BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > bmw maps Next 2018-2 update problem
      09-16-2018, 12:43 PM   #1
Skeeco
Skeeco's Avatar
Croatia
Drives: F30 318d
Hello.
I've tried searching the forums but i haven't found anyone with similar problem..
So, I've got 2014 F30 with NBT. I have 2014-1 version of maps and I want to update. I've bought USB with maps and FSC code.
When I insert the usb into the car, i get the message on my display that USB device contains more recent version of navigation data blah blah, and i can click Start update, or Cancel. Of course I click "Start update" and nothing happens.. My display goes back to where it was (radio station list) and that's it. It doesn't ask for a code, it doesn't start copying...
Has anyone encountered similar problem/situation?
USB is 64gb, formatted to NTFS. I've tried copying maps to my computer, reformatting usb to FAT32 or exFAT but then the car doesn't recognize usb at all. Any help would be appreciated.
      09-16-2018, 02:53 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
What does the developer say? Are you sure it's not downloading in the background?
      09-17-2018, 02:02 AM   #3
Skeeco
Skeeco's Avatar
Croatia
Drives: F30 318d
I don't know... how can I check? I can't find anything that could tell me that there is update in progress in the service menu or anywhere else for that matter...
      09-17-2018, 11:04 AM   #4
x-m4n
x-m4n's Avatar
Drives: Gran Turismo (F34)
New maps take some 45 mins to load - you can use the navigation as usual while the maps are transferring, you get a message when all is done.
There is a progress bar somewhere there in the options - click options from the map view and see if you can spot the option there and see if you already have the new version of the map.
Failing that best to contact the provider...
      09-17-2018, 01:16 PM   #5
Skeeco
Skeeco's Avatar
Croatia
Drives: F30 318d
Since i can't find progress bar in options, I'll just assume that it's not updating in the background.
Tried calling a "friend" in BMW service, says he hasn't heard of that problem before. He said that i should bring the car to them, but I'm not thrilled about paying for the update twice, as I can imagine that will be the case if i bring it to them..
I have also sent a message to provider, waiting for the answer...
Is update possible any other way than via USB?
      09-17-2018, 05:37 PM   #6
Jhnblckwood
Drives: F30 2014 320i xdrive
Pretty sure u can burn to dvd discs
      09-17-2018, 09:30 PM   #7
Billfitz
Billfitz's Avatar
DVDs are only 4.7 GB. I'm guessing that's not enough.
      09-18-2018, 06:16 PM   #8
Jhnblckwood
It can b done. Jus use more than one but I do kno it has to b set up correctly so hu knows to look for second dvd instead of usb or whatever.
      09-19-2018, 12:48 PM   #9
IAmATeaf
IAmATeaf's Avatar
Drives: 2015 F30 335i
2015 BMW 335i  [0.00]
Dual layer DVD?
      09-19-2018, 03:41 PM   #10
Jhnblckwood
Originally Posted by IAmATeaf View Post
Dual layer DVD?
Idk if dual layer would work. The map update u downloaded did come packaged as 4 different usb files numbered 1-4. If so u can edit the one file on each to dvd instead of usb. I'm sure someone else on here knows how to do that.
      09-26-2018, 12:31 AM   #11
Danneh
Drives: 2015 BMW 328i GT
Hello.
Hello.
When I updated the maps in my '15 F34, I formatted the USB drive to FAT32 using this tool http://www.ridgecrop.demon.co.uk/guiformat.exe
Then I copied the updated map files and ran the update after entering the FSC code.
      09-26-2018, 02:56 AM   #12
Eschmacher
Car Hypochondriac
Eschmacher's Avatar
2014 BMW 335i  [0.00]
Thinking out loud - fat32 technically supports a maximum partition size of 32GB, hence the name. You can make it work on larger disks, but it tends to act weird. Grab a 32GB usb and try that instead, OP.
      10-04-2018, 09:58 AM   #13
Skeeco
Skeeco's Avatar
Croatia
Drives: F30 318d
@Danneh: I've returned the USB drive to seller and I'm waiting for a new one. If it still won't work I'll try reformatting with program you've recommended
@Eschmacher: Yeah, that sounds good, in theory, but maps won't fit on 32gb usb
      10-29-2018, 11:35 AM   #14
Skeeco
Skeeco's Avatar
Croatia
Drives: F30 318d
Ok, so.. if anyone wondered, or experiences the same problem, the problem was faulty usb drive..
      12-31-2018, 08:58 AM   #15
kkbg
Drives: f11
what format is your USB stick? I dont know if my bmw can read ntfs format ...
