12-02-2021, 02:59 AM | #1 |
Rep 497
F33 LED Headlamp retrofit
Can anyone tell whether I can replace my existing Xenon headlamps with LED units? I'm not thinking about changing just the lamps [I would say bulb] but the entire headlamp moulding.
I have changed the Xenon lamps for Osram Night breakers, which are a vast improvement over the OEM lamps, they're as not as bright as I would like - as I get older the worse my vision at night becomes. Other than buying the lamp units and drivers, getting them coded, what else would I need and most importantly is this feasible? |
12-02-2021, 03:30 AM | #2 |
Rep 8,081
Why on earth would you want to? The OEM Xenon headlamps are much better than LED.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
12-02-2021, 05:27 AM | #4 |
Rep 1,162
The perceived light output from the Xenons and the Adaptive LEDs are very similar. I went from adaptive Xenon to Adaptive LED when I changed from my 335 to the 440 and while the behaviour of the lights was different, the LED adaptive function was much more refined for instance overall vision was very similar.
Generally the Xenons were better than the standard LED in my view. And both are leagues ahead of the old halogen units. In your circumstance having a brighter headlight might not be the solution to the problem. As we get older the accommodation of eyes reduces, ie the eye takes longer to recover between periods of brightness and darkness. This is especially a problem at night with oncoming traffic for older people. If it's becoming too much I would recommend talking to your optician about it as they might be able to assist before you spend hundreds or even thousands on replacing your headlights. |
12-02-2021, 06:45 AM | #5 |
Rep 8,081
Could be - I'm currently in a G21 330i in Mineral Grey, around the Keresley End / Corley area.
Ian
12-02-2021, 08:10 AM | #6 |
Rep 497
Thanks for your replies, its weird but the Xenons on my previous 2012 E92 produced a white light providing a great view of the road in all weather conditions and even having swapped the lamps for Osram Night Breakers the light output is nowhere as good as it was with the old car. Might be my rose tinted memory.
I will be getting my eyes tested as I've noticed that I am less able to judge the speed of the vehicles ahead of me in the dark so I tend to leave a large braking distance ahead which rapidly gets filled by other cars - I've resigned myself to driving more slowly. |
12-02-2021, 01:20 PM | #9 |
Rep 1,475
I asked BMW this recently and they said there's a lot involved to upgrade from Xenon to LED, you're probably looking at £3-4k for parts/labour to get it right.
