07-22-2016, 09:00 AM | #1 |
Rep 1,127
Pure Stage 2 Comparison
Hey Everyone. Here is a comparison of the intake and exhaust sides of the Stock N55 EWG turbo vs the Pure Stage 2. These are from my upgrade.
They are fairly high res so I won't clutter up the thread with large pictures. Album: View post on imgur.com Gives you an idea of how much material they are removing from the Turbo case and the increased size of the larger wheels. |
07-24-2016, 02:01 PM | #2 |
Rep 938
you can see the difference, is yours installed? How do you like it?
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
07-25-2016, 07:06 AM | #3 |
Rep 4,323
It's sad how bad stock is right!?
07-25-2016, 07:20 AM | #4 |
Rep 1,805
So how do you like the Pure stage 2? Do you just run a JB4 with that?
I want to run 93-92...
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
07-25-2016, 09:34 AM | #6 |
Rep 271
Which flash tune are you using? Are you going to use supplemental fueling?
2021 M550i
BMS Pedal tuner JB4 |
07-25-2016, 10:08 AM | #7 |
Rep 1,805
Enzo? I sent them my ECU last year, major issues and we had to go back to stock flash. I still would want to try it again, I think i was one of the first couple guys to get it.
07-25-2016, 11:30 AM | #8 |
Rep 1,127
07-25-2016, 11:57 AM | #9 | |
Rep 1,805
Well I just got off the phone with Mike and placed my order for the pure 2 and a bunch of other goodies. Can't wait!
zinner559.00 |
08-05-2016, 06:50 PM | #10 |
Rep 1,127
08-17-2016, 02:12 PM | #11 |
Rep 893
Curious how much boost the flash tune is targeting? From what I remember, stock fueling is good up to about 16-17psi til redline. I would really recommend port injection or meth, the turbo really comes alive around 22+psi.
2019 SG M5C
2015 SO M3 6MT 2015 BSM M235xi |
FSociety3812.50 |
08-22-2016, 04:23 PM | #12 |
IG @bmwF9xG80
3813
Rep 7,593
OP, how much boost your flash is running ?
60-130mph 6.5s X4M #HCP
08-23-2016, 09:37 PM | #17 |
Rep 115,980
08-24-2016, 07:59 PM | #18 | |
Rep 1,127
I will let the port fuel injection/tuning work itself out a bit more with the trail blazers before I check into that. |
08-24-2016, 08:32 PM | #19 | |
Rep 1,127
edit oops wrong person quoted. I went back and looked at some logs and mind you this is a BT adapter so the sample rate isn't the best, but I am seeing 15 psi @ 3200 rpm and please don't take that as fact as the sample rates aren't the best, but I am doing full sweep to keep the sensor data as close as possible. |
08-24-2016, 09:18 PM | #21 | |
Rep 893
2019 SG M5C
