04-03-2018, 08:54 AM | #1651 |
Rep 2,382
Yes, it is. They dim typically when you put the low beams on.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
04-03-2018, 09:01 AM | #1652 |
Rep 9
Hi Guys, I'm new to the forum and didn't want to make a new thread - I'm sorry if this is posted in the wrong area.
I've recently purchased the DEPO headlights from Eurowagens; along with Osram Cool Blue Intense & Chrome indicator bulbs. ( I also purchased the Osram Laser bulbs too ) After reading a few threads and some Instagram posts regarding the lights, I have come to the conclusion that I'm missing something. I presumed that fitting these lights were as simple as plugging in the bulbs and that's done, but I'm reading a lot of posts regarding fitting a6000k white hid xenon conversion kit ect. I presume then, that my bulbs will not suffice in gaining the look that I'm after. [Please see picture 2 of this instagram post; https://www.instagram.com/p/Bg_6p-eF...n-by=auto_modz ] It also seems to me, that sometimes the 'inner' ring is left without a bulb, but when looking at some other photographs, bulbs seem to be present? Any help somebody could give a Newby like me some help in this matter, would be greatfuly appreciated. Thanks, JonnyB Last edited by 4sXdmk9snW; 04-03-2018 at 09:02 AM.. Reason: Wrong Link |
04-03-2018, 09:14 AM | #1653 | |
Rep 2,382
04-03-2018, 09:24 AM | #1654 | |
Rep 9
Thanks very much for your prompt reply! As I'm in England, I presume the bulbs will be the same as you bought? Would it be possible to send me a link for the kit you bought so that I can buy these before I fit the lights? Regarding leaving bulbs out of the high beams, is this allowed? As I've seen many people leave them out. |
04-03-2018, 09:39 AM | #1655 | |
Rep 2,382
04-03-2018, 10:53 AM | #1656 |
Rep 31
Anyone know how to fix the dreaded “turn signal malfunction” ? My left side recently stopped working. I’ve changed the bulb and got a new bulb socket holder and still no luck.
04-03-2018, 11:14 AM | #1657 |
Rep 2,382
Strange that a new a bulb holder didn't fix it. Is this brand new or a used one from somewhere else? Try pulling the contacts on the inside of the holder out some and put it back in. Contacts where the bulb sits. If you did that or it doesn't work, it could be a wiring issue.
04-03-2018, 11:14 AM | #1658 |
Rep 4,031
Check out YouTube for Kies Motorsports Bryan has done a video on it.
2012 BMW 328i E93 | Deep Sea Blue Metallic - 2015 BMW 328i F31 MSport Sports Wagon | Alpine White - BMW CCA DelVal
04-03-2018, 11:39 AM | #1659 | |
Rep 13
04-03-2018, 12:42 PM | #1660 |
Rep 27
I installed these on my facelift F30. Everything works execpt we can’t get the angel eyes to stay on at the same time as low beam! Anyone had this issue? How do I fix this? Can I code the angel eyes i.e. DRLs to stay on with low beam? Or do I need to re-wire? Thanks
04-03-2018, 12:44 PM | #1661 | |
Rep 2,382
04-03-2018, 12:56 PM | #1663 |
Rep 2,382
Did you check the "lighting" section under options?
04-03-2018, 01:00 PM | #1665 |
Rep 2,382
Oh, that's right. It's disabled on cars in the EU. You can code the option back in, but I don't think that'd help you. I'd go make a post in the "Coding" section of the forums. I'm sure there is a parameter for it and someone in the EU has done it.
04-03-2018, 01:04 PM | #1666 |
Rep 27
Ok will do thanks.
Do you think coding will help though? Im confident that my angel eyes are replicating the ugly stock LED DRL strips. Even on auto when it goes dark the angel eyes turn off and low beam comes on (exactly how it was when I had halogen headlights) |
04-03-2018, 01:12 PM | #1667 |
Rep 2,382
My assessment would be yes. I doubt there is any major differences if any between our modules aside from coding. Mine stay on with or without the lowbeams on. Now that I think about it, I'm curious if your brightness for the option "With low beams on" is just set to 0%?
04-03-2018, 01:19 PM | #1668 | |
Rep 2,382
Cheatsheet to help out.
04-03-2018, 02:19 PM | #1669 |
Rep 4,031
FYI Depo's will be back in stock 4/4/18.
Use EGTDP2014 for 10% off
04-03-2018, 02:35 PM | #1670 | |
Rep 27
04-03-2018, 09:29 PM | #1671 |
Rep 92
Hmm. My rings still dim when the low beams are on. I used bimmercode... not sure if I'm overlooking something? Do they still dim, just not as much?
F30 328i Mineral Grey Metallic, M Perf Kit, M Perf Exhaust, Matte Black Kidney Grills, H&R Sport Springs, 19" Velgen VMB5 Rims.
04-03-2018, 10:00 PM | #1672 |
Rep 2,382
Hmm. I'll have to take a look when I get a chance and see if it's a huge difference.
