11-14-2017, 02:50 PM | #45 |
Rep 6
Just retrofitted everything to my 2013 F30, I have changed climate control panel and IKHA to IKHA3, all coded. Climate panel working, but always white digits.
After this retrofit I get issue - I am getting only cold wind into interior, even if I set temperature to 26C, it is still cold... Hot air start coming when I set 27-28C (maximum). ISTA-D see footwell and ventilation temperature at passenger side +70C, I think this is reason, any ideas what is wrong? Maybe I installed wrong version of IKHA3 (I have automatic climate control with heater) - or I should see any errors in this case? Maybe I have to do any additional wiring changing IKHA to IKHA3 as mentioned gribouille1210 before ? |
01-30-2018, 07:13 AM | #46 |
Rep 37
Hello my friends, i have a bmw f20 from 2016 (it has ikha3) but i dont have the dual-zone air conditioning... is it possible to install this one on my f20
i've tried to search on f20 forums but no luck... EDIT: btw i have this one : |
01-30-2018, 10:51 AM | #47 | |
Rep 2,302
More changes are necessary for that. |
01-31-2018, 08:18 AM | #48 |
Rep 37
02-02-2018, 12:41 PM | #49 |
Rep 34
hello i have a 2015 f30 the ikha 3 module is installed on esys but when i try to read code data it just comes up with a red error and wont read any ideas
02-03-2018, 11:50 AM | #52 |
Rep 2,302
At the start of the E-sys Launcher did you choose the right car series (F030 for your car)?
And at the connection window did you choose "VehicleInfo=F020" without DIRECT? And then "Connection via VIN"? |
02-04-2018, 05:56 AM | #53 |
Rep 34
thanks for reply yes right car selected can get into the rest of the stuff ie kombi hdu and so on as i have been coding other stuff. ivwas wondering if itvis because i upgraded the hdu system to pro with the larger screen ??
02-04-2018, 08:44 AM | #55 |
Rep 34
tried it again and its went in. not sure why it wouldnt for the last few days coded it but still orange have i the right head unit ??
part no.. 6411 9320 341 01 |
02-05-2018, 09:09 PM | #62 |
Rep 139
Drives: '15 F36 435i / '07 E90 328i
Hmmmm.. My F36 has a build date of 9/14, but when I look at the IHKA module in Bimmercode it shows up as "IHKA VA02". Is that just because it's Bimmercode I'm looking at and not e-sys, or is the IHKA module in the car not the IHKA3 even though it was a late 2014 build?
03-02-2018, 05:29 PM | #63 |
Rep 58
Hi everybody, nice to meet you, I'm Enrico from Italy.
I have a 07/2012 build date 320d Luxury F31. I bought a Automatic air cond unit code 64119363546 Only after reading this post, i saw that is necessary a IHKA3 ECU to make it work. I have some questions to manage it: Does it need a change of pin of connector of FEM or IHKA? It's a simply CODE? What is the right part number of the ECU IHKA3 i must buy to make it work? Thanks to everyone will try to help me. |
04-06-2018, 12:50 PM | #65 |
Rep 4
Hi.
I retrofit white clima controller to my F21 07/2014 pre LCI (with IHKA3 factory fitted). I VO Code IHKA3 but my CON Ecu still have Error Code : 801410 CON:no current coding data stored 801411 CON:control unit is not encoded for the vehicle How I can VO Code CON ECU (not available in E-SYS) ?? Kind regards. |
04-07-2018, 01:54 PM | #66 | |||
Rep 10,473
From other thread steps are: 1) Install IHKA3 Controller Unit Known to work for mod: 64116820235 64119390099 64116842986 2) Install LCI Screen Display unit 3) Move the IHKA ECU connection from the slower KCAN Network to the higher speed KCAN2 Network by moving the 2 wires from pins 22 and 23) on FEM A173*7B to pins (10 & 11) on FEM A173*10B. There may or may not be wires already connected to pin 10 and 11 depending on if your car has HU_NBT Professional with Navigation or not. Make sure to properly connect the H to H and L to L when reconnecting and wires are not reversed. Quote:
5) update car to latest istep level 6) Performed a "TAL-Calculating" and then a "TAL-Processing" to update the IHKA3 BTLD, SWFL and CAFD files. 7) Run Rheingold to clear all warnings and errors before starting your vehicle. 8) Start vehicle and run it until the A/C LED stops blinking. Complete thread at http://f30.bimmerpost.com/forums/sho....php?t=1274250 |
