06-07-2013, 04:24 PM | #1 |
Rep 210
Track Set Up Thread
I thought I'd create a track set up thread so people can discuss and learn from each others set ups. For each set up, please include information on suspension, wheels/tires, brakes/pads, software, and any other parts that might be informative to people who track their F30. Please also include a review of your set up on track (and on the street).
Unfortunately, I have nothing to offer until my first track event with this car in two weeks. Until AST comes out with coilovers (and camber plates) for the F30, my set up will be as follows: Suspension: stock sport line (with stock alignment) Wheels: APEX ARC 8 18X9 Tries: Nitto NT-01 235 or 245/40/18 Brakes/Pads: Stop Tech BBK ST-60, 355X32 F; ST-40 345X28 R, with Stop Tech street and race pads Software: stock I will post my review from my NASA event at Gingerman in a couple of weeks. I suspect my tires and brakes will overwhelm the stock, marshmallow like suspension.
SCCA & Midwestern Council W2W, '91 Spec Miata, '07
NASA TTD Champion, Midwest, '99 M3, '09 Midwstrn Council TT Champion, BS, '10 GTI, '10 &'11 Midwestern Council TT Champion, BS, ‘17 BRZ, ‘19 Last edited by JMK007; 06-09-2013 at 09:26 PM.. |
06-09-2013, 07:36 PM | #2 |
Rep 234
I had the ST40's on the front of my E46 and they were great calipers, especially when coupled with Pagid Orange pads. I ran Blue's on the street for a bit then learned to live with Orange for both track and street. I imagine with the 60's up front and 40's in the rear your setup should equal if not rival the OEM BBK that I have on my F30. In either case, you most definitely WILL be able to take advantage of the extra braking power with the NT01s. With that said, my car has the DHP and I found it plenty good for track use. Of course, I was on the RFTs. One day I'll see about mounting up the NT01s I have on a set of track rims but if there was one area I'd want to improve the suspension first with a DHP car it'd be the swaybars. The 'electronic' shocks actually do a decent job, especially considering they can pull double duty being that my F30 is my DD.
06-14-2013, 02:11 PM | #3 |
Rep 2,431
I'll let you know after this weekend, but I just sold my track car and I already signed up for willow springs so ill be going out with my
328i H&r sport springs +1/16 toe out and -1.5 camber 255/40/17 nt01 on stock 17x7.5 This will have to do in a pinch
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
06-14-2013, 02:42 PM | #4 |
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
How'd you manage -1.5 deg camber on an F30?
06-14-2013, 03:03 PM | #5 | |
Rep 2,431
06-15-2013, 07:35 PM | #6 |
Rep 2,431
I thought this was on topic...
Rear seat fits 4 tires with the center console folded down to let a pop up through And while 255-40-17 is considered too wide for a 7.5" rim. It fits in a pinch and the handling isn't bad at all since the tire sidewalls are so stiff
06-17-2013, 11:40 AM | #7 |
Rep 623
I always wanted to track my car and think I finally will this year. Just sold my heavy 20" wheels and looking into purchasing some light weight 19"... I know it's probably best to go with 18" for the track but until I am super familiar with tracking I still want a clean and nice setup.
06-17-2013, 12:40 PM | #8 |
Rep 2,431
Just got back from big willow springs. My setup gave me a best lap time of 141.1 in 99* heat with a lot left on the table once I figure out turn 1 and 9 it was fun running out there with e36 m3's and brz's
My biggest gripe about the car was lack of steering feel and the lack of throttle modulation/power.... What I did love was the light front end that loved to turn in and the car was well balanced with a slight hint of understeer. Keep in mind I'm used to tracking high hp cars that rarely go wot. At first I thought I wasted my day coming out with this car but once my mentality switched to momentum driving it was a real hoot and I would do it again, even with a dedicated track car Posting video soon....
06-17-2013, 09:28 PM | #9 | |
Rep 210
NASA TTD Champion, Midwest, '99 M3, '09 Midwstrn Council TT Champion, BS, '10 GTI, '10 &'11 Midwestern Council TT Champion, BS, ‘17 BRZ, ‘19 |
06-18-2013, 12:52 PM | #10 | ||
Rep 2,431
06-18-2013, 02:26 PM | #11 |
Rep 2,431
Oh yeah, and lift throttle oversteer was not a problem. Very well balanced
06-18-2013, 04:34 PM | #12 |
Rep 210
Krnnerdboy,
Glad to hear the suspension worked well. Do did you find roll resistance greatly increased after the just H&R compared to stock?
06-28-2013, 08:37 PM | #13 |
Rep 349
OP, after your experience would you make any changes to your tire width? I'm in the market for your same wheel. I've been recommended to go 245's all around with SS's.
06-28-2013, 10:04 PM | #14 |
Rep 210
I would not pick anything more narrow than 245. 255 would probably be the widest I would go, though steering feel would not be as sharp on turn in. I think 245 may be ideal.
06-30-2013, 09:50 PM | #15 | |
Rep 349
http://www.f30post.com/forums/showpo...2&postcount=18 |
07-01-2013, 10:41 PM | #17 | |
Rep 210
07-04-2013, 02:44 AM | #18 | |
Rep 2,431
07-08-2013, 05:27 PM | #19 |
Rep 1,245
Setup is as follows
328i DHP H&R sport MPerformance Brembo's Challenge SS brake lines 8.5x18 running Yoko Neova's 245 front 255 rear Ran my first event on the stock runflats so needless to say a huge all-around improvement was found with the track wheel/tires. I also added the SS lines after my first event with the car and that further extended braking before ABS intervention. aside from those obvious improvments I still consider myself a track newbie so I'm reluctant to point out the vehicles flaws...because the majority would probably be that of the driver
03' 525iT stick, 22' 530i
Previous: 20' X3 M40i, 19' 740i Msport, 17' 430i GC, 15' Msport X3 28i, 15' Sportline X1 28i, 13' Msport 328i, 09' Msport 335i, 07' Msport 335i |
07-09-2013, 09:22 AM | #21 |
Rep 1,245
Challenge, they're a vendor.
07-10-2013, 06:03 PM | #22 | |
Rep 1,050
Suspension: KW V3s Alignment, Camber: reduce toe for mileage, -0.7 ft. -1.9 rr. Wheels: APEX ARC-8, 17X9" ET42 Tires: Hoosier R6, 245/45/17 Brakes: Stock I recently tracked my F30. It was better than expected and the light front end along with the KWs was crisp, poised, and surprisingly good with understeer. The motor was great and even though I have an AT the car was really fun and crisp, as long as you turn off traction control. In 110 degree heat there was no perceivable loss of power and no overheating. Hallelujah!!!! I previously owned an E92 335 The brakes were less than desirable but I just used the sock pads and fluid. My fault. I got the funniest warning I had ever seen half way through my last session: "Excessive braking load: Drive moderately". It made me laugh as I was entering a braking zone at 110. Funny. I used 245/40/17 Hoosier R6s, which are a little small in diameter. They should be 245/45/17 for the F30 but I had these . The Hoosier 245s measure to 255 so this is in reference to other manufacturers 255s. I had never driven a car where, in a way, the tires had more grip than the car. The KW V3s are very, very good and I highly suggest them for a street/track car. KW targets the performance street user but I think they're more than good for the track. The V3s have the feel and control of a much more expensive coilover and even with the progressive springs, which I hate on the track but love on the street, the car was very poised and predictable. I could have even dialed up the compression damping more to mimic stiffer springs and I'm sure the handling would have been even better and with less body roll. I would love some swaybars as an interim upgrade to control the body roll until the aftermarket matures for the F30. Without aftermarket bushings and M3 suspension bits available, I wouldn't use stiffer springs to control roll and increase handling as the weak links are all of the soft, rubber bushings. I do like stiffer springs as opposed to large swaybars to control roll but at this point I would opt for the bars. With the suspension setup, throttle steering in sustained corners was easy and I only had to compensate for understeer a little. The suspension, tires, and car were remarkably good as a system and would have been much better with a manual tranny. The motor was really great and I expect great things from it. I loved going at it with fully prepared track cars in the race group with my "Mom Rocket" SUSPENSION NOTES: You may want to change to a stiffer, linear spring but as I said above, wait until better bushings and other suspension bits are available. With KW V3s and a very low ride height I only get a little rubbing on the fender liner at the 2:00 position close to the outside. This is mainly due to my ride height. It's only low because this isn't my track car so maximizing handling isn't vital to me. I'm after looks Last edited by jbass524; 07-10-2013 at 07:27 PM.. |
