11-05-2013, 09:45 AM | #4995 | |
Rep 9
11-05-2013, 06:10 PM | #4996 | |
Rep 41,058
11-05-2013, 06:12 PM | #4997 | |
Rep 41,058
The first thing I would do is call BMW Assist and give them your VIN / Account Number, and have them verify everything is correct on their side.
11-06-2013, 07:12 AM | #4998 |
Rep 9
Hindsight is 20/20....never checked between picking car up and coding. Will check with BMW. thanks!
11-06-2013, 02:20 PM | #4999 |
Rep 941
Anyone know what needs to be changed/coded to have the voice response with a British accent?
2019 M4CS Lime Rock Grey, MP HAS, GC camber plates, MPE
11-06-2013, 02:52 PM | #5000 |
Rep 114
I'm from Europe, before one week bought F30 in usa. I want to know, it's possible to code everything from USA standarts to EUR like farenheits to celsius, mph to kmh and other things?
11-07-2013, 04:55 PM | #5001 | |
Rep 41,058
However, I just don't follow the logic of your appeal. Since it is proven to work, and what you can change is well documented, there is nothing to "test".
11-08-2013, 07:36 AM | #5002 |
Rep 23
Please help !
I want to update the NBT with preserving the original VIN. Enjoyed here this instruction. Go to Comfort Mode => TAL-Calculating - Read and Save FA - Activate FA - Read and Save SVT Actual as SVT_ist - Create an SVT Target Under KIS / SVT Target Calculation Strategy, select Complete Flash Select I-Step (shipm.) to match your original I-Level as read and shown in VCM I-Step (Shipment) I-Step (target.) will be unselectable as it is fixed based on current PSdZData I-Level Do a KIS / SVT Target Calculation and Save as SVT_soll - Do a TAL Calculation and Save as SVT_tal Go to Expert Mode => TAL-Processing Load TAL (SVT_tal) Load SVT Target (SVT_soll) Select "Read FA" button. On ECU Tab, uncheck let top box in column "All" (All checked boxes should toggle to unchecked) On ID Base Row for HU_NBT, make check boxes in blFlash, swDeploy, cdDeploy, and ibaDeploy columns. Press Check software availability Press Start and it will proceed with processing TAL to flash HU_NBT with new firmware. But that's got this error: |
11-08-2013, 08:26 AM | #5003 | |
Rep 41,058
When you say you want to preserve the VIN, I assume this is a retofitted NBT Head Unit, and you are trying to keep the original Donor VIN in it which is different then the car VIN?
11-08-2013, 09:49 AM | #5004 |
Rep 23
11-08-2013, 11:06 AM | #5006 |
Rep 41,058
So, specify Donor VIN to be used during Flash, and Uncheck these boxes before flashing:
11-08-2013, 11:10 AM | #5007 | |
Rep 41,058
http://www.f30post.com/forums/showpo...postcount=1403
11-08-2013, 11:46 AM | #5008 | ||
Rep 218
My last istep was F020-11-11-504 |
11-08-2013, 11:56 AM | #5009 | |
Rep 23
11-08-2013, 10:11 PM | #5010 |
Rep 41,058
PM sent.
11-08-2013, 10:46 PM | #5011 | ||
Rep 23
11-09-2013, 04:48 AM | #5012 |
135 to 335 M Sport to X3 30d M Sport
164
Rep 1,788
Drives: 2018 X3 30d, optioned up!
Hi Shawn,
I installed everything today, being E-Sys v3.23.4 and PSdZData 50.4, copied (and renamed) the patch files, copied the token into a new subdirectory and pointed E-Sys to the right file in the right directory, but when I click on 'Coding' in E-Sys, I get the following error: EstCmDocumentCorruptException: Error during base64 decoding of EST token! __________________________________________________ ___ com.bmw.esys.commons.exception.EsysException: An error occurred while processing the EST file "C:\ESysData\E-Sys EST\xxxxxxxx-esys.est". See details for more information. [C157] Any ideas?
2018 X3 30d, Carbon Black Metallic, M Sport Package, Panorama glass sunroof, Lumbar support, Instrument panel in Sensatec, Ambient Lightning, Harmon Kardon Surround Sound , Dynamic Damper Control
11-09-2013, 07:54 AM | #5013 |
Rep 41,058
You must specify an FA to be used, and manually enter the Donor VIN like this:
11-09-2013, 07:58 AM | #5014 | |
Rep 41,058
11-09-2013, 08:24 AM | #5015 | |
164
Rep 1,788
I've emailed the source, asking if he knows what could cause the error, so I guess I'll have to wait Thanks...
