BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Confirm oil quantity?
      04-08-2013, 12:23 AM   #1
momo3605
Drives: M340i LCI, 718 GTS 4.0
I went to the dealership to pick up the oil filter, and they were adamant that the car takes 7 quarts. That has to be wrong...I think I've seen 5 in the forum. Can someone just confirm real fast if it needs 5 or 7?
      04-08-2013, 06:47 AM   #2
jwilly
Drives: They're all white now.
Five.
Joel
That's a lot of white
      04-08-2013, 12:10 PM   #3
Frogman
Drives: 2012 F30 328i
I've had my oil changed twice and both times that said they used 7 quarts.
      04-08-2013, 04:01 PM   #4
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
I changed my own oil (335i) and it was just a tad over 6.5 qts
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      04-08-2013, 09:19 PM   #5
momo3605
So again I'm getting 5 and 7 hah...well if a 335i takes 6.5 then there is no way a 328i takes 7qts.
      04-09-2013, 01:27 AM   #6
EclipseDS
Drives: Black Sapphire 328i
328i takes 5qts. I changed oil recently and put in 5qts, similar quantity drained from the engine. Oil measurement indicates it at max level. If the max was 7, car would definitely complain about it
      04-09-2013, 10:06 AM   #7
finaloption
finaloption's Avatar
Drives: '13 f30 n26
looks like you got overcharged for 4 qts
      04-10-2013, 03:48 AM   #8
momo3605
That's so strange. Putting 7 quarts when the engine takes 5 would definitely be bad for the engine. I can't imagine how often dealers are messing up 328 engines cuz of this
      04-11-2013, 03:12 PM   #9
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
it's 7 quarts!!
SOLD: 2012 335i Mineral Gray
      04-11-2013, 03:40 PM   #10
finaloption
Drives: '13 f30 n26
Originally Posted by shivaswrath View Post
it's 7 quarts!!
yes, for your n55.. not the n20/n26 like the OP has..
      04-11-2013, 03:46 PM   #11
shivaswrath
Drives: 2012 335i
oops, sorry, should've read for engine type...lol the dealer would've figure it out one way or the other when the oil spilled on the ground..
      04-11-2013, 03:48 PM   #12
finaloption
Drives: '13 f30 n26
s'all good my theory is that 7 qts is so embedded into their brains that they forget the n20/n26 is a 4 banger
