BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.2" touchscreen for NBT EVO2 on f30
      10-22-2018, 06:53 AM   #23
FRANKLINDEE
Italy
Drives: BMW F30 2016
I've installed the G30 screen on my F30 and looks perfect you will just need to trim the holes where the brackets goes in order to slide on the right the screen in order to the 10,25 screen to fit properly and of couse you will need to fabricate with fibleglass the back pannel in order to match with the F30
i will do mine next week i will post some photos
      10-22-2018, 07:17 AM   #24
jojo7
Drives: F320i
subbed
      10-24-2018, 02:29 AM   #25
Victor1818
Drives: 328i xdrive
Originally Posted by jaydaman93 View Post
so my car is a 2016 which had the nbt evo hu with id4. i guess i upgraded to the nbt evo 2 hu with id5/id6lite. so im running a nbt evo 8.8" CID, just not the touchscreen cid.
how much did this cost? and where did you get the parts?
      10-24-2018, 04:41 AM   #26
FRANKLINDEE
Italy
Hi
I've purchased form a very good seller @naviprof
he will provide all necessary items to do the retrofit including coding
I've paid 1200 GBP all in
you will need to modify the dash (holes where the bracket with screw goes) , cut the original bracket and put new bracket to make it in straight position
i will fabricate with fiber the back to match the f30 dash hope to post some picture soon
let me know if you have other questions
      11-05-2018, 03:33 PM   #27
jojo7
Drives: F320i
Originally Posted by FRANKLINDEE View Post
Hi
Any update?
      12-24-2018, 02:45 PM   #28
jaydaman93
Drives: 2016 bmw 328i xdrive
Did you get the touchscreen to work? I am trying to install a f30 8.8" touch screen on my 2016 f30 with the id6_lite headunit. However, when i plugged in, it came up blank. i am not sure what needs to get coded to make it work. Any advice?
      12-25-2018, 04:37 PM   #29
MarkoSK
Drives: BMW G20 330eX
HU_ENTRYNAV2 > EXBOX > DISPLAY_VARIANTE = "breites_display"
HU_ENTRYNAV2 > HMI > DISPLAY_SIZE_RESOLUTION = "8.8_1280x480"
(the second one should be optional - the 1st one is important)
See this thread for more info (you have HU_ENTRYNAV2, which is a newer version of HU_ENTRYNAV).
Note that if you bought a touch screen and don't have navigation, it won't work. You have to get the non-touch version (part no. 65506822626).
EDIT: Here is a link to a thread with pictures of an upgraded screen on HU_ENTRYNAV2.
      12-25-2018, 05:18 PM   #30
jaydaman93
Hey I had an 8.8 screen with id4 NBT EVO in my 2016 F30 originally. I upgraded the head unit to NBT EVO2 with id6_lite which has the navigation and everything activated. I never had the HU_ENTRYNAV. Also, those two parameters you mentioned are already set to what u have listed. the screen is still blank. i had apix mode set to apix2, com_mode to mii. None of these changes turned on the screen. The screen remains blank. Do you think i got a bad screen?
      12-25-2018, 06:44 PM   #31
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
Are you sure that your screen came from an NBT EVO2?
Coding should be:
CID_APIX_MODE : apix2
CID_COLOR_DEPTH : 24
CID_COM_MODE : mii
CID_RESOLUTION : 1280 x 480
This coding should have been set in your NBT EVO2.
There is a Touchscreen coding entry as well.
      12-25-2018, 07:25 PM   #32
jaydaman93
Coding should be:
I tried all those settings and nothing shows up on the screen after i code that. Should i be coding first, then installing screen? I connected the screen first and then coded.
The screen i bought was from this listing by a member here. The link to the listing is here: https://f30.bimmerpost.com/forums/sh....php?t=1563906
Can someone please tell me if im doing something wrong here. I fdl coded those settings and the screen stays blank. the sticker on the back of the screen says F3X Touch
      12-26-2018, 10:46 AM   #33
Encanto
Encanto's Avatar
Screen should display right away if a) it is from an NBT EVO2 and b) it is not defective.
No coding should be necessary if your NBT EVO2 HU was connected to its APIX2 screen from factory. All the coding, except perhaps "touchscreen" should be in place already.
Does the screen shows "No Signal"?
      12-26-2018, 11:48 AM   #34
jaydaman93
The screen is just blank. Im starting to think that the screen is defective.
      12-26-2018, 04:11 PM   #35
Encanto
Encanto's Avatar
Agree.
      12-26-2018, 09:53 PM   #36
yjypm
yjypm's Avatar
Drives: 2018 M3 ZCP
The screen i bought was from this listing by a member here. The link to the listing is here: https://f30.bimmerpost.com/forums/showthread.php?t=1563906
I tried to connect my 18 M3's touchscreen to my gf's 17 330i and it was all blank too. By saying evo2 do you mean the HU needs to be MY18 since iirc MY17 comes with nbt evo HU
Instagram:catpupu_f80
      12-27-2018, 06:56 AM   #37
MarkoSK
Agree.
Not necessarily - when I upgraded my 6.5" screen to 8.8", the screen was black (i.e. didn't display the NO VIDEO message) until I coded it properly. I have the HU_ENTRYNAV unit (or NBT EVO ID4 as you guys refer to it in this thread).
      12-27-2018, 07:40 AM   #38
Encanto
Encanto's Avatar
NBT EVO 2 is MY2017-on.
Blank screen means two things: screen is damaged or voltage/coding is incorrect. A “NO SIGNAL” message display means that the voltage is correct but the coding isn’t.
The touchscreen display obviously requires extra coding but it seems that either the voltage was changed or the “NO SIGNAL” message was eliminated.
      12-27-2018, 11:56 AM   #39
yjypm
yjypm's Avatar
Drives: 2018 M3 ZCP
Oh I'm sorry I just remembered that it showed "no signal"
      01-10-2019, 01:36 AM   #40
vilord
Drives: E91, Tundra, TT, SV650
Just to correct a misconception here...
I have an evo / apix2 10.25 screen, which may act differently...
However, when the NBT was set for the 8.8, my screen just showed black and appeared to be "broken" as others have mentioned.
I actually got the screen cheap because the seller said it was broken / for parts.
Once I changed the coding to 10.25, but at the wrong resolution, it then said NO SIGNAL.
Once I changed the coding to the right resolution, it worked fine.
So... it was definitely black even with the right voltage and a working screen.
Now to figure out how to flash my evo... the istep on this thing is ancient... pre-id6 existing, and so my touchscreen doesn't do anything.
      03-05-2019, 12:16 AM   #41
glachhman3
Drives: SO M2
Id5 with touchscreen? I thought only ID6 works with touchscreens.
I'm retrofitting an f15 touchscreen to my 18 F80 (with 8.8 inch touchscreen). It's not a directly plugnplay, you need to cut the back of the screen and/or your dash, and also coding.
Currently the f15 touchscreen turns on but stays blank, I'll do some coding next week and I'll let you know if I can make it work.
You can also go for AvinUSA but I don't need android and i want something that looks more OEM. Also AvinUSA doesn't support touch in original IDrive, an no android screen work with IDrive touch.
Did you figure out the coding? I have the same issue.
      03-05-2019, 12:45 AM   #42
yjypm
yjypm's Avatar
Drives: 2018 M3 ZCP
I used BimmerCode to have it coded. Simply change HU's display size to 10.25 and resolution a level higher solves the problem.
Sorry I don't remember the exact parameters but it was pretty easy.
      03-05-2019, 07:31 AM   #43
glachhman3
Drives: SO M2
Damn I tried that. I wonder if this screen is a dud. I have backlight but nothing else. Trying to fit the screen from a 18 x5 into my 19 M2c. Gonna give it another try.
      03-05-2019, 07:49 AM   #44
vilord
There are 2 places to change the screen size and resolution.
If you search for RESOLUTION you should find both.
Here are the correct options for the 10.25 APIX2 touchscreen I have, which came from an X5:
CID_APIX_MODE = APIX2
CID_COM_MODE = MMI
CID_COLOR_DEPTH = 24bit
CID_RESOLUTION = 1440_540 (might also be CID_DISPLAY_RES)
CID_DISPLAY_SIZE = 10_25
DISPLAY_VARIANTE = breites_display
DISPLAY_SIZE_RESOLUTION = 10.25_1440x540
DIMMUNGSVARIANTE alte_dimmung
yjypm219.00
psyki285.00
