11-16-2020, 11:31 PM | #1 |
Rep 180
Do I need a transmission cooler? (ZF 8HP50)
Greetings,
I recently started tracking my car more often and was wondering if I could add a transmission cooler to my 2016 340i. I push my car to the limit on the track, but was wondering if a transmission cooler is really needed? What is the typical operating temp or normal temps on the 8HP50? Any feedback greatly appreciated!
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 Last edited by Mr. 340; 11-17-2020 at 05:46 PM.. |
11-19-2020, 01:45 PM | #4 |
Rep 180
I am pretty sure I don't. The only auxiliary cooler I know I have is on the passenger side fog light vent, but from what I have read thats the engine oil cooler.
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 |
11-19-2020, 01:46 PM | #5 |
Rep 180
But do you have the transmission cooler or without it?
11-20-2020, 06:43 AM | #7 |
Rep 214
The image on the right shows your trans cooler, the front drivers side cooler is a remote radiator.
Here is the remote radiator you're missing, it is not part of the transmission cooling system. https://www.realoem.com/bmw/enUS/sho...diagId=17_1012 Last edited by TheFanatic; 11-20-2020 at 06:51 AM.. |
11-20-2020, 10:04 AM | #9 |
Rep 180
Oh... well if that is the case then I guess all I would need is the radiator. I will double check anyways. Thank you!
11-23-2020, 06:52 AM | #10 |
Rep 214
The trans cooler isn't a front mount radiator but uses engine coolant to cool the transmission fluid. The two pictures that were posted show the trans cooler
11-23-2020, 09:58 AM | #11 |
Rep 3,179
Pretty sure that is a trans heater rather than cooler. To get the trans fluid up to temp faster. Trans fluid likes to be 160-180, not coolant temps.
11-23-2020, 11:20 AM | #12 | |
Rep 214
also its listed as a trans cooler in realoem https://www.realoem.com/bmw/enUS/sho...diagId=17_1013 |
11-24-2020, 06:46 AM | #14 |
Rep 420
I know. But our climate rarely pampers with heat in summer. Only two weeks in August. So the box temperature on the M140IX does not exceed 90C.
M140IX. Turbo Pure 800 Cast.
11-24-2020, 06:51 AM | #15 | |
Rep 214
The overwhelming majority is far below that, the engine is the last thing the coolant goes through before going to the radiator, if you're your coolant is at 200 degrees after it went through the radiator there wouldn't be enough room left in it to cool the engine properly and you'll overheat. |
11-24-2020, 06:58 AM | #16 |
Rep 214
This photo will help you greatly in understanding how radiators work.
Pussiwillow521.00 bigdnno98286.50 |
11-25-2020, 12:27 PM | #18 |
Rep 931
Never any problems with it here either
Mr. 34068.00 Pussiwillow521.00 |
11-26-2020, 09:33 AM | #19 |
Rep 180
I appreciate all the feedback! I will just leave the car as is then.
11-29-2020, 12:20 AM | #20 | |
Rep 3
Checked the tube connections, transmission use an independent cooler, to reduce the temperature of engine.
BDC Automotive Workshop China
12-07-2020, 12:59 PM | #21 |
Cheapskate
4442
Rep 4,992
Guys, there is a separate heat exchanger for the sport auto trans. It's #13. You'll see it in the kidney grilles, it's a thin heat exchanger mounted at the top edge of the main radiator.
12-08-2020, 07:32 AM | #22 |
Rep 180
Yeah exactly, that is what I was referring too. My model doesn't have that, but many say they have no issues with overheating without that radiator, so I guess it's not really needed?
