08-19-2022, 09:55 PM | #1 |
Rep 67
You can access all of the pictures through my album View post on imgur.com 2013 BMW 328i M-sport Black Sapphire Metallic 109,0XX miles I got the car 10/2019 82k miles, It now sits at 109,000 miles. I am the third owner. First owner drove it 16k miles, then the second owner, and now me. I always take great care of the car, it's my baby. Often give it weekly pressure washer hand washes, and detail the inside too. I believe this is one of the cleanest examples of an F30 you will find out there. This F30 has all the options you could ask for! The M-sport package, Premium package with comfort access entry, Premium Surround Sound Harman & Kardon 16-speaker package (great sound system that sounds amazing), Technology package with the nicer navigation screen inside, heads-up-display, parking sensors, and reverse camera. Comes with 2 keys. Overall car is in excellent condition! Newly installed engine (more info down below) runs and drives good with no check engine lights or other lights on the dash. Car exterior is in great condition, paint looks great with no rock chips on the front bumper or hood (lower portions of the front bumper above the front lip have some ppf). Interior is in great condition too, no issues. Car has all new Coolant, Engine Oil, Fuel Injectors, Ignition Coils, Spark Plugs, Battery, Brake Fluid Flush, Engine air filter and Cabin air filter, Headlight low beam bulbs, and more. Exterior -Paint is in excellent condition! August 2022 completed full vehicle clay bar, machine polish, and waxing and then covered the car and it is now sitting still under the cover. -Original paint matched M-sport trunk spoiler -M-performance style rear diffuser (have stock diffuser included as well) -Ikon Motorsports DP Style Front Lip -KG Splitters side skirt extensions and rear bumper extensions -GTS style oled taillights (have stock tail lights included as well) -Active Autowerke axle-back Exhaust (stock exhaust included) -Gloss black dual slat kidney grills -Black front and rear reflectors -Custom mud flaps to protect the paint and keep it clean -Carbon Fiber antenna -Comes lowered on BC Racing Coilovers (lowered about an inch all around from the stock M-Sport suspension ride height, on fully adjustable BC Racing Coilovers because my stock m-sport suspension went bad with mileage). -BMW M-Sport 400M wheels that are powder-coated satin black and then ceramic coated to protect and keep clean. 18x8 front, 18x8.5 rear, -Michelin Pilot Sport A/S3+ tires with a 235/40/r18 front tire, 255/40/r18 rear tire -12.5mm wheel spacers in the front and 15mm wheel spacers and extended lug bolts in the rear. -Front fenders rolled to perfection by only the best @mrsexys2k for that nice flush wheel fitment with no rubbing. -Yellow painted brake calipers also ceramic coated to match the license plates and black and yellow theme of the car. Interior -20% ceramic tint all around which looks great and keeps the inside cool. -M-sport silver aluminum hexagon trim that is currently wrapped in carbon fiber vinyl wrap to give a nicer, darker, carbon fiber, stealth look inside (you can easily remove vinyl wrap if you'd like to put it back to stock silver metal hexagon trim inside). -Start stop button and center steering wheel trim wrapped yellow. -M-Sport steering wheel has a suede steering wheel cover that I custom ordered from @eastdetailing and sewed onto the wheel to add soft suede and yellow accents which make this upgrade look and feel much nicer. -Comes with the original bmw all-weather rubber floor mats which I always use, and also have the like new carpet floor mats in a bag kept inside which you will get too. Maintenance Reusable Engine air filter 2/7/20 86k Cabin air filter 2/11/20 86k Front brake rotors and pads 4/1/20 89k Rear brake rotors and pads 8/16/20 91k Michelin Pilot Sport A/S 3+ tires 10/16/20 96k BC Racing Coilovers 11/1/20 96k Alignment by JMP Autowerkz 11/14/20 96k Windshield Wipers 5/5/21 103.5k Ignition Coils 7/16/21 105k Spark Plugs 7/16/21 105k Fuel Injectors and decoupling elements 10/11/21 106.5k Battery 10/13/21 106.5k Xenon Headlight low beam bulbs 1/11/22 108k Engine replaced by JMP Autowerkz 8/1/22 at 109k miles (Engine in car has only 100k) Original n26 engine was blown, so just replaced it with a 100k mile same type 2013 n26 engine. JMP Autowerkz completed the engine swap and replaced the original blown engine with the newer engine. I have proof of a very recent compression test on this engine that proves this engine is in good condition with good compression numbers all right around/above 200-210 psi on every cylinder. The new fuel injectors, ignition coils, and spark plugs were swapped over into this newer engine along with new exhaust manifold gaskets, intake manifold gaskets, turbocharger oil feed and return lines, and new turbocharger coolant feed/return lines. Everything works as it should and there have been zero issues with this engine in the car. I have driven about 100 miles with this newer engine in the car and it is now sitting under the car cover (which is included with sale) waiting for you! If you have any doubts or concerns about the engine swap, just please google JMP Autowerkz and you will see that they are a very reputable, 5 star shop, and have all good reviews with 5 stars on both yelp and google. If you have any questions or inquiries about this car, please contact me by messaging me through bimmerpost or leaving a reply down below! |
09-16-2022, 09:07 PM | #7 |
Good life
130
Rep 1,937
Nice job. Very clean. Would make a great fun daily
Current: 08 E90 M3 Alpine White Former: 11 135i Msport Space Gray -Former: 07 335i Titanium Silver E92- Former: 08 135i Alpine White E82- Past: 06 Subaru STI WRB- Past: 04 Audi S4 Imola yellow- Past:97 Honda prelude Ice blue
kylebm33.00 |
09-24-2022, 06:14 AM | #9 |
¯\_(ツ)_/¯
945
Rep 1,762
I love the yellow accents with the calipers, steering wheel trim and plate
kylebm33.00 |
09-24-2022, 05:12 PM | #10 |
Rep 265
Drives: 2018 BMW M4 Vert
I've followed this build since it was stock. Kyles a great seller, cars been meticulously maintained and worked on. Engine work was done by one of the best shops in Los Angeles- JMP Motorworks
Good luck with sale bro. |
kylebm33.00 |
