07-30-2020, 03:14 AM | #1431 | |
Rep 585
If in the logs you activate Load Required %, Load Actual RAM and Throttle Position you'll see that the throttle closes a bit where Load Actual exceeds Load Required. If it exceeds the target by too much you may also see a Torque Limiter activated. A custom tune would be able to reduce the throttle closing if it's concerning you. If you use SAE correction in Virtual Dyno, adjusting for the different ambient pressure and temperature would make a difference. You're also using smoothing factor of 1. I'd recommend using smoothing of 3 as a minimum. Edit: Check your tire size in VD as well, should be 26.03 if you have 255/40/18 or 255/30/19 rears.
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
Uni-Rapide71.00 |
07-30-2020, 03:31 AM | #1432 |
Rep 1,010
You already have 20 psi boost at top end and your timing is 5 degrees which is very low.
I think you should try 20 psi at midrange and reduce boost gradually to 18 psi from 5500 to redline.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
07-30-2020, 07:45 AM | #1433 | |
Rep 198
Freaked me out first time it happened as some said I had a boost leak. |
Uni-Rapide71.00 |
07-30-2020, 12:35 PM | #1434 |
Rep 242
Well Paul finished my e30 map all i can say he make excelent job imo. For my altitude and hot summer temps i think my log looks perfect (1800-2200DA) https://www.bootmod3.net/log?id=5f21...90c67e9ceed34b waiting for masterminds to comment
07-30-2020, 12:55 PM | #1435 |
Rep 435
Yes but with 6psi less midrange boost, won't that help with the gradual increase of timing?
'16 F80 M3 6M/T (sold)
'20 Toyota Supra |
07-30-2020, 01:40 PM | #1436 |
Rep 312
Drives: 2019 x3 M40i
Think I've got a winner now between my current e30 blend, stage 2+ e30 map, and how my car likes to run. Probably the prettiest log I've produced. Only slight concern is the somewhat erratic HPFP up and down mid RPM. Thoughts?
2019 X3 M40i BM3 Stage 2+ E30 map ~E32 fuel MST intake VRSF charge pipe ER catted and coated downpipe Dorch Stage 2 HPFP 5th gear pull. https://www.bootmod3.net/log?id=5f22...90c67f30eb14f7
2019 X3 M40i - Phytonic Blue - MST Intake, VRSF Chargepipe, ER catted/coated DP, Dorch Stage 2 HPFP, BM3 stage 2+ e30, XHP stage 3, 275/40/20 Michelin MPS4
07-30-2020, 01:56 PM | #1437 |
Rep 1,010
It will help with lower IAT building up which will improve your timing, anyway you have to log and see the results and make changes from there.
Apparently the B58 combined with bad fuel doesn't like hot weather especially when it reaches 40 degrees C. Here's my stock MPPSK log in 40 degrees C, a total mess: https://datazap.me/u/ims/mppsk-40-de...og=0&data=4-22
07-30-2020, 02:59 PM | #1438 | |
Rep 122
Unfortunately I didn't select the ambient temp during the logs and can't remember the temp when I did the 102RON run so SAE correction is a bit of a guess. For future logs I have selected ambient temp ;-) I selected smoothing factor 1 based on the smooth 102RON but will try the higher smoothing factor. I'm running 265/35/19 rears so that's why my tire size is a bit larger.
Mods: 19" HRE FF15, M Performance diffuser, Bilstein B16 Damptronic, VRSF catted downpipe, Remus catback, Dorch St1, Pure 800, OS Giken LSD, Ross Racing PCV+OCC V1
OzBMR574.50 |
07-30-2020, 03:50 PM | #1439 | |
Rep 435
'20 Toyota Supra |
IMS-340C394.50 |
07-30-2020, 04:20 PM | #1440 | |
Rep 643
your pre throttle boost is consistently ~4 psi over target.. yet the "boost deviation" channel only reports 0.4 psi..makes me wonder when DME will intervene, if at all. weird thing is your MAP is flatline with the target, so, is this a limitation of that sensor? did you upgrade the tmap sensor? timing looks good.
M235i rwd 6mt
07-30-2020, 04:26 PM | #1441 | |
Rep 242
07-30-2020, 05:34 PM | #1442 | |
Rep 585
Torinalth194.50 |
07-30-2020, 05:49 PM | #1443 | |
Rep 585
Did you do anything with the coil pack because cylinder 1 is much better timing now? Will you revert to 100RON tune or stick with ethanol?
07-30-2020, 05:58 PM | #1444 |
Rep 242
Ill drive it to enjoy one more month and after just from time to time cuz ethanol is 3,50euro per liter here I didnt change coil pack
07-31-2020, 01:18 AM | #1445 |
Rep 255
Been having a weird sound with my car and after a few week of shop time and not getting it fixed I'm pretty sure i narrowed it down to wastegate issue.
Trying to verify before I bring the car back to the shop a second time for weeks again. Wondering if you guys can see anything weird with this log? Wastegate specifically but anything abnormal is fine. https://datazap.me/u/alfanzo2/pure-8...;zoom=560-2911 When comparing my WGDC% to my previous logs it seems about the same. First 3rd gear pull is under boosting but the pull after is hitting target PSI which is weird.. |
07-31-2020, 03:03 AM | #1446 | |
Rep 95
I think he basically used the boost limit to limit the top end boost / load > 5500RPM, then used the load limit to regulate the boost < ~5500rpm, that is exactly what I do and it works a treat, and I think give nice feeling power band. there are some odd discontinuous in your timing, and its not correction related (knock & IAT), as you correction is stable, so you should ask him to see if anything odd in the IGN tables, like some changes that need to be smoothed out, with IGN vs load for example, as you should not see the IGN change by my almost 2 deg when load is only changing by a few %, or did you leave your TC on? if so that may also be some TC issue Last edited by RMMAGA; 07-31-2020 at 03:08 AM.. |
07-31-2020, 07:50 AM | #1447 | |
Cheapskate
4447
Rep 4,993
yokata156.00 |
07-31-2020, 09:37 AM | #1448 | ||
Rep 151
Kirill @ OdinTuned
07-31-2020, 03:44 PM | #1449 |
Rep 198
Latest w/ MG ST1+ v2.11 on E20 mix & Injen CAI on 2018 440i GC...
https://bmw.***********.com/graphs/log-07-31-2020-20-09-45.2059/?series=1&zoom=-1,137 I ran out of road at 6000 rpm, but figured better than nothing. EDIT: just realized the url was redacted...street of spool 😁 |
08-01-2020, 01:00 AM | #1450 |
Rep 585
10.94@127mph Log File
Here's the log file from my 10.93@127MPH run at the drag strip today. Did two almost identical runs within 0.01s.
https://datazap.me/u/ozbmr/ozbmr-dra...23-24-25-26-27
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph Last edited by OzBMR; 08-01-2020 at 01:06 AM.. |
M140_BCS237.50 |
08-01-2020, 02:27 AM | #1451 | |
Rep 151
Also for everyone saying that anything leaner than 12.5 throughout the RPMs is dangerous - look closely at the AFRs here and take a note. Direct injection fuel system does not need excessively rich AFR (<12.5:1) to keep the engine safe. Significantly higher fuel rail pressure with DI systems provides very good fuel atomization which helps dissipate heat in the cylinder. Running richer not only does waste gas but can also reduce torque.
Kirill @ OdinTuned
08-01-2020, 02:55 AM | #1452 | |
Rep 10
