BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - California > FS: N55 PWGPS2, DP, Intake, PI kit, PR coils, IC
      01-17-2022, 02:03 PM   #1
madrrio
Capable
madrrio's Avatar
Drives: 335i m sport
Hello all,
Recently started to part out. I will have more parts coming down the road (likely Ohlin R&T coils and HRE wheels w new ps4s). Knocking 30 percent off the price clear across unless something wrong with the parts, and no need to trade your stock parts.
https://drive.google.com/drive/folde...UP?usp=sharing
Pure turbo for 2013 PWG N55. $2000. Comes with GFB+ installed, turbo has maybe 15k mainly from driving to and from work. No shaft play, and everything is in working order. left on the manifold. I do not need an exchange/core so that saves a good amount of money. Comes with the inlet pipe and will include a turbo to intercooler pipe as well.
Wagner Evo comp 2 Intercooler. Black $550. See photos, fins are in good condition and i will clean it prior to pick up. These are all fresh of the car photos. Thing kept air cool like a champ, even running 22 lbs.
Fuel-it Port injection kit, split second controller, and new set of 550 injectors. $1000. Comes with hardware required, worked good with 100 percent ethanol but including new injectors to relieve any concern.
ER Downpipe. $300 Has been coated black hi temp ceramic by myself to maintain stealth look.
BMS Intake, blue 160.
BMS Catch can. 100. a little scratched but everything there.
Other parts not in the drive, Light single mass flywheel and stage 3+ clutch from Spec. About 10k on it. It'll handle all the power, but man its grippy. might be best to pair this with a steel single mass instead of aluminum. You can take it all for 500.
Will try to check this thread daily, Thanks for looking.
      01-20-2022, 12:18 PM   #2
funker840
Drives: 2013 N55 PWG AH3
Is the ER downpipe catted or catless?
      01-28-2022, 03:18 AM   #3
madrrio
Capable
madrrio's Avatar
catless, please see photos
      01-28-2022, 08:50 PM   #4
GAB0
Drives: F30 335i Msport
Which version of the PS2? Is it their newest blade design?
      01-29-2022, 07:37 PM   #5
madrrio
Capable
madrrio's Avatar
I do not believe its their newest blade design, I've had the kit a while, just didn't drive the car a lot.
      01-29-2022, 10:01 PM   #6
Logicoeur
Logicoeur's Avatar
991
Drives: F30 335i xDrive
Rwd?
      01-30-2022, 07:47 PM   #7
madrrio
Capable
madrrio's Avatar
rwd
      02-06-2022, 01:54 AM   #8
minty335i
Drives: ‘12 e92
What is the model number and specs on the HRE wheels? I’m in the market..
      02-07-2022, 02:34 PM   #9
madrrio
Capable
madrrio's Avatar
ff01, ipa, f30 fitment... believe its 19" 19x8.5 +30, 19x10 +40
on ps4's pretty new all around.
      02-09-2022, 01:39 AM   #10
minty335i
Drives: ‘12 e92
I personally love those for the Fseries but I’m not too crazy about how they’d look on my e92. beautiful wheels nonetheless, glws!
      02-10-2022, 01:30 PM   #11
madrrio
Capable
madrrio's Avatar
I completely understand, thanks!
