08-24-2020, 10:30 AM | #397 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
For hard shifting, is there a way to remove it in lower gears? Especially in Comfort mode?
Super jerky and uncomfortable when driving around town running errands with the lady. |
08-24-2020, 11:53 AM | #398 | |
Rep 7,607
You shouldnt have any jerky shifting... i run stage 3 and my shifts in D/comfort are very smooth. I don't think i have ever had a jerky or uncomfortable shift either before or after XHP. In S/sport+ they are crisp and faster but i still wouldnt call them jerky. |
08-24-2020, 12:04 PM | #399 | |
Moto Lover
187
Rep 591
The car felt fine when I first did the flash. This only happened after I switched my maps from E30 to 91ACN. Wondering if me reflashing on BM3 has anything to do with it. Gonna get some more mileage and see if anything changes. Just wanted to bring this up just in case if anyone had dealt with the same feeling. |
08-24-2020, 12:10 PM | #400 | |
Rep 7,607
One thing you can do is make sure you XHP app is fully updated, then re-flash whatever stage map you are on to the newest version. Might help, especially if its been a while since you did the XHP flash since maps have been updated fairly recently. |
08-24-2020, 12:22 PM | #401 | |
Moto Lover
187
Rep 591
I turned on stock shift points and reflashed it yesterday after visiting Home Depot. Gonna drive it around and see what it does. What settings do you have setup? If you don't mind sending me a screenshot of what you have, I'd greatly appreciate it. So far I have max rpm (6100 like you) but I might switch it to 6k. Also have stock shiftmaps and torque limits turned on but left the settings as is. |
08-24-2020, 12:41 PM | #402 | |
Rep 7,607
The only things i actually changed in the settings were the enable gear display in D mode, and setting max rpm to 6100. Didn't mess with anything else. Next time I pull up the app i can get SS but might be a while since my car is dialed right now lol. I didnt change the shiftmaps if you are talking about the % sliders. Left those as is. Why would you turn torque limits on? Did you also make sure to choose the correct flash option on MHD? |
08-24-2020, 12:56 PM | #403 | ||
Moto Lover
187
Rep 591
I don't have shiftmap deleted but I do have stock shiftmap selected. I just realized even though I had stock shiftmap selected, it was turn off. Just turned it on, gonna see how that goes. I thought it was good to turn torque limits on? But after going back a few pages, seems like XHP actually removes torque limits "properly". Should I turn that settings off? Here's what I have right now |
08-24-2020, 01:10 PM | #404 | |
Rep 7,607
08-24-2020, 01:20 PM | #405 | ||
Moto Lover
187
Rep 591
I turned off torque limits for now. I will email them to see what they say. This is a screenshot of the torque limits description. |
08-24-2020, 03:34 PM | #406 |
Rep 114
hey Jeremy I switched back to a 91 tune from e30 I noticed my shifts aren't as crisp anymore at half throttle or so there us a tiny bit if hang between the gears feels like someone is lightly tapping the breaks especially 5-8. Time to sell?
08-24-2020, 03:43 PM | #407 | |
Rep 7,607
What do you mean time to sell? Ive never experienced what you described but it could be a DME tune issue not a XHP issue... You should try flashing the newest XHP map to make sure but in generally you shouldnt need to reflash XHP after a DME tune change. |
08-24-2020, 03:49 PM | #408 |
Rep 114
Yes I reflashed both of the tunes already got a little better but i can still feel it its very slight and minor if soemone would have drove the car they would notice it just bugs me do you thing the adaptations are just still set for the higher hp tune?
08-24-2020, 03:52 PM | #409 |
Moto Lover
187
Rep 591
Do you have yours manually turned on?
08-24-2020, 04:17 PM | #410 | |
Rep 7,607
If you're talking about DME adaptations, you can just drive 50 miles after the tune change and see if things get better. Ive only changed DME tunes once since running XHP and i never noticed any issues when switching. I've also updated XHP map version a few times and everything was always consistent. No. No changes aside from gear display in D and shift points at 6100. I can basically hook 1st gear from a dig with little to no spin with PS4S tires so i have no need for them. |
08-25-2020, 10:38 AM | #411 |
Moto Lover
187
Rep 591
So I think changing my BM3 tune kind of reset my adaptation. Driving home from work yesterday, the "lurches" were minimal. I made changes to the XP tune like you mentioned thejeremyman9 but as stated, I don't think any of that would affect or have any connection with my "lurches/jerks".
I will test this theory in about a week or some after I go through another tank of 91. I switched over from my E30 mix to 91 to reset my tank. Piece of mind. After this tank, I will flash back to my E30 mix and will see if it goes back to these aggressive lurches. |
08-25-2020, 12:17 PM | #412 | |
Rep 7,607
08-25-2020, 12:29 PM | #413 | |
Moto Lover
187
Rep 591
To keep things on topic, here is a response from XHP and my question about whether or not I need to turn on torque limits: Hi Richard, our OTS MAPS have pre-defined torque settings. Stage 1 and 2 are 800NM for all gears and stage 3 uses 1000NM in all gears. You only should activate the torque limits if you want to limit certain gears. Like for 1/4 mile cars with "bad tires" you can limit the 1 and 2 gear to 600NM as example to lower the wheelspin. Best regards, Semin Biscevic Product Genius xHP & xDelete RBT TUNING GMBH – Home of xHP Flashtool & xDelete |
08-25-2020, 08:36 PM | #414 |
Rep 2,358
Change in throttle sensitivity
Has anyone else experienced a change in throttle sensitivity going from eg. Stage1 to Stage3? My car feel much more twitchy with Stage3 comparing the two like for like
(A Dane in China) |
09-26-2020, 09:29 PM | #415 | |
Rep 13
I've posted a few times now. This forum has been great for a newbie modder. I've lowered and widened my 435d X. Had it tuned and added zimmermann discs and pads now. Next is a gearbox tune, hence this post. The above quote sounds like the remap holds the car in gear for longer. Exactly what I want. Can someone confirm for me before I buy if it does this in Sport too :-) I drive in Sport mostly and it annoys me how the car gets to S4 by 40ish mph. I like my car to rev a bit. Thanks in advance. Last edited by Stevro; 09-27-2020 at 05:19 PM.. |
09-28-2020, 11:16 AM | #416 | |
Rep 7,607
Also, if you REALLY want to hold gears for maximum revs, you can do the new stage 4 map which is basically for track use and always shifts up and own to keep you in the upper RPM range. |
06-14-2021, 11:51 AM | #418 |
Rep 461
I believe those are the settings Kies uses on his pwg xdrive 335.
I've got mine at 10 and 10. Seems to work well. I haven't experimented beyond that yet. Its a little hard to do a straight back to back comparison because after you do a launch, the dme has a cool down period before it will let you launch again. Not sure exactly how long it is. Last edited by 435gc; 06-14-2021 at 12:40 PM.. |
