09-06-2022, 12:04 PM | #23 | |
Rep 27
09-06-2022, 12:35 PM | #25 |
Rep 27
09-06-2022, 02:05 PM | #26 | |
Rep 7,602
09-06-2022, 02:26 PM | #28 | |
Rep 27
09-06-2022, 03:28 PM | #29 |
Rep 27
09-06-2022, 03:38 PM | #30 | |
Rep 7,602
stock plugs (bosch) stock gap... the BM3 recommendation is not needed on 99% of cars and is a common trap people fall into. In some cases it actually makes the car run worse. |
09-06-2022, 03:41 PM | #31 | |
Rep 27
09-06-2022, 09:44 PM | #32 |
Rep 2,357
I have never seen logs with worse timing than this. I am guessing you make very little extra power running stage1/2 over stage0 because timing is so poor. Complete waste of fuel. In my opinion, if you cannot achieve at least 8 degree of timing then lower your boost.
Running octane booster will be very expensive. Get a WMI kit and run 100% methanol, this will help you immensely!
(A Dane in China) Last edited by harkes; 09-06-2022 at 09:50 PM.. |
09-07-2022, 12:08 AM | #33 | |
Rep 27
Not sure what anyone's thoughts on putting the car on the Stage 1 91 ACN tune at 12 psi until I can find something concrete. My next thought is to just dump the rest of the octane booster (around 24 ounces of Boostane Pro) in with half a tank of fuel just to confirm 100% that it is infact fuel that is my problem. If that is the problem, I'll tune the car to the stage 1 tune and leave it at that and anyone having the same issue have this thread as assurance. If not, then I will work on figuring out the problem, whether that is a bad coil(s), bad injector(s) or whatever it may be. |
09-07-2022, 12:42 AM | #34 | |
Rep 7,602
1. High dose of octane booster as you mentioned. What octane would those 24 oz to 8gal get you? 2. Try stock bosch plugs at stock gap If neither of those work, need to evaluate if its worth trying coils, but honestly coils usually dont cause that problem... especially not all at once on all cylinders. WMI is a reasonable solution. It provide extra fuel quantity, octane, and lowers IATs. It does add complexity though. |
09-07-2022, 02:14 AM | #35 |
Rep 2,357
+1 for the stock ZR5TPP33. They work just fine all the way to 500whp - and at stock gap!
(A Dane in China) |
09-07-2022, 06:08 PM | #36 |
Rep 27
09-07-2022, 07:30 PM | #37 |
Rep 7,602
Then you should have basically perfect timing running the ACN and 91 maps. I would try both on that tank of gas. 2-3 logs on ACN, then flash 91 map, drive maybe 10 miles for adaptations, then 2-3 logs on 91 map
09-08-2022, 10:05 PM | #38 |
Rep 27
Here are the last 2 logs of testing with the 28 oz 8 gallon fuel mix, but I left the colder plugs in (not sure the other plugs will help THIS much). I'll test the stock plugs this weekend, but not sure that will solve my problem. Also, scanned my car and had this error: https://gyazo.com/062b41d456dc3609c3972afb28166035 dont believe it is a very good sign for the health of my engine...
Logs here https://www.bootmod3.net/log?id=631a...0b4376d45fbb7c https://www.bootmod3.net/log?id=631a...90c69a0b8114af |
09-09-2022, 01:29 AM | #39 | |
Rep 7,602
09-09-2022, 05:46 AM | #40 | |
Rep 2,639
Your logs are partial so it's pretty hard to get a good look at it.
09-09-2022, 09:19 AM | #41 |
Rep 27
When I am doing these logs, the car is breaking up really bad and it feels like I am going to blow my engine, so no I am not going to keep it floored if it starts shaking and misfiring as much as it is when this is happening.
09-09-2022, 09:21 AM | #42 | |
Rep 27
09-09-2022, 02:12 PM | #43 |
Rep 7,602
MY suggestion is to install fresh OEM bosch plugs at stock gap (confirm it before installing), then flash down to stage 1 91 or ACN tune and log that. How confident are you that your NGKs are not counterfeit?
09-09-2022, 03:01 PM | #44 |
Rep 27
I bought the plugs from a NAPA Auto Parts store in my city so I am pretty sure they aren't counterfeit. I will try the stock plugs today and see if that helps any.
