BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 Projector Angel Eye Headlights!
      09-27-2018, 09:04 PM   #1849
jlorenzo125
Drives: 320i Sportline
Originally Posted by jdrew View Post
So.....if I want the halo ring/angel eye look I go with depo units (or equivalent) and then get good bulbs. If I just want to be able to drive at night I can just get good bulbs.
Can I ask what LED did you have?
I don't remmeber which specific bulbs I had, but I do know I purchased them from ijdmtoy.com since they have bulbs listed as can-bus error free. Just find out what bulbs are needed for our cars and find them there.
      09-28-2018, 09:15 PM   #1850
Righter13
Drives: F31 gray metallic diesel
Originally Posted by akhent0n View Post
I will receive my DEPO angel eyes tomorrow and I think I will go with the HID option for the bulbs. I did a lot of research and ended up with that:
HID Parts
H7 HID Adapter : https://www.theretrofitsource.com/h7...ros-49083.html 10$
H7 Morimoto HID Bulb: https://www.theretrofitsource.com/hi...to-xb-hid.html 40$
H7 35W Canbus: https://www.theretrofitsource.com/ba...anbus-35w.html 90$
Total: 150$
I’m correcting in assuming I’d need two of each of the above?
      09-29-2018, 07:39 AM   #1851
akhenat0n
Drives: BMW 320i 2014
No, it comes as a pair. Only one of each.
I received the DEPO lights yesterday, it shipped in 2 days (California to Montreal, Canada) I'm shocked !!! Can't wait to receive the HIDs and install the headlights!
      10-01-2018, 07:14 AM   #1852
BMWF30PGH
BMWF30PGH's Avatar
Drives: 2016 320i xDrive
LCI with Depo Headlights
I decided to purchase the Depo headlights for my 2016 320 LCI. I was holding out until the LCI equivalent Depo lights were released but decided to purchase these instead due to the fact that they have been out for a few years and the cost is more than reasonable. I had already turned off warm and cold checks for my headlights. Everything else was essentially plug and play. Since the plug for the headlight housing is on the opposite side I had to loosen some of the tape and clips to make it work. I did manage to do the job without taking off my wheels or wheel liners. Bumper removal was simple; headlight removal was mostly simple except for the one bolt underneath the headlight that is closer to the center of the car. After I mounted the first headlight, I attempted to put the bumper cover back on and it did not line up correctly. It took a few tries to get the headlights lined up and a few additional washers helped. Leaving the old headlight in place while lining up the new headlight helps. Here are a few pics of the before and after.
OLD:
NEW:
      10-01-2018, 07:53 AM   #1853
dashBMW
Drives: BMW F30
I am planning to order the same, quick question do you see any difference in nighttime visibility on stock depo halogen ? or we need to install HID/ LED to increase it?
      10-01-2018, 08:17 AM   #1854
jlorenzo125
I can say I deffinetlty do. Maybe because the beam is more focused?. The bulbs I use are GP Thunder 5800K Super Bright White H7 halogen Bulb, I'm sure an error free led would be better.
      10-01-2018, 08:34 AM   #1855
BMWF30PGH
BMWF30PGH's Avatar
I went with H7 Auxbeam F-T1 and so far they look great. I did not want to go back to halogen. I had LED in my halogen reflectors, they were ok but always lacked. The projector in the Depo is much improved over the halogen reflector.
      10-01-2018, 08:38 AM   #1856
dashBMW
Drives: BMW F30
Awesome, Are this LED direct fit in Depo headlights? plug and play?
      10-01-2018, 09:49 AM   #1857
BMWF30PGH
BMWF30PGH's Avatar
These were plug and play, they just needed the adapter. This is what I purchased.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      10-01-2018, 10:40 AM   #1858
dashBMW
Drives: BMW F30
Thank you very much for the link, last question the Base Holders Adapters which size did you order KP-101? what was the size?
      10-01-2018, 02:38 PM   #1859
BMWF30PGH
BMWF30PGH's Avatar
I purchased the KP-101. They looked the closest to my existing clips.
      10-11-2018, 11:21 AM   #1860
F80_Ho
F80_Ho's Avatar
Drives: 2017 F80 M3 Competition
Just Ordered These
Just ordered these for my 2013 328i. I opted for the H7 Super White Halogen Bulbs. I will post before and after pictures soon, as well as how long they took to arrive.
      10-14-2018, 04:34 PM   #1861
ithk21620
Drives: 2013 328i X-Drive
How are the cutoff lines with these LED's? Do you have any pictures of the lights at night with these? I have my Depo's coming and I need to decide what way I want to go with the bulbs. LED or HID
      10-15-2018, 08:13 AM   #1862
QuikSilver_
QuikSilver_'s Avatar
Drives: 2016 F36 M Sport
Hi All,
I'm looking at getting these DEPO headlights for my '15 320i. Since they don't have a pre-installed HID option, I'm going with an HID conversion kit from HID Nation, which includes:
55 watt slim ballast (AC/Digital)
Error/Warning cancelers
Relay Harness
and of course the 6000k bulbs
Will I need to do some coding for any of this? I've only ever replaced the turn signal bulbs with LED's on my previous BMW and I coded out the warm/cold checks for that. I'm assuming I won't need to do that with the error/warning cancelers and relay harness?
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
      10-22-2018, 01:21 PM   #1863
andyt26
Drives: 2015 BMW 335i Msport
Can everyone take a pic of their beam pattern? Been running these lights since July and the thing that bothers me most about them is the ugly beam pattern. Any suggestions on how to make them more aligned would be appreciated. I’ve looked at all tutorials and still can’t get the beam pattern right.
      10-22-2018, 08:15 PM   #1864
Craven_01
Drives: 2013 F30
Adjust your bulb position and align your headlights. That's all you can do. You won't be able to eliminate the "divot" in the beam cut off. I've been down this road with USR. Their response to my many emails about the beam pattern is "there is no way around that as that part on the edges is a result of the Bi Xenon Internal Shutter which lifts that causes the output on the end." Tried pursuing the issue with USR but no response. Good luck!
      10-23-2018, 08:45 AM   #1865
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Originally Posted by Craven_01 View Post
Adjust your bulb position and align your headlights. That's all you can do. You won't be able to eliminate the "divot" in the beam output. I've been down this road with USR. Their response to my many emails about the beam pattern is "there is no way around that as that part on the edges is a result of the Bi Xenon Internal Shutter which lifts that causes the output on the end." Tried pursuing the issue with USR but no response. Good luck!
They can't do anything about it because it's U.S. law and presumably similar in other countries.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      10-23-2018, 12:47 PM   #1866
Craven_01
Drives: 2013 F30
I understand it's the law but the beam cut off line of USR headlight is horrible. The internal shutter of USR headlights causes two steps in the beam cut off. It's a poor design. Below is an example of how a clean cut off line should like.
      10-23-2018, 12:52 PM   #1867
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
That's unfortunate. Mine is only a single vs. your double.
      10-23-2018, 01:30 PM   #1868
Craven_01
Drives: 2013 F30
There's quite a few of us having the same problem with the beam cut off. Would you post a picture of your beam cut off up close and from a distance. What bulbs do you have installed?
      10-23-2018, 03:57 PM   #1869
F80_Ho
F80_Ho's Avatar
Just had a local shop install them today They arrived in about 5 business days, no problems or issues. Plug and play. They look awesome! Very satisfied.
      10-23-2018, 04:28 PM   #1870
QuikSilver_
They look awesome!! Very nice! How much did the shop charge to install them? Mine are arriving tomorrow. Wondering if I should go that route.
