04-20-2020, 09:00 AM | #353 |
Rep 314
It's $340 US well worth it.
Kiel McCaul
04-20-2020, 10:17 AM | #354 |
Rep 963
ah - thanks i was looking at the 6 speed map pack for $76. that's still much better than i was expecting.
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
05-02-2020, 07:51 PM | #355 | |
Rep 8
06-15-2020, 11:50 AM | #356 | |
Rep 7,607
New XHP Line Pressure Bump Feature
I am wondering who is using the new Line Pressure Bump feature. See PDF page 27 of the manual: https://www.xhpflashtool.com/fileadm..._manual_en.pdf
The manual states Quote:
06-15-2020, 12:36 PM | #357 | |
Rep 84
I have this option enabled on my car .. without this option enabled boost will drop on 6 gear if I'm running anything over 22+ PSI. With this enabled it will hold till around 25-26 PSI+ without dropping on 6 gear.. unfortunately anything over 27 PSI+ and it still drop Best way to check if you need to enable this is to log.
'14 F30 335i N55 EWG - Speedtech Stage 3 EFR 8374 - BM3 Custom Tune - xHP Flash - BMS Meth kit - Dorch Stage 2 HPFP - ER FMIC & CP
06-26-2020, 10:34 AM | #358 |
Rep 467
I got the xHP flash for my car last weekend. So far not impressed. Tried stage 1 and stage 2. Didn't feel a bit of difference in any of the sport modes from stock setup. Shifts are no quicker and still a little delay like before flash. Maybe my expectations were to high and the changes are very subtle. For the money and the hype by the various youtube product reviewers, thought it would be more than changing the gear selector view in automatic shifting mode on the cluster. Haven't pushed the car as recommended for the first 50 miles to allow for adaption. Maybe I'll feel a difference then. But thought I would have noticed "something" after the flash.
06-26-2020, 10:40 AM | #359 | |
Rep 153
06-26-2020, 10:49 AM | #360 |
Rep 467
06-26-2020, 11:38 AM | #361 | |
Rep 7,607
The difference is a little more noticeable when in sport/sport+ and shifter to the right, but the magic happens in sport+ and shifter to the left if you are looking for the most noticeable increase in performance. There is absolutely a difference in shift speed and quality/feel in sport+ and sport transmission (shifter to the left), especially on stage 3. This is true not only for manual shifting but when you leave the car in auto as well. I drove gently for the first 50 miles as recommending and the moment i went into sport + and shifter to the left and did a 0-100mph pull at about half throttle the shifting was obviously different. Also, note that the paddle response is actually slower than OEM unless you are in sport + and shifter to the left. This was discussed in several other posts. Finally, XHP is about a lot more than just the change in shift speed/quality. Its about 'properly' removing torque limits, increasing line pressures, etc, to go along with a car that has FBO and beyond power levels. It also allows full customization of all the parameters - for example i have used the shift point editor to set my non-kickdown shiftpoints to 6300 so that WOT auto is more useable (not revving to 7k for no reason). You can also use torque limits per gear, etc. My recommendation is go to go stage 3, drive the car a bit, then go into sport + and shifter to the left, and try both auto and manual modes. Stage 3 is totally fine for a daily driver, not harsh or anything at all. |
07-09-2020, 12:53 PM | #363 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
07-13-2020, 12:23 PM | #365 |
Moto Lover
187
Rep 591
07-15-2020, 04:12 AM | #366 |
Rep 153
07-17-2020, 08:58 PM | #367 |
Rep 22
Question to anyone that can answer please. I would like to purchase xHP to flash my tranny since I will be going PS2 next week. For my F30 the license is currently $171. Do you get to choose a free ots map? If not on the website the OTS maps are also $171 for 8 speed? Is this correct or am I crazy lol?
07-17-2020, 09:58 PM | #368 | |
Rep 7,607
07-20-2020, 05:25 PM | #369 |
DisplacementReplacement
409
Rep 1,104
I'm of the opinion that XHP changes the feel of almost everything especially if you adjust shift points. It's less perceptible in normal and basic sport but it is perceptible. in normal, sport and sport + with traction control off the shifts are tight, to me, much much tighter then stock. My 2cents......... very happy with results, it's the way it should be from factory.
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
07-20-2020, 06:35 PM | #370 | |
Rep 7,607
As for shift points, i edited all of mine (without kickdown depressed) to be 6100 in both D and S modes. Stock is 6900 which frankly is unnecessarily high for stock turbo. |
Conr4d27.50 |
07-22-2020, 05:33 AM | #371 | |
409
Rep 1,104
08-06-2020, 03:49 PM | #373 |
Rep 7,607
Go straight to stage 3, drive about 15-20 miles of city driving in D/Comfort mode, then get on the highway and do another 15ish miles in D/comfort and D/eco (eco helps with coasting and shift to neutral), then go back to city driving and do some medium throttle in D/Sport for maybe 5 miles, then let it rip with S/Sport + and you wont be disappointed
DVC558.00 |
08-06-2020, 04:29 PM | #374 | |
Moto Lover
187
Rep 591
So I was planning to flash it after work and drive home (38 mile commute) that starts off at normal traffic conditions (going about 80mph) till I get closer to Temecula, then it's bumper to bumper. This should be fine yea? I don't see this causing any issues. |
