09-29-2021, 07:06 AM | #45 |
Rep 173
Having had to live without any charging facility whilst I wait for a replacement 330e charger, I've mainly been in Eco-Pro most of the time.
Reason is that in the 330e, the comfort mode also aggressively recharges the battery up to 15% max. So for those first few miles the economy tanks, after that it's quite normal. Eco Pro on the other hand leaves the battery alone so you immediately get 'normal' efficiency. It's not doing too bad so far, I'm on target to get 400 (or slightly more) out of a 40L tank. New charging cable comes today, so hopefully I can make the rest of the tank stretch out for another week to let the panic buying pass by!
___________
F30 330e SE 2017 Previously Audi A3 S Line Cab, F30 320d Luxury, E90 318d SE |
09-30-2021, 03:08 AM | #46 |
Rep 34
I drive round in Eco Pro most of the time. Gets quite addictive seeing the extra miles increasing as you drive more eco friendly
If I need to overtake, I knock the gearbox over to sport and it takes off quickly :-) |
09-30-2021, 04:35 AM | #48 |
Rep 289
Is eco-pro more effective on petrol or diesel engines?
I haven't found much difference with my diesel on a regular 200-mile motorway journey comparing eco pro and comfort, I reckon there is a mpg gain of around 3% with eco-pro. |
09-30-2021, 05:36 AM | #49 |
Rep 808
I quite liked Eco with the Alpina gearbox map, but the problem is now I have XHP you can't reconfigure the shift points which is a shame.
I love the coast mode but the hills around where I live it's pretty useless as the car just runs away! |
09-30-2021, 05:49 AM | #50 | |
Rep 15,858
I've read several studies on the 'Efficiency' theme. Petrol vs. diesel savings depend on use. For example, a petrol benefits more from 'idle off' devices. A diesel usually benefits more from keeping the revs lower. It gets a bit complex of where the savings are the greatest. Latest engine designs confuse it even more. |
09-30-2021, 10:07 AM | #51 | |
Rep 3,862
And why would you need to, if you retain the stock ones?
09-30-2021, 01:05 PM | #52 | |
Rep 289
The main thing about eco-pro is the way it drops revs when cruising or going at a steady rate. I understand why, but it's unnerving when you try to accelerate, had a nasty incident last year which put me off. Rent a goat says pop it into comfort or sport before acceleration, but a bit of a faff, I'd rather take the hit and keep it in comfort or sport. |
09-30-2021, 01:49 PM | #53 | ||
Rep 3,862
09-30-2021, 05:27 PM | #54 | |
Rep 15,858
I do that in my 535i, even when I'm in Normal mode. It is the fastest way to wake up the transmission, for an over-take, if you have been trundling along in traffic flows. |
JR16641146.50 |
09-30-2021, 10:25 PM | #55 | |
Rep 861
Also, on my g30 the car assesses speed limits and upcoming roundabouts to make a decision on whether to coast or not. If you are doing 40mph and 300m from a roundabout and a 30 zone, the car recognises this and doesn't coast, since your speed needs to decrease and its more efficient to decrease speed using engine braking. Coasting is for situations where you would like to maintain speed on a decline. I use it for acceleration on long declines also, its great on Windy Hill on the M62. |
10-02-2021, 06:21 AM | #56 | |
Rep 70
Sounds like the BMW black box is a very clever box and it makes sense if your approaching a slower area it'll slow you down |
10-04-2021, 04:36 AM | #57 |
Rep 1,475
I'll be the first to admit that I don't really know how the Eco Pro system works, and I've never used it in local driving apart from when I've had zero range showing.
I did however, use it this weekend on a 378 mile round to Manchester. Ignoring local driving, according to Eco Pro I gained about 12miles of range. I don't know what percentage that would be as I don't know what basis I should calculate that off. I do know however, that my total range was extended from an average of 320miles to a full tank (local driving) to 435miles to a full tank. Now, this is completely unscientific, but in previous trips to Manchester of similar distance, I've had about the same range shown on my trip computer - around the 430miles and I've driven those miles in Comfort or Sport - not sure how much Eco Pro has actually contributed to overall range.
10-04-2021, 10:39 AM | #58 | |
Rep 289
Went up north last week in Comfort, 220 motorway miles, stuck to the speed limit, (with difficulty), and got an impressive 54mpg on the dial. Amazing for a 313bhp, 3 litre xdrive with an extra 250Kg, (because of the folding roof!) |
10-04-2021, 02:20 PM | #59 | |
Rep 222
cramsnik388.50 |
10-04-2021, 02:41 PM | #60 |
Rep 15,858
10-04-2021, 02:42 PM | #61 |
Rep 2,047
Using it on motorways with the occasional switch to sport+ if I'm going through a tunnel.
Motorway driving is boring and the drone from the downpipe with valves open gets a bit tedious. Most of my journeys are city driving - had a 1 hour motorway trip yesterday and fuel economy went from 19.4 all the way up to 19.3 mpg
440i GC with MPPSK, AP intake, 20" 624 M wheels, Wagner downpipe, Xhp stg 3, BM3 stg 2
instagram: f36_garage |
10-05-2021, 10:38 AM | #63 | |
Crustacean denier
389
Rep 578
10-05-2021, 11:42 AM | #64 |
Rep 289
So was I, mind you the dial always reads high. I keep a check on fuelly and after this run my fill up following it was 50.4 mpg that's my highest ever! Normal average is 38 mpg. I'd just filled up with motorway services, expensive fuel, so was taking it easy.
10-05-2021, 06:07 PM | #66 |
Rep 7,032
Drives: 335xd Msport +
In fairness I managed to get 50mpg out of my 335d a couple of times without busing eco pro. Usually in the 40s with mainly motorway driving at a steadyish 75- 80. Still think that’s pretty impressive with the available performance.
