06-24-2020, 01:57 AM | #1 |
Rep 36
Electrical What? I'm confused
Evening Gents,
To start off I love my F30!! I do need the communities input/suggestion on an issue that I have been experiencing. (Yes I tried looking but didn't find anything) I have to press lock/unlock and the engine start/stop button multiple times before the car will recognize the key fob in the car. Sometimes the right low beam headlight will not come on. Here are my mods:
I'm pretty confident the issue with the key fob is the aftermarket puddle lights. I have removed them for one week and the car worked like a dream than the car decided to start having the issues the right low beam comes on when it wants to so I installed the puddle lights back in. I have had all of these modifications running perfectly fine for the last 2 yrs and than one day it just started acting up. I do use Carly to code some things out FYI. Has anyone been successful with using aftermarket puddle lights? |
06-24-2020, 01:28 PM | #3 | |
Rep 36
Also I figured out the headlight issue... The ballast was intermittently failing.. It went completely out today. |
06-24-2020, 02:36 PM | #4 |
Rep 16,140
I don't know. Mine never caused any problem, so I never had a reason to investigate it. I'm just aware that it happens by the experience of others.
06-24-2020, 05:55 PM | #5 |
Rep 36
06-24-2020, 09:02 PM | #6 |
Rep 16,140
They're no longer being sold. You might find something similar. These differ from the usual in that they have an aluminum housing instead of plastic. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
06-29-2020, 11:32 PM | #7 |
Rep 14
This screams that there is a grounding issue with one of your add ons. If there is an intermittent short ( or insufficient resistance between power and ground) then that could interfere with the radio signals.
