BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 Projector Angel Eye Headlights!
      12-20-2016, 12:15 AM   #837
RayonF30
Drives: Black BMW F30
Originally Posted by Hack14 View Post
Originally Posted by RayonF30 View Post
which bulbs?
I got two sets of the GP Thunder 7500K H7 bulbs for my hi/lo beams and one set of the GP Thunder 7500K H8 bulbs for my fog lights.
If you look a few posts before this there are some good conversations about bulbs and what everyone is using.
Install complete. I got the GP Thunder 5800K
      12-20-2016, 12:16 AM   #838
RayonF30
Headlights just arrived...two days earlier than FedEx tracking had scheduled!
Now I need the bulbs to get here so I can have a reason to fiddle with them.
Hopefully doing mine tonight. Already have the bulbs waiting.
which bulbs?
my headlights just shipped (at least got a fedex tracking number)
can't wait!!!
GP Thunder 5800k
      12-20-2016, 12:58 AM   #839
ill250
Drives: 2013 f30
Take pics! I ordered the same light bulbs but waiting for them to come in.
      12-20-2016, 01:17 AM   #840
kreeess
kreeess's Avatar
Drives: 2013 328xi
My bulbs just came in today also, will be attempting the install Friday night
If it ain't broke don't fix it
      12-20-2016, 05:50 AM   #841
RayonF30
which bulbs?
can't wait!!!
GP Thunder 5800k
      12-20-2016, 05:52 AM   #842
RayonF30
Low beam off
      12-20-2016, 05:53 AM   #843
RayonF30
Low beam off
Low beam on
      12-20-2016, 05:55 AM   #844
RayonF30
Low beam off
Low beam on
Full front... terrible shot... sorry. Lol
      12-20-2016, 06:00 AM   #845
RayonF30
Low beam off
Low beam on
Cutoff
XKxRome0ox1587.50
      12-20-2016, 07:28 AM   #846
Hack14
Hack14's Avatar
Drives: 2014 320i Xdrive
Install complete.
They look fantastic! Great job!
How'd the install go?
Any difficulties or shortcuts worth mentioning??
      12-20-2016, 09:02 AM   #847
RayonF30
Install complete.
Taking off the number was a breeze... HOWEVER, taking out the headlights was a pain. Total time spent was around 4.5 hrs. My friend helped with the headlight removal. The fasteners for the headlights are difficult to remove because of the bolt and nut design, and where/how they are positioned. They also had lock-tight on them so they were a pain to untighten. I also had to take of the front wheels and fender liner to get to the two bolts on the bottom of the headlight.
      12-20-2016, 09:10 AM   #848
Hack14
Hack14's Avatar
Good to know, thanks for the info!
      12-20-2016, 09:29 AM   #849
kreeess
kreeess's Avatar
Drives: 2013 328xi
Low beam off
Do the signal lights stay on with just the DRL?
Looks damn good btw!!
      12-20-2016, 09:31 AM   #850
kreeess
kreeess's Avatar
Drives: 2013 328xi
Low beam off
Low beam on
Cutoff
Is it me or is the light pattern uneven in this pic
      12-20-2016, 09:47 AM   #851
RayonF30
Low beam off
Low beam on
Cutoff
I think it's uneven. I don't know how to adjust I AND I hope I don't have to remove them to adjust it.
      12-20-2016, 09:49 AM   #852
RayonF30
Low beam off
I have only driven it at night. Haven't looked at that yet. I will today. Doubt it tho. Anyone else did the install?
      12-20-2016, 10:06 AM   #853
Hack14
Hack14's Avatar
From everything I've read thus far, they ALL need some adjustment out of the box. I'm quite sure I remember reading somewhere on this thread that you can adjust them while they're mounted. Otherwise, how would you ever be able to truly know if you'd gotten it right?
Supposedly, you just need a long screwdriver to access the adjustment screws. That being said, mine haven't even been removed from their boxes yet so I can't tell you exactly where those adjustment screws are for certain.
      12-20-2016, 10:29 AM   #854
elusive
elusive's Avatar
192
Drives: 2015 F30
Low beam off
No they do not. The photo above is parking lights, not DRL mode.
      12-20-2016, 10:31 AM   #855
elusive
elusive's Avatar
192
Drives: 2015 F30
Low beam off
Low beam on
Cutoff
There's two adjustment screws on each headlight accessed with the hood open. One is for vertical and the other for horizontal.
From your photo you need to do both. Did you tape off the original headlight center positions? If not you can use the center of the low beam as a guide.
Congrats on the headlights
      12-20-2016, 10:47 AM   #856
kreeess
kreeess's Avatar
Drives: 2013 328xi
Man I am JUICED to install mine this Friday
      12-20-2016, 11:05 AM   #857
MONSTAR
#gotboost
MONSTAR's Avatar
Drives: 2018 M2
Looks good!! You need a long screwdriver to get the 2 adjustment points. Be careful with them as they are plastic and they move plastic gears.
Hoping that removing the front wheels won't be necessary as I don't have my jack or stands out here
      12-20-2016, 11:28 AM   #858
RayonF30
If you can manage to get the torx screwdriver pass the fender liner then you won't need to take off the wheels.
