connecting the 2 pins there. |
09-21-2020, 03:22 PM | #644 |
Rep 21
No sorry on my car 118i, the air conditionning is connecting to K_CAN2 on the connector X20*1B.
I think my TRSVC module is dead, so I will change it in few day... I hope I am right. |
10-08-2020, 01:32 AM | #645 | |
Rep 22
Can we install ICAM natively without special adapters and without changing FEM to a newer version? |
11-16-2020, 10:53 AM | #646 |
Rep 109
I dont have can wires in pin51 and 52 then i saw these i tried using positap however i dont have any trsvc module showing up in esys and ista can someone help me?[IMG][/IMG]
Alsontried the yellow red anf yellow orange but not working Adding the error in ista |
11-16-2020, 11:12 AM | #647 |
Rep 109
quick question if you VO 3AG does that mean trsvc should be in ista? regardless if the ground and 12v is not connected or the can wires is wrong should it be in insta and should shaded red? or if there's not power or wrong can wires it will not show up in ista?
11-16-2020, 11:07 PM | #648 |
Rep 109
Soldered and added a line for pin 51 and 52. Started the car and check the voltage in the pin of the trsvc. Pin 1 and 7 i get 14.2v. Orange/green wire i get 3.5v. Green wire i get 1v. Does that mean wirings are all correct anfd the problem is my module might be broken?
11-17-2020, 10:35 AM | #649 | |
Rep 2,302
You can only measure the ground or 12V but not the KCAN lines. After you connected to Pin 51 and 52 do you see the TRSVC now in ISTA or E-Sys? |
11-18-2020, 09:57 AM | #650 |
Rep 109
yes i did. was able to connect it already and was able to install an 8.8" screen also. what i want to do next is to retrofit the pdc/camera button
11-21-2020, 02:16 AM | #651 |
Rep 67
Hi all,
Does anybody know if EntryNav2 head unit supports in general original rear view camera iCam (66 53 7 951 083) retrofit? In case only some of EntryNav2 supports does HU with part number 65 12 8 720 702 supports it? I can not find any evidence that FBAS on it working and it supports option 3AG. Thanks in advance |
12-30-2020, 06:28 AM | #652 |
e90 my big fat lady!
49
Rep 290
so i have e90 with nbt unit how possible is to install oem camera retrofit from f30?? i think can be done i am not very sure..
need small help guys !! |
01-06-2021, 03:21 PM | #653 |
Rep 8
Hi guys and thx a lot for all the incredible info that i found here. I ve installed the camera like roxxor said and for the nbt evo, the navi pins are red21, shield 23 and white 24. I had the short cable, the one for the f10 so i ve mounted the module, in the place that other cars have the combox. I had to split the cables, so that i can keep the green in the back, to connect it to the fuse box beside the combox and the kcan to route them neer the idrive.
All in all, it works perfect. Thx a lot again, all of you are great! |
02-02-2021, 07:35 AM | #654 |
Rep 12
Hello guys,
If someone can help me out. I’ve installed a rvc in my 2013 f31 Coded fdl but can’t get picture in NBT I have the menu option to select rvc but no image... Just a black square where the video feed should be. I’ve tryed different settings, icam, trsvc, and nothing seems to work. It’s an emulator box, connected to pin 21, 23 and 24. It’s also connected in quad lock to power, ground, can-H and can-L Any thoughts? Thanks |
02-02-2021, 11:00 AM | #655 |
Rep 12
02-05-2021, 12:15 PM | #656 |
Rep 12
02-08-2021, 03:17 AM | #657 | |
Rep 106
02-15-2021, 01:16 PM | #658 | ||
Rep 12
I only have this error in ista. Camera is connected to emulator box, seller is great, send a new box to see if that's the problem, I'm going to check tonight |
03-05-2021, 04:05 PM | #659 |
Rep 12
[img]https://i.ibb.co/5RkQJ4N/4-D907196-A...57-E37-ED1.jpg[/img]
[img]https://i.ibb.co/Wpj5GyF/E9-C04-A56-...-CF7149-A9.jpg[/img] Can someone share any opinions please? Thanks |
03-16-2021, 05:14 AM | #660 |
Rep 63
Looking into doing this retrofit and I have a question (sorry if it has been asked, did try and search through posts first).
I am looking into different TRSVC modules from scrappers. They are usually quite old (like 2010 - 2013). I see the part number has updated over time. My main concern is having the moving guide lines available and the obstacle highlights. Do I need a TRSVC module upwards of a certain year (or part number) to have this available? What I am missing is where are these features implemented. In the HU / PDC or in the TRSVC module? If they are not coming from the TRSVC then my guess will be that the age of the module doesn't matter. Am I correct? Thanks in advance. |
