09-02-2022, 04:39 AM | #23 | |
Rep 2,048
09-02-2022, 07:44 AM | #24 | |
Rep 103
09-02-2022, 08:57 AM | #25 | |
Rep 2,048
There is not a single chance that the weight difference between the single and two piece discs is 2.5kg each, there isn't enough material for that to be the case. A basic calculation assuming the disc end is 10mm thick (it's thinner) and is 200mm diameter (it's smaller) and the bore is about 70mm then even without the relieving of the corners and the wheel stud holes a plain steel disc would be 2.1kg vs 0.8kg for the aluminium. Except that would only be the saving made if it was bonded straight onto the steel disc. Instead you've got the normal diameter steel hat, and more aluminium as an additional layer, plus rivets. It might be a few hundred grams or so lighter but that's bugger all in the grand scheme of the unsprung mass involved in these cars. Even if you were saving 2.5kg on a total unsprung mass of 10kg then that's dramatic but we're talking sprung mass of 50kg upwards, and as a rotational mass it's negligible too as it's such a small diameter. I mean it'll have an impact but unless you do lots of other stuff to reduce mass too it's just not going to be discernible. If someone puts a brand new two piece stock rotor on a scale and does the same with a one piece and it shows a big difference (or shows manufacturers tech specs) then I'll happily believe it but until then I will continue to believe that these rotors are simply for looks and not performance. To save 2.5kg by going to aluminium from steel you would need to replace the equivalent of a 25cm diameter by 1cm thick piece of solid steel, and not add any more material on anywhere else. Clearly this isn't the case with these rotors. I'm not trying to personally go at anyone here, it's just some people seem to be arguing against basic maths and physics because 'aluminium is lighter than steel', which while vaguely true in that it's less dense, also needs greater volume for equivalent strength which also complicates things in these *** paper calculations. Start adding on bits of aluminium AND steel and those potential savings become moot very quickly. Like I say, show me numbers and I'll believe it. |
09-02-2022, 02:57 PM | #26 | |
Rep 103
https://brakeguide.com/hpa/en_US/8DD...atasheet.xhtml Here are the zimmerman 1 piece front 370mm rotors, which per the spec sheet weigh 13.2kg https://web.tecalliance.net/otto-zim...eNumber:113409 Therefore, 1.3kg savings per wheel or 2.6kg for the front rotors only vs going 1 piece. The rears are .9kg lighter per rotor vs zimmerman which you can find on both sites. Total savings of 4.4kg. |
09-02-2022, 04:08 PM | #27 | |
Rep 2,048
The amount of mass in the suspension system of an F30 is sizeable, and even though not all of it counts as unsprung, the weight of a wheel, tyre, hub, caliper, driveshaft end etc add up very significantly. If you're saving 1kg here, 2kg there off each and every part and going to the point of milling down uprights then you're likely to detect something at the wheel even on a heavy car, but saving 1.3kg on such a mass as a stock F30 just isn't going to make a difference, especially when the mass of the car is so great and the unsprung mass therefore has a heavier opposing mass to work against (unsprung:sprung mass ratios are also a key factor, more so in many instances than just unsprung mass itself). Personally I like the look of the aluminium centres, but if I was wanting to actually make a meaningful difference then I'd look at pukka 2 piece rotors with a full aluminium bell and a racing style disc with much thinner braking surfaces and larger venting slots. |
09-03-2022, 10:09 AM | #28 | |
Rep 103
09-04-2022, 04:51 PM | #29 |
Rep 2,048
Hey, I've got them, I'm not against them, I just think that anyone putting them on and believing they can feel the difference is kidding themselves. On a Caterham a 10lb saving in rotational/unsprung mass is sizeable, but on a large and heavy saloon/estate I think it's pissing into the wind unless you've got a large chequebook out and made some other fairly large chunks so you get a reasonable cumulative effect. Even then you've got a lot of mass elsewhere which is difficult to overcome. Maybe I'm just more pragmatic than some having already pissed much money on tweaking road cars, or just have lower expectations of a daily, but on public roads I just don't see that you will ever notice the difference of what is in essence the square root of bugger all and I'd say I'm at the upper end of what people would consider (un)reasonable behaviour on tight and twisty public roads, most of which are rough enough to definitely highlight any improvements.
09-04-2022, 10:55 PM | #30 | |
Rep 5,393
I would much prefer a StopTech full crossdrilled with directional left/right vanes for optimal cooling. That's a difference that can definitely be felt in bite and in stopping power in the rain. Heck, if one could feel a sizable difference, then people would be refusing Brembo 370's for Brembo 340's. There's a weight savings of 5.1 lbs per rotor alone, and more from the smaller caliper. The front StopTech 370x30 full floating 2-piece that I have now weigh 10.5kg (23.2 lbs) If someone was really targeting weight savings, I'd be looking at forged wheels at 18 lbs each vs stock 400M wheels at 26 lbs each. 8 lbs per corner is probably something that could actually be felt. |
Ennoch2257.00 |
09-05-2022, 06:14 AM | #31 |
Rep 2,048
Yep. I actually just did a quick google as I suddenly wondered what my 403M's weigh and it's 29.5lb apparently, according t'tinternet. Whether that's front or back is anyone's guess, but it's heavy. Throw on a 22lb Michelin PS4S front, or 23.8lb for the rear, and you have a 50lb+ tyre setup on each corner. It's certainly noticeable how heavy they are compared to my Impreza's 17's. Of course there's then another however many kg/lb's from all the other unsprung mass and it's just such an inconsequential amount, I mean just disc plus wheels on the front is 78lbs a corner. The calipers are 10.8lb each, so say a round 90lbs a corner, but then you've still got a portion of the control arms, the strut lowers, a portion of the springs, a portion of the driveshafts and the wheelnuts...I reckon you're probably looking at another 50lb or more so say 150lb a corner unsprung mass. Against that backdrop the couple of pounds saving is just so tiny.
johnung4528.00 |
09-05-2022, 07:47 AM | #32 | |
Rep 5,393
09-05-2022, 10:34 AM | #33 |
Rep 103
I'm actually waiting on a set of backordered fl-5 wheels with dws06+ tires that weight 11lb less per corner while having 255 square vs 225. By going to the larger brakes, I'm negating some of those savings, but this route at least makes it a bit better (gaining 4lb vs 7lb with 1 piece as it pertains to the fronts, gaining 1.8lb vs 3.8lb for the rears). I've felt a significant difference going with a 5lb lighter per corner wheel set up in a past car, so I'm really excited for the lighter wheels and want to keep as much of those weight savings as I can. Will anyone feel the difference with these rotors vs 1 piece? Highly unlikely, but to me the looks and weight savings are worth such a tiny investment.
09-05-2022, 10:54 AM | #34 | |
Rep 103
09-05-2022, 03:41 PM | #35 | ||
Rep 5,393
09-08-2022, 11:00 PM | #36 |
Rep 261
Drives: 2017 320i xdrive
So, I have a 320i (stg2 fbo) with base brakes. 312 front 300 rear. 2017 xdrive. I am looking to do this exact same converstion (I believe its warranted given how I drive on backroads, ive destroyed 2.5 sets of rotors in 50k miles). I am very confused on whether or not this will fit my car (assuming I throw in 18inch rims). Can anybody speak to whether or not this works in an F30 320ix? edit: I do not care at all about looks, only performance. If the calipers are unpainted then so be it. Suggestions?
09-09-2022, 08:49 AM | #37 | |
Rep 103
09-11-2022, 10:34 AM | #38 |
Rep 103
Got the brakes put on. They feel great and look amazing. I appreciate the smooth nature of the akebono pads. The initial bite is very smooth which helps when your wife gets car sick easily. Still more stopping power than i had before but buttery smooth. No additional parts needed and smooth sailing. Due to a miscommunication with the install shop, they did not code for the brakes but offered to do so free of charge whenever I'd like. Going to live with them as is for a bit to determine if its necessary. If anything, i'll just get it done at my next oil change. 1 pic pre install and the rest taken 40 miles after getting them on.
09-11-2022, 04:55 PM | #39 | |
Rep 261
09-12-2022, 07:16 AM | #40 | |
Rep 103
09-12-2022, 07:36 AM | #41 | |
Rep 132
MoeTE87651.00 |
09-12-2022, 11:07 AM | #42 | |
Rep 103
