11-20-2021, 02:58 AM | #45 |
Rep 1,801
Just a little update the car has been remapped by HLC Performance to see quite what we can get out of the port meth setup and I'm sure there is a little bit left in it but I've now done three runs in the 5's for 100-200 making this by far the fastest F31 ouside of Taiwan.
I appreciate that the jump from the Stg3 E30 time to what I'm at now isn't actually that much BUT the E30 time was admittedly a VALID glory run. The weather gods were on my side as it was ~5c and brilliant DA. Last night in Mexico it was 12.5-13c, rather humid and rubbish DA so the difference is really more than it appears. Also the constant mixing of Ethanol with every fill up was a pain in the backside so now I just go out, put my foot down and as long as there is meth in the tank it gets up and goes. 8.68s - Stg2+ (didnt do much testing on this but this was the fastest) 7.84s - Stg2+ E30 (Average 7.9s - 8.0s fairly consistent) 6.91s - Stg3 99 (Average 7.0 - 7.1s) 6.10s - Stg3+ E30 (Average 6.25s - 6.3s) 5.76s - St3 + Port Meth (Average 6.0/6.1)
Europe's fastest (stock block) F31 340i RWD | MPPSK | XHP 3 | Pure800 | Port Meth | Dorch 2 HPFP | MG Flasher
Last edited by chris-c; 12-15-2021 at 09:59 AM.. Reason: Upgdated the fastest numbers. |
11-20-2021, 05:29 AM | #47 |
Rep 1,801
I swapped to some Zimmerman ones from auto doc. Slotted and dimpled. They're not expensive but the pads make all the difference. Doing all of these trips to Mexico is destroying the ferodo pads though
11-23-2021, 03:14 AM | #50 | |
Rep 8,498
I run Pagid RSL1 all round, full-time, street and track. They handle heavy braking very well but do squeak at low speeds i.e. sub 10mph. Pagid RS29 is also a popular compound. The pad compound is very similar to RSL1 but some of the characteristics have been tweaked.
11-23-2021, 03:36 AM | #51 |
The artist formerly known as AC Schnitzer UK
3609
Rep 4,518
11-23-2021, 03:45 AM | #52 |
3609
Rep 4,518
A few comparisons for your 100-200km/h time.
M2 Comp: 10.7 AC Schnitzer M2 Comp: 8.8 M4 (G82): 8.6 AC Schnitzer M4 (G82): 6.9 M5 (F90): 7.5 AC Schnitzer M5 (F90) 6.4 |
11-23-2021, 04:04 PM | #53 | |
Rep 1,801
Annoyingly I filled the car to the brim the other day or I'd have been out tonight doing some more data logs. I need to poke my meth controller more to make sure everything is a-okay. Might add in a flow sensor and a boost cut so if it isn't flowing the car simply looses boost. |
11-23-2021, 04:06 PM | #54 | |
Rep 1,801
Can't wait to get it to pod next year and I'll beat the snot out of it until it hits tens |
11-24-2021, 02:38 AM | #55 |
Rep 272
Wrench recorded 5.65 100-200kph on a F90 M5.
Stage 1 with decat downpipes but doesn't mention the fuel used.
2017 F36 440 LCI - Smoked Topaz | Auto | M Sport Plus | HUD | ICON Adaptive Headlights
11-24-2021, 03:38 AM | #56 |
3609
Rep 4,518
According to the datalog our dragbike does 100-200km/h in 1.27, but admittedly you can't drive it to the shops or go on holiday on it
11-24-2021, 05:53 AM | #57 |
Rep 8,498
11-25-2021, 02:26 PM | #58 | ||
Rep 1,801
I've had a few issues with my OBD adapter to get the RPM over the last few days where the controller simply wasn't seeing an RPM signal therefore it wasn't spraying meth. Fortunately I've caught it without going too silly.
Today I ripped the OBD port out and hardwired the RPM feed to it so I don't have to worry about a loose connection anymore. The bonus is my OBD port flap closes now and the car looks even more stealthy! Quote:
I honestly think the only reason your bike stays on the ground is because you're balls are just too heavy so it can't take off!
Lorcan3609.00 |
12-14-2021, 04:38 AM | #59 |
Rep 1,801
I caught a plane last night to mexico (as you do) and the car was running very nicely. Full tank of meth (12L) and just over 3/4 tank of fuel, car seats in the back. 13C ambient, 23 IAT and the car ran a respectable time.
The tuner is going to turn it up one more time to allow me to fight for the fastest F31 on Dragy (0.09s difference). I didn't expect to get this much from it on my "daily" map
12-14-2021, 05:41 AM | #60 | |
Rep 2,047
Have you changed the bearing and taken other precautions to strengthen the engine?
440i GC with MPPSK, AP intake, 20" 624 M wheels, Wagner downpipe, Xhp stg 3, BM3 stg 2
instagram: f36_garage |
MY340i721.00 |
12-14-2021, 07:46 AM | #61 |
Rep 1,801
Nope absolutely stock block. I'm sure it'll shit the bed at some point and I'll have to replace/upgrade it but for now I'm keeping it 100% stock block / stock gearbox.
12-14-2021, 08:53 AM | #62 | |
Rep 211
In the good old bad old days of carburettors it was a known fail to let something drop into the choke during servicing (sometime a ball bearing that was a part of the carb). You would then get maybe 10 minutes of gentle 'pinging' until the poor piston that had received the unwelcome part gave up the ghost ... along with the engine. |
12-14-2021, 11:03 AM | #63 | |
Rep 2,047
Hoping it will stay healthy and let us know when you break the record! Don't forget the gopro
12-14-2021, 11:22 AM | #64 |
Rep 8,498
The 'new' turbo was seized/stuck - this was a massive warning sign. But they freed it by counter-rotating one of the wheels, heard a ping', and chose to bolt it on to the engine for a tuning session.
Had they bench primed the turbo ? Had they cranked the engine, two separate 10 second cranks using the starter motor but with the electrical connectors disconnected from the injectors so that the engine couldn't 'fire', so as to produce a pressurised oil supply to the turbo ? If not, damage to the turbo bearings is very likely, which can produce swarf. A turbo should always spin freely. Depending on the construction of the core the 'ping' could have been a ball bearing coming out of a race, some swarf being ejected, etc. It could have been a jammed vane, and that in itself should have been a significant warning that the turbo was suspect. Damage to the turbo bearings can cause the turbo to fall out of balance, fast rotating metal components no longer run on a complete bearing and touch whilst spinning at 100k-200k rpm, more swarf is produced, metal particles flow out of the turbo through the oil drain and into the sump where they can be picked up by the rotating components or the oil pump. The oil filter is meant to intercept things like this and stop them getting into the oil pathways and galleries, but fine particles can still find their way into bearings etc. Sometimes 'we' take a risk. Big shame for the guy that he's apparently blown his engine, but it seems that there's a chain of factors here including low mechanical sympathy and/or servicing, and lack of attention to detail.
12-14-2021, 11:45 AM | #65 | |
Rep 2,047
He already sourced a new 1K miles engine in his update vid, so glad to see he is moving on. As mentioned, he had no idea how the engine was treated by previous owner, and while enthusiastic about his builds, he doesn't have the in-depth technical knowledge - and never claimed to. But when you are the garage, certainly you would expect them to take all the right steps to try and prevent such a massive failure.
12-14-2021, 01:32 PM | #66 | |
Rep 1,801
When I swap maps to the silly map I'll make sure I video it but it's all a bit bloody boring going in a straight line. I should be going to terminal velocity next year and the first proper Santa Pod event as I need to get the car into the tens. It will happen but I might end up taking a lot of stuff out of the car to get there. Who needs seats and a tow bar anyway! |
