BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Which Tune To Get For The B48?
      03-01-2020, 07:16 AM   #1
Bluef33
Drives: BMW 4 Series
Hi,
I own a 430i which has the B48 engine. It produced 252 horsepower and I would ideally like it be in the 300 range.
It seems like Bootmod3 is the tune to go for but the website says that I will only be gaining around 14% horsepower in stage 1 for my car.
This would mean I'd only be in the high 200s and won't touch 300HP.
Do these numbers really matter in this case or will it still be worth going for Bootmod, or should I look at some other tune?
Thanks!
      03-01-2020, 08:22 AM   #2
hybris
hybris's Avatar
Norway
205
Drives: BMW 330e F30 M-sport
The 330i isn't an ideal car for tuning as the B48 in this engine is already tuned quite a bit from the factory (it's basically the same engine as the one in 320i that's making 184hp).
Bootmod3 would be a good way to get a safe increase. Stage 2 will get you close to 300hp.
Thorbjorn
16 BMW F30 330e M-sport
Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs
      03-01-2020, 09:10 AM   #3
Dronamashina
Dronamashina's Avatar
64
Drives: Bmw 340ix
Mgflasher is awesome for b48! I have 184 hp 20i version with st2 tune and that’s around 330 hp confirmed with logs and dragy tests. St1 would be good for 300 hp and safe at the same time! Also MGFlasher have some really nice and unique features and it’s cheaper than bm3.
2018 340ix AWD B58 8AT | MGflasher ST1 |
Instagram: andreykrop
Youtube: DronaMashina
      03-01-2020, 01:24 PM   #4
jcdub
jcdub's Avatar
Ireland
204
Drives: 330e M Sport
+1 I'm another happy customer with MG Flasher. Its customer service is second to none.
[/B]2017 330e M Performance, MG Flasher Stage 2, RM Motors DP, xHP Stage 3, Armaspeed CIA
      03-01-2020, 04:50 PM   #5
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
what's the math for logs and draggy to determine HP? I never understood this.
I have a B46 (US version of B48) xdrive with BM3 stage 1 93 and on the Mustang dyno, it shows 233whp which is about a 20hp increase over stock. Haven't found a local non Mustang dyno to try.
VipinLJ1941.50
      03-01-2020, 08:24 PM   #6
SRHosein
Trinidad_and_tobago
195
Drives: BMW 330e M-sport
Curious to know your gains with MG Flasher. Any dyno results?
BM3 Stage 2 91 octane on BMW 330e making about 350whp 440ft-lbs.
      03-01-2020, 09:57 PM   #7
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
i'm on B48 engine on BM3, and its been great for the past few months
stage 1 take me to around 219hp on wheel (around 266hp on crank)
chowser512025.00
VipinLJ1941.50
      03-02-2020, 10:58 AM   #8
mike@x-ph.com
mike@x-ph.com's Avatar
Originally Posted by Bluef33 View Post
Hi,
Thanks!
Get Bootmod3. Its safe, reliable, powerful and gives you complete control.
If you want even more power, we offer custom maps
https://x-ph.com/sale/
Phone number 702-494-9435
johnung4528.00
      03-09-2020, 04:09 AM   #9
johnung
I share your skepticism. I have heard of a rough correlation between an increase in MAF sensor readings and horsepower gains. But doubtful that numbers could be used to make tune judgments.
But how could draggy numbers correlate to horsepower? Too many variables like tires, temperature, road surface, etc. If a time changes by 0.1 or 0.2 seconds, it could be caused by almost anything and wouldn't correlate to a specific amount of horsepower gained.
      03-09-2020, 06:10 AM   #10
Dronamashina
64
Drives: Bmw 340ix
Dyno numbers means nothing for me if the car doesnt performs well. 20 hp over stock 330 is verry little if you ask me. Also dyno numbers depends on dyno itself as well as on dyno operator and differs a lot from one dyno to another with the same car.
      03-09-2020, 06:27 AM   #11
Dronamashina
64
Drives: Bmw 340ix
Ive got your point, but as i said above - dyno numbers means nothing if the car doesnt perform well. MGF st2 OTS tune proved to be powerfull and dragy numbers comfirms that. Also there were some racing against different cars wth good results for MGF st2 OTS.
      03-09-2020, 09:41 AM   #12
johnung
I'm just curious what the actual before and after dragy numbers were that are being taken as a confirmation of using a specific tune? I've just never heard that rational before so I'm trying to understand. Thanks.
      03-09-2020, 10:22 AM   #13
Dronamashina
64
Drives: Bmw 340ix
I have all of that data. MGF St2 ots Is about 1 full second quicker than stock 330 0-100 kph. 100-200 kph is about 5 seconds quicker, 1/4 also about 1 full second quicker.
      03-09-2020, 07:06 PM   #14
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
can you send us the link of MGF ST2 OTS vs other brand remap?
curious too see the difference
if dyno numbers means nothing, then you will say dragy numbers is a solid number?
then what's the purpose of tuner and workshop spend thousand of dollars installing dyno machine and testing their tune on dyno machine? and customer spend hundred of dollars just to run on dyno?
      03-10-2020, 02:48 AM   #15
Dronamashina
64
Drives: Bmw 340ix
The purpose of dynos for tuners is marketing. Also it’s good to see power and torque graphs, but dyno numbers itself is marketing in most times in my opinion. Remember that hp numbers sells cars...)) hp numbers sells tunes as well.
I only got this 5,2 seconds 0-100 bm3 st2 for 95 octane for 330ix. My 320ix st2 OTS for 98 octane runs 4,8 most of the time with 4,7 was the best. I’ll try to find another tuned 320/330 in my city and race it...
      03-10-2020, 04:18 AM   #16
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
the different in octane itself already provide gap in the performance gain
you can't expect octane 95 to run as good as octane 98, right?
      03-10-2020, 04:30 AM   #17
Dronamashina
64
Drives: Bmw 340ix
yes there is a difference, but not such big. MGF st1 for 95 octane ran 5.1 for me. So its still quicker than st2 bm3 for the same octane. Also much bigger difference after 100 kph, there is arond 2 seconds gap between MGF st2 and BM3 st2 from 100 kph to 200 kph. Im not saing bm3 is a bad tune, just saing that mgf is quicker.
      03-10-2020, 04:52 AM   #18
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
2 seconds gap is really big
but then again, it's from dragy result, which i don't know if it's true, the same thing you said for dyno number
because i believe, most of tuner (including MGF perhaps), develop their tuning on dyno machine. they will develope their tune not just based on hp and tq gain, but also the powerband across various rpm and other variables
      03-10-2020, 05:30 AM   #19
Dronamashina
64
Drives: Bmw 340ix
For the powerband and torque curve you are right, but I’ve said it already. As for the dragy... well I like it because it shows slope, so no one cat cheat with it. Also it shows weather conditions so you can compare different results pretty objective.
Just to mention: that car with bm3 has never break 5 sec barrier, while my car consistently runs less then 5 seconds. For example yesterday I had 4,9 with around 50 kg additional weight in the car, also it was uphill. So it would be 4,8 easily if weren’t uphill.
      03-10-2020, 07:02 PM   #20
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
do you have the dragy result for BM3?
      03-11-2020, 01:43 AM   #21
Dronamashina
64
Drives: Bmw 340ix
Yes, above 5,2 is bm3 st2...
      03-11-2020, 01:56 AM   #22
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
are you sure?
this is dragy for BM3 stage 1, 5.2s
430i, 4series, b48, engine, tune
