09-27-2019, 08:19 PM | #265 | |
Rep 117
09-28-2019, 04:00 AM | #267 |
Rep 15,858
There will still be extra xDrive related transmission losses. Components are still there, weight, having to be driven, churning looses in the diff and transfer box.
Interesting to see some figures, you'd need to be running/rolling all four wheels to get any true figures. Not sure how you do that. We know acceleration times could be meaningless, as there is enough debate on sDrive vs. xDrive anyway, how each has an impact on the times. |
09-28-2019, 08:44 AM | #268 |
Rep 55
I've only seen one youtube video where they back to back dyno on an AWD dyno and then a RWD dyno with x-delete enabled. The difference was about 25hp greater on the RWD dyno.
2018 340i X-Drive | M-Sport | MPPSK | Dinan Intake
mcintoshf30184.00 |
09-28-2019, 08:49 AM | #269 |
Rep 529
The only true comparison test to see if there is any power/acceleration benefit would be for someone to get Dragy 100-200 (60-130) results back to back in identical conditions one with xdrive and one with xdelete.
Xdelete claims 30whp gains, that would be good for around 0.5sec in 100-200. If nobody can prove gains with actual street verified results then I think it's BS as far as claimed gains, but.... still might be worth the $200 to get improved steering feel, turn-in response and better fuel economy.
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
09-28-2019, 11:00 AM | #270 |
Rep 15,858
So what's happening to the front wheels during the RWD test? Figures mean very little if the front transmission is static. The drivetrain losses those components contribute once rolling, (they are not 'invisible' with a delete) must be calculated and subtracted, to get net gains.
09-28-2019, 12:11 PM | #271 | |
Rep 55
09-28-2019, 02:40 PM | #273 |
Rep 15,858
I understand where you are coming from. We are used to dyno figures. But as a standalone figure from xDelete, it doesn't tell the whole picture. Does make for a good headline.
09-28-2019, 03:25 PM | #274 |
Rep 252
Drives: 2017 Model S P100D
I flashed yesterday. Definitely like a whole new car. I forgot what it was like to lose traction when stepping on it in 2nd gear. I was laughing like a little kid with a bag of treats
09-28-2019, 10:22 PM | #275 |
Rep 288
Just flashed today and OH MY launch control is sooo different. Even with my 275's I'm spinning, before it would hook every time. It's a lot of fun though and I think i'll leave it in RWD until the first snow storm hits, want to enjoy the added fuel economy.
ali820272.50 |
09-29-2019, 03:18 AM | #276 |
Rep 15,858
Interested in reading what the real fuel savings will be. You continue to have the extra xDrive weight and are still accelerating all the additional rotating components (with their associated losses), compared with a straight RWD model. Even steady state losses will be very similar.
09-29-2019, 05:12 AM | #277 | |
Rep 2,674
09-29-2019, 09:17 AM | #278 | |
Rep 15,858
I'm feeling some are thinking there are HP gains, better economy, as if the drivetrain is running as a RWD model. I'm also not too sure about longevity, as I've already briefly posted on this thread. Does xDelete simply translate to the same disconnection/function of the M5? The transfer box is not the same design as the M5, with its switchable drive. As an engineer I know what is referenced, isn't the complete story. The dyno test and the gains in HP calculated by the run down cycle, excludes the front end of the drivetrain, which also accelerate and run down in real world driving. The figures can't be left out for calculating real world gains. Dyno figures in isolation can be misleading. I'm simply following with interest. |
Skyhigh1898.00 floridaorange10255.00 |
09-29-2019, 04:22 PM | #280 |
Rep 2,674
I flashed xDelete today - my traction control kept kicking in while in sport - how do I turn that off or is it only possible in sport+?
09-29-2019, 04:46 PM | #281 | |
Rep 290
09-29-2019, 04:51 PM | #282 |
Rep 2,674
Thanks - that never mattered until now 😂
BeerHerder250.50 |
09-29-2019, 05:11 PM | #283 |
Rep 2,674
Alright so I guess sport+ is the only way to be in sport and have traction control off (on my model) - I think the sport suspension goes away (I know that topic had been covered at nauseam) but most importantly to burnout all I had to do was be in sport+ and now it's worth every bit of $150 (so long as it doesn't mess up my car as our engineer friend has pointed out)... I definitely feel a boost in power as well - no question - I need a charge pipe lol. Total blast though - does make the car feel more aggressive and overall sportier!
09-30-2019, 01:13 AM | #284 |
Rep 3,885
Not sure what you mean about the suspension.
If (and only if) you have Adaptive suspension, it goes into sport mode when you go into Sport or Sport+. You can (no coding needed, iDrive setting available) disable it switching in Sport to have it in its comfort setting. Not in Sport+ however, it is always set to sport there.
09-30-2019, 04:16 AM | #286 |
Rep 15,858
