BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Headlight 0 setting with engine running
      09-21-2018, 09:13 AM   #1
bimmer456
Drives: 340i
So this seems to activate angel eyes in bright setting at night at least. Seems brighter than auto setting. What is your experience?
      09-21-2018, 10:10 AM   #2
supermarket
Drives: 2018 340xi, 1996 328iS
This is normal. The car has different brightness settings for the corona rings to be used when the headlights and parking lights are off (position 0), when just the parking lights are on (position 1), and when the headlights are on (position 2).
At position 0 (lights off), the corona rings serve as the daytime running lights, so they’re lit more brightly.
At positions 1 and 2, with various other lights on, DRLs are no longer needed, and the corona rings serve more of an aesthetic purpose than a functional one. They dim accordingly.
The brightness settings are codeable. If you’re into coding, see:
Code:
FEM_BODY/3062/MAPPING_{TAGFAHRL,PARKL,STANDL}_V_{L,R}_PWM_LEVEL_1
      11-04-2018, 10:18 AM   #3
ovsa
Drives: 2014 328i xdrive
following
      11-04-2018, 11:03 AM   #4
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Drives: '13 328i Msport 6MT
With Bimmercode you can code them to be 100% brightness when the low beams come on
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
