09-28-2022, 09:17 AM | #1 |
Rep 31
Help reviewing Datalog - 2013 F30 N55 Xdrive
Hi Folks,
Can someone please take a look at this log and let me know your thoughts? It seems like I lose power when I initially step on it. Sometimes it feels like the clutch slips then catches and the power is there again. From what I can see it looks like boost is dropping off on heavy load but I wanted some more experienced folks to review the log to see if anything else stands out. Also, the clutch slipping feeling doesn't seem to happen in the stock map. 2013 335XI F30 N55 VRSF Catless Downpipe VRSF Charge Pipe BM3 Stage 2 93 Octane Map New plugs and coils in Feb 2022 https://www.bootmod3.net/log?id=6333...90c63171d21d83 |
09-28-2022, 11:46 AM | #2 |
Rep 7,606
Looks like some overboost and throttle closure starting at around 3000rpm then clutch slip and the car pulls boost and timing at 3495 rpm. You can log a higher gear in low rpm/high boost to confirm as it should slip worse.
Also, you should not be running stage 2 without an upgraded IC, and let the car warm up before doing WOT logging man... your oil temp was only 122F... |
09-28-2022, 12:14 PM | #3 |
Rep 31
That's fair. Having some trouble finding time and space to do a pull and I had an opening leaving work today. To you're point, it was probably stupid not to warm up first. Do you think the clutch slip is related to the overboost? I'll try to do a better log soon to see if it looks any different.
09-28-2022, 12:48 PM | #4 | |
Rep 7,606
https://f30.bimmerpost.com/forums/sh....php?t=1732327 |
09-28-2022, 12:59 PM | #5 |
Rep 31
You also mentioned that I shouldn't be running stage 2 since I don't have an upgraded IC. Should I be running stage 1 93 with a catless DP though?
09-28-2022, 01:10 PM | #6 |
Rep 7,606
You should have an IC for stage 1 and IC+DP for stage 2. You can run any tune with a DP you just dont need it for stage 1; you will still get the performance gains though. On the other hand you really should not be running any tune without an upgraded IC. The car has no idea what IC/CP/DP hardware you have installed so you can technically flash any tune with stock parts even if its a bad idea
09-29-2022, 12:09 PM | #7 |
1296
Rep 3,533
Yeah definitely go back to stage 1 at least without an IC.. but you need one asap
10-02-2022, 10:59 AM | #8 |
Rep 529
An upgraded clutch is essentially a required mod on any f series n55 6mt car running stage 2 tune and higher. Either go down to a stage 1 tune or start planning out your clutch upgrade.
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
n55david1295.50 |
