04-15-2020, 05:34 PM | #89 |
Rep 247
I did this in my F15. It really does sound good mids and highs sounded much better. Bass sounded tighter. BUT the really low end bass was just... gone? If I adjusted the eq, low end bass just couldn't get to where the HK system coding was.
I don't know how other cars are set up, but in the F15, there are speakers for the low end (sub 100 Hz?) under the front seats. I'm thinking that this may have neutered those speakers. It might be an improvement in those cars that don't have this separation of speakers? but I ended up reverting back to Harmon Kardon too. |
04-25-2020, 06:58 AM | #90 | |
Rep 30
I might have to add that i placed 6mm mdf rings between the underseat woofers and the housings, and added some damping wool in the housing which also cleaned up the bass a bit before i coded the amp. But the B&O and eq settings really made the difference for me. Now i only turned the fader 2 to the rear and 200hz to -2 and am very happy with the sound. |
04-30-2020, 06:05 PM | #92 |
Rep 177
I ordered my OBD2 bluetooth scanner and was thinking about Bimmercode and/or Bimmerlink. Would be really nice if this could be tried via one of those.
06-09-2020, 04:40 PM | #94 |
Rep 61
Anyone have any experience with the Bowers & Wilkins profiles? Do they seem to make any improvement? Everything I have found is just talking about the B&O settings.
06-13-2020, 01:45 AM | #95 | |
Rep 145
Drives: 2017 F31 330xi
07-27-2020, 03:07 PM | #96 |
Rep 749
Drives: F31 320d xDrive M Sport
I've just restored my EQ settings with Logic7 after doing more Bimmercoding a while ago (and forgetting to restore my changes again).
The sound is loads better, must have got used to terrible sound lol. But going to try coding this B&O in if the general consensus is that it's better than L7.
09-25-2020, 11:54 PM | #97 | |
Rep 67
The only differences generally between B&W and HK are: - central channel has separated mid and hi (they used empty 10th channel on amp to separate twitter from mid speaker) - since B&W has 1400watt it’s AMP is connected directly to battery instead of being connected to rear electrical module as HK - however electrical connection type is not related to sound producing - there is an additional mic over driver seat which checks noise level inside of car to make adjustments to sound on the fly - there is led module in a trunk which responsible to speaker grills led color - but this is not related to sound producing so can be neglected - DSP profiles are different, however on some HU HK Profile can be replaced to B&W - amp has 1400 watt output, while HK 600+. However it affects only max sound level and level clean from distortion. I actually plan to retrofit speakers from B&W for the beginning, maybe later will change the amp too. Amp is expensive, the cheapest used one is currently more than 1k $ Last edited by SniPro; 09-26-2020 at 12:06 AM.. |
J555568.50 |
09-26-2020, 05:07 AM | #98 | |
Rep 611
However, there are different versions of the amp (e.g. X7 has 20 active channels) and unlike HK that has two versions of tweeters (both the same, but one in bigger holder for dash), B&W has wider variety. That includes standard and super-expensive diamond versions (diamonds are used in the front doors) and wirings in quite many options -also different holders, with variety of wiring lengths, and some with resistors, some without. Unlike HK, the latter use direct wiring harness to the amp, while all HK tweeters are connected to mids and all have resistors. I did it, replaced all HK tweeters and mids with B&W. The improvement in every aspect is night and day compared to HK. In case of woofers decided to go aftermarket, as the B&W's - while much better than HK - do not meet my expectations (and still damn expensive). Last edited by J555; 09-26-2020 at 05:18 AM.. |
Samir72433.00 |
09-26-2020, 08:12 AM | #99 | |
Rep 67
Is there significant difference between B&W aluminum dome twitters and H&K twitters? They seem for me to be very similar. What actually changed after speakers replacement, could you please describe? Clarity, scene, volume level etc. |
09-26-2020, 08:33 AM | #100 | |
Rep 2,180
This thread is about coding, not about hardware differences.
J555568.50 |
09-26-2020, 08:34 AM | #101 | |
Rep 16,089
https://www.parts-express.com/dayton...ystem--390-792 But they don't. |
09-26-2020, 09:14 AM | #102 |
Rep 67
You are right, but one depends on another. The more similar from hardware perspective two “different” systems are, the more effect software change from opposite system will do.
I just tried to show that B&W coding can be potentially more effective than B&O on HK system |
09-26-2020, 12:25 PM | #103 | |
Rep 2,180
Just because you can code whatever MOST profile you find for a HK-hardware system and find it more rewarding to you only means that OEM speakers are being forced to play something that they are not designed for, not that they are more effective. |
J555568.50 |
09-26-2020, 12:30 PM | #104 | |
Rep 2,180
The X7 uses two OEM amps, that's why it can drive 20 channels. The most that an F-chassis OEM can drive is 11 channels. There is nothing in the software that is common.
J555568.50 |
09-27-2020, 06:32 PM | #105 | ||
Rep 611
The improvement is literally in everything and is big. The clarity is excellent, the speakers play exact but not sharp, the mids cover a much wider frequency range (much more mid-bass), the separation is a different league. The tweeters are very good and while they are not up to B&W home speakers, they still sound as B&W. The mids are both bright and deep, however, I am sure they have big reserves and would work even better with more power (which is my subjective feeling even in cars equipped with the entire B&W system from the factory). The speakers play subjectively louder at the same volume settings. I do not use the surround option anymore (as you clearly see the negative impact of processing and distortions) and keep the EQ almost flat. I experience very little listening fatigue, no problem listening for hours at very high volume levels. I have listened to many upgraded BMW's and not saying the B&W are the best speakers for stock amp or even best for the bucks. However, the improvement is big and if you like the B&W sound, you get it here. Worth noting that I have tried to describe the tweeters and mids only - the underseat woofers affect the overall sound a lot. Also the reason, why I am not trying to compare my setup to BMW's and Volvo's with factory B&W systems, that I drive time to time (btw, they sound quite different, too). Ah, makes sense, thanks for the information! I spotted at least three different HW versions of B&W amps, but they have the same speaker connectors... |
SniPro20.50 |
10-12-2020, 09:24 AM | #106 |
Rep 24
I'm gonna try this also. Did not even know that you could code the sound system from HK to B&O.
Just to make sure: doesn't coding it to B&O overload the amplifier and speakers/tweeters/etc.? Love to hear the improvements when the sound system is coded to B&O. |
10-13-2020, 03:37 AM | #107 |
Rep 611
In "expanded" mode, the B&O profile uses the center dash speakers significantly more (i.e. they play significantly louder). When listening at very high volume levels, the center mid can be potentially damaged. That's the only thing I am aware of.
01-15-2021, 12:17 AM | #108 | |
Rep 67
Earlier B&W amplifiers (the black box one) are using 10 channels (9 in same way as HK, 10th is separated central twitter) and are very similar to HK (has also 10 channels but uses only 9 - central mid and hight sitting on same channel) except power 1400 vs 600 and active noise processing (mic for equalizer) and active instead of passive crossovers for front. I replaced all high and mid speakers from HK to B&W and coded head unit the Bowers & Wilkins (6F1) and difference is night and day Last edited by SniPro; 01-15-2021 at 12:24 AM.. |
J555568.50 |
01-15-2021, 01:59 AM | #109 | ||||
Rep 58
hey. u have changed the mid Center speaker and the Front door speakers right ? maybe u can share the partnumbers greetings |
01-15-2021, 03:10 AM | #110 | |
Rep 611
- center mid: 65-13-9-279-632 - center tweeter: 65-13-9-279-631 - door mid: 65-13-9-279-635 - door tweeter: 65-13-9-279-629 |
