10-23-2018, 05:57 PM | #1871 | |
Rep 614
Drives: 2016 F36 M Sport
Also, do you know what the difference is between the H7A bulbs and H7B?
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
10-23-2018, 11:46 PM | #1872 | |
Rep 46
QuikSilver_174.50 |
10-24-2018, 02:45 PM | #1873 | |
Rep 129
Would you post a picture of the beam cut off? Last edited by Craven_01; 10-24-2018 at 04:11 PM.. |
10-26-2018, 11:46 AM | #1874 |
Rep 129
10-26-2018, 03:51 PM | #1875 | |
Rep 2,382
View post on imgur.com This is the only one I have right now. Not the best photo but you can I see I just have the one cutoff vs. two.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
10-26-2018, 08:12 PM | #1876 | ||
Rep 129
10-27-2018, 08:34 AM | #1877 | ||
Rep 577
Light output is way better than the Halogens. I'm still tweaking the alignment because I think the point of the cutoff is to have both cut outs match at a certain distance for incoming traffic. I'm setting that match point at about 50 yards. I parked in a level parking garage at one end and adjusted the beams so the notches were over each other on a wall about 50 yards away. It's not great, but they're not bad either, especially with the better output from the HID's. |
10-29-2018, 09:12 AM | #1878 | |
Rep 2,382
10-29-2018, 05:33 PM | #1880 |
Rep 614
Ok stupid question. Just got my HID kit from TRS. How the heck do I get the adapter on the bulb?? It goes behind the bulb right? Do I need to slide the H7 socket out of the grommet to slide the bulb wires through the adapter?
10-29-2018, 05:40 PM | #1881 |
Rep 129
10-29-2018, 05:45 PM | #1882 |
Rep 614
I just got the Depo headlights and Morimoto H7 HID bulbs. Trying to swap out the halogen bulbs the new headlights came with, with the HID’s, before I install this weekend. But can’t figure out how to get the adapter on
10-29-2018, 06:04 PM | #1883 | |
Rep 129
I backed out the screws a little to make it easier. It's all trial and error. |
10-30-2018, 08:53 AM | #1884 |
Rep 2,382
11-02-2018, 04:43 PM | #1886 |
Rep 35
Edit: I wasn't thinking that the projector will flip the light
However if you look at the cutoff you will see a tiny imperfection and I think that is what is causing a lot of the grief with everyone and the cutoff line. I have some time before I will be installing them so I may try to take a file and lightly take that extra notch off and flatten the line out some. Just not sure I want to risk messing up $600 lights. Original: So I finally got time to open the box for my Depo lights and I decided to take a look at the infamous cutoff line inside the projector. Isn't the cut off line supposed to be on the top? Mine is installed on the bottom and I am afraid I have some defective units. Anyone else have this issue?? |
11-04-2018, 02:02 PM | #1887 | |
Rep 129
https://www.theretrofitsource.com/bl...id-projectors/ |
11-04-2018, 08:08 PM | #1888 | ||
Rep 35
11-04-2018, 09:57 PM | #1889 | ||||||
Rep 129
11-05-2018, 06:37 AM | #1890 | |||||||
Rep 35
11-05-2018, 07:52 AM | #1891 | ||||||||
Rep 129
11-05-2018, 07:56 AM | #1892 |
Rep 35
Here is the cutoff line up close when using a flashlight. And also a better picture of the actual cutoff piece. The cutoff piece isn't very sturdy inside so I'm not sure how well this is going to go...
