03-04-2019, 05:58 PM | #1 |
Rep 84
Different ride heights right to left
I was measuring from top of wheel well opening to the floor for each wheel as I am getting prepared to swap my springs (435i x-drive, M sport) for M4 springs. With the stock springs the passenger side front is 26" and the drivers side front is 27 1/8". Is that big of a difference normal?
03-04-2019, 09:06 PM | #3 |
Rep 5,456
Drives: F30
Sounds Normal.
Once vehicle is loaded with your ass in the seat, it should even out. |
03-05-2019, 04:50 AM | #4 |
Rep 464
Ride height spec
According to BMW, the normal difference in ride height (left/right) should be 10mm.
https://www.newtis.info/tisv2/a/en/f...ral/1VnXdA8kdL https://www.newtis.info/tisv2/a/en/f...ide/1VnXfyK8Ok If there is no damage to the suspension, I suspect the floor upon which the car was sitting when you took the measurements was not level. Try taking two sets of measurements with the vehicle oriented 180 degrees between the two. Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
03-07-2019, 09:55 PM | #6 |
Rep 153
Drives: 2014 428xi Sport Line
Went in for an alignment at the dealership. F32 xDrive.
On the post alignment spec sheet the ride height shows as ; Front left 635mm, front right 628mm Rear left 619mm, rear right 611mm The target data for front is 629mm and rear target data 620mm. |
03-08-2019, 12:36 PM | #7 |
Rep 503
What are your wheel specs?
03-08-2019, 02:51 PM | #8 | |
Rep 84
03-08-2019, 10:43 PM | #9 |
Rep 153
