BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > How does dealer/BMWNA recover engine parameters, only when a code?
      08-29-2016, 02:36 PM   #1
2wheelsrbetter
2wheelsrbetter's Avatar
Drives: hot rod
charge pipe cracked and popped off. dealer ran data and called to let me know there was an over-boost occurrence. they want to deduce a tune was present from this.
can they only pull data from the code incident that was thrown? (drivetrain malfunction when pipe went)
Meaning, if codes are deleted, are they still able to download parameter data to see max boost etc?
If no, then one would want to delete all codes prior to bringing in for repair, correct?
07 e90 335i
13 mk6 GTI
13 f30 335i
      08-29-2016, 03:04 PM   #2
jgoens
jgoens's Avatar
3788
Drives: 2013 335i msport
Best thing to do is get an ER CP and be done with it. This is why with a tune it is always better to upgrade and avoid the inevitable. As for your question, I have heard they can pull parameters if need be.
      08-29-2016, 03:39 PM   #3
stxf30
stxf30's Avatar
Drives: '13 F30 335i MSport
Yes, they can pull the data. Sounds like you have an a$$hat for a dealer. In my instance, the Tech stated the DV failed causing overboost and thus the CP and DV were replaced under warranty. While it was in the shop I ordered my ER CP. If they are going down that path then I say F it. If they can prove you are running a tune, it could get nasty down the road if anything else fails.
2013 GSM 335i MSport
      08-29-2016, 09:21 PM   #4
2wheelsrbetter
Drives: hot rod
what was interesting to me is that the SA said he's never seen or heard of this failure.
whether one is purely ignorant of their livelihood, or pretending to be ignorant are both equally amusing and entertaining to me.
if I wasn't knowledgeable in my career I would be quickly replaced, but somehow in the auto industry it's widely accepted.
07 e90 335i
13 mk6 GTI
13 f30 335i
      08-29-2016, 09:42 PM   #5
TypeOne
Enthuisiast
TypeOne's Avatar
93
Drives: G05 X5
My SA told me the same thing when I took my car in to have the CP replaced. I told them I was beating on it and heard it pop. They didn't ask any questions and replaced it under warranty. I showed them the threads on here showing they cracked on cars with out tuners.
Haven't had an issue since, although I have a metal CP.
      08-29-2016, 10:19 PM   #6
zinner
zinner's Avatar
Drives: `17 X5 35d/`15 335i/`18 M550IX
Yeah they can pull it from the DME. It's in the fault history. You can delete it from ISTA/D+ not sure if it puts it outta reach of the dealers methods, but probably does.
