11-26-2019, 05:36 AM | #1 |
Rep 87
TCB help?
Hi guys I've just got a second hand tcb unit that sits in the trunk, I've plugged it in but it's still coming up as no connection on ista, does anyone know how to program it?
11-26-2019, 11:42 AM | #2 | |
Rep 10,473
Did you original unit go bad? EDIT: Apparently your original unit was stolen out of car based on previous post ? |
11-26-2019, 11:44 AM | #3 | |
Rep 87
But I would like to use remote features, possibly by typing in the donor vin to connected drive when registering the system But would like the car to more or less function like before |
11-26-2019, 11:47 AM | #4 | ||
Rep 10,473
Do you know the VIN? |
11-26-2019, 11:49 AM | #5 | |||
Rep 87
Yes I know the last few digits of the vin that will be enough to identify the car |
11-26-2019, 11:50 AM | #6 | ||||
Rep 10,473
Likewise, you need the TCB part number to determine how old the TCB is as 3G is planned to Sunset in UK in 2020 which might make your unit a boat anchor after all this. And how do you know that the TCB of the donor car isn't already registered to the previous owners with BMW? These are things you MUST know before possibly wasting time installing something that otherwise will never work as you intend it to. |
11-26-2019, 01:36 PM | #7 | |||||
Rep 87
Do you have a guide on how to do this I just want to give it a try at least |
11-26-2019, 02:13 PM | #8 | ||||||
Rep 10,473
As you cannot swap your eSIM from your current TCB as it was stolen, you would essentially swap (or actually install in your case) the TCB unit WITH A CAN filter and register it to car. Do not attempt to change the TCB donor VIN. You could then see if it works. Having never done a TCB retrofit, if it doesn't, you might need to also install a CAN filter on the HU and then code your HU VIN to match the donor TCB VIN. This would most likely require new FSC codes as well. By putting CAN filters on the HU and TCB, You have isolated the donors VIN from yours. At this point, your M140 should appear as the donor's X1 to BMW. |
11-26-2019, 02:18 PM | #9 | |||||||
Rep 87
11-26-2019, 02:23 PM | #10 | ||||||||
Rep 10,473
