BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Robbing the F8x M3 M4 for suspension parts
      01-15-2019, 05:43 PM   #133
52172
52172's Avatar
Drives: 2015 Bronze Metallic 335i
I got a quote for four custom spacers for about 300 dollars! Gonna go with the summit racing aluminum ones. How are those working out btw?
      01-15-2019, 07:23 PM   #134
MacklinUSOB
Drives: f30 328i 6MT Sport
Originally Posted by mose121 View Post
Originally Posted by MacklinUSOB View Post
So I have my car in the shop as I write this and I just got off the phone with them. While they haven't reported any issues as far as rubbing goes, my foreman was concerned with the extension of the tie rod ends and that they are very close to the end of adjustment to compensate for all the toe these add. He is estimating 1/4" on the threads where toe is true again and suggests this might not be exactly safe...
My question is, has anyone here ran into any issues with their tie rods in conjuncture with this upgrade?
I have done some searching across the board and I can't seem to find anyone even hinting at their tie rod arms not successfully accommodating the excess toe compensation. Thanks in advance.
Edit: Zero problems, please disregard. Hope this info helps others.
Anything ever come of this issue?
Not a thing. After over 10k miles, several track days, and a few pothole hits I put it in for a post-season inspection. The same foreman who raised those concerns said the front end was solid.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines |
Past: E36 328is & E38 740i
      02-17-2019, 03:17 PM   #135
Polo08816
Drives: 2014 335i M Sport
Originally Posted by 52172 View Post
What are the ideal spacer sizes? I was gonna source stainless spacers 1.5” od .5” id two 15mm wide and 2 2mm’s wide? These are the correct sizes I believe? Thanks
Anyone find a good place to procure these washers? Any luck with a nearby Home Depot, Lowes, or Ace Hardware?
      02-17-2019, 03:25 PM   #136
52172
52172's Avatar
Summit racing aluminum ones are inexpensive
      02-17-2019, 08:01 PM   #137
Polo08816
Would you happen to have a link or item number to the exact one you used?
      02-19-2019, 05:00 AM   #138
Polo08816
Not many places have a washer that's 1mm in thickness.
      02-24-2019, 03:19 PM   #139
jbiswurm
Drives: F30 335i msport 6mt
I have the f80 lcas installed and the turn in is awesome and understeer basically gone.
I am stuck between f80 TSs and pressing Turner monoballs into my stock TSs. conflicting opinions on if the F80 TS does push the wheel back to center of the wheel well or not.
anyone have a recommendation on which option to take?
sspade2464.50
VAF3025.50
      02-24-2019, 03:55 PM   #140
Polo08816
I would like to know as well.
VAF3025.50
      04-01-2019, 10:10 AM   #141
Polo08816
https://www.grainger.com/product/GRA...-1-2-O-D-4ARX6
This is the closest I've been able to find. It's a hair thicker than 1mm.
      04-30-2019, 06:07 AM   #142
Littlebear
Drives: ...the Mods crazy.
Hello BMW Experts!
My only problem with putting in the M3/4 LCA is the small amount of screw left on the tie rod adjusters. Various people & venders (Bird, Turner, ECS) say 'no worries!', but I don't really like lots of toe-in for my front tires, just a little.
Do any of you muggs who have done this LCA change know your front toe-in, or if your alignment guy put you in the 'more toe' part of the allowed range in order to get the tie rod screw further in? Or, are any of you running in the 'less toe than median' of the allowed range?
Clear as mud?
Murf
      04-30-2019, 08:42 AM   #143
Polo08816
Originally Posted by Littlebear View Post
Hello BMW Experts!
Do any of you muggs who have done this LCA change know your front toe-in, or if your alignment guy put you in the 'more toe' part of the allowed range in order to get the tie rod screw in further in? Or, are any of you running in the more 'less toe' allowed range?
Clear as mud?
Murf
So would someone need shorter tie rod adjuster or longer tie rod adjusters as a result of this modification?
      04-30-2019, 08:58 AM   #144
Littlebear
A little more would be nice!
Murf
      05-03-2019, 06:08 AM   #145
Littlebear
My guy aligned me right down the middle of specs: 0.11
Toe spec is 0.08 to 0.15 for my '17 330i.
Murf
      05-08-2019, 09:11 AM   #146
Littlebear
Hello BMW Experts!
I now have the M3/4 LCAs in. Previously, I had them in, but took them out.
I was not getting proper self centering the first time I put the M3 LCAs in. The steering would not fully center after some turns, and I had to complete the centering myself. This did not inspire confidence.
But that was last time. This time I went to an expert alignment shop, and the car feels great (this after getting an alignment characterized as, "looking like Ray Charles did it", by a Forum member, at the other shop). The centering is improved (from more caster?), & the turn-in is sharper. I bet that when I take it to the mountains, the front won't scrub as much either!
"My name is LittleBear (or Murf or Tom or...), and I now approve of this mod!"
Murf
      05-08-2019, 09:30 AM   #147
MacklinUSOB
My tension strut bushings started giving up on me so I installed the F80 TS with the aluminum spacers from Summit Racing. It did push the wheel back roughly half of the way. When you're ready to touch the tension struts I'd go for the F80 arms. If you still wanted a monoball kit you could press in the F30 spec ones and forget about spacers.
More info in this thread.
https://www.bimmerpost.com/forums/sh...php?p=24686879
      05-12-2019, 02:41 PM   #148
tomppa
Belgium
Drives: 6
Originally Posted by Lancelot View Post
You can increase neg camber by 0.5° using an alternative wheelhub instead of these arms:
http://www.realoem.com/bmw/enUS/show...diagId=31_0994
Part #31216856535 / 31216856536 are compatible with X Drive
I have no idea what the complexity of installation is though.
Is this the whole hub? RealOem talks about the pivot bearing and camber correction kit. Eccentric bearing? Shims to correct camber?
I would be willing to try but if it's the whole hub, I'm afraid it will be too expensive. Pre-owned part might be an option but how can you tell if a vehicle has an -30, +30 or 0?
      05-13-2019, 05:34 PM   #149
Polo08816
Can you send the link for the specific Summit Racing spacers/washers you used?
      05-13-2019, 05:35 PM   #150
Polo08816
Each of those correction part numbers is actually a different whole new hub. I bought used ones from DVC .
      05-13-2019, 07:44 PM   #151
MacklinUSOB
Here they are
http://www.summitracing.com/parts/KYS-100-377-3
http://www.summitracing.com/parts/KYS-100-377-1
      05-15-2019, 01:27 PM   #152
Polo08816
Hrm. That's a bit confusing. The picture of the item on Summit Racing makes it seem like it's a set of spacers that you are getting but the description seems to indicate that it's just one spacer.
So they need to be .25 inches (or ~6.36mm) and .50 inches (~12.7mm) thick. Are you sure that's the correct thickness?
I recall reading that people were using spacers around 1mm thick on the 2 Series forums.
      05-15-2019, 02:06 PM   #153
MacklinUSOB
These are the exact spacers used by many in the thread I linked earlier for TS installation. I suggest reading through that one.
Each item is just one spacer, the product picture is the entire KYS-100-377 lineup. 1 and 3 are the ones you are purchasing.
Some people have used 1mm spacers on the LCA, I haven't and haven't had issue.
      05-15-2019, 02:09 PM   #154
Polo08816
So the spacers you are using are, indeed, significantly thicker than the 1mm spacers used on the LCA.
