12-15-2016, 02:15 PM | #1 |
Rep 144
Coding combos?
I like that there's the ability to code the car to close the sunroof when the rain sensor gets tripped on.
I am interested in two other "combos", and wonder if they can be coded. 1. When the auto headlights turn on, I would like the fog lights to turn on with them automatically. I prefer the look with those lights on but hate having to turn them on every time. 2. When I turn the heated seats on, I would like the heated steering wheel to also turn on. Are these possible through coding? These also might be iDrive settings, but I've tried to look through there and can't find them. |
12-15-2016, 06:29 PM | #2 | |
Rep 8,364
There is coding for Rain sensor, but I do not know anyone who has actually tested it. The only coding option is to turn on fog lights as welcome lights or allow fog with high beam or parking lamps. Set this way due to regulations against running fogs without inclement weather. There are options for remembering heat / cooling / massage settings for seats / steering for designated shutoff interval (eg, Shutting down vehicle ==> run quick errand (< designated period) ==> start car & feature still enabled). Never looked for pairing cold weather options. |
12-17-2016, 12:04 PM | #4 |
Rep 191
Never looked for pairing cold weather options.[/QUOTE] i read on here the save timeout is 15 mins, anyone know where to change this setting? tia
2012 335 2016 435 2019 440 GC |
12-17-2016, 06:58 PM | #5 |
Rep 8,364
12-18-2016, 09:01 PM | #6 | |
Rep 191
i tried coding that in the FEM but it didn't seem to work according to this page (google translated) https://www.drive2.ru/l/7492089/ he could get the heated wheel to stick but not the seats a user suggested coding REM as well and it will work, but i coded both FEM and REM and still not saving after the 15 mins... thoughts?
12-18-2016, 09:18 PM | #7 | |
Rep 8,364
Coding will depend on your vehicle packages. For example, if you have adaptive xenons or LED's, then lighting changes are done in LHM/TMS or FLE rather than Fem_body. Equally, if you have comfort seats, there are SM (CAFD_000000B5/ CAFD_000000B6) settings. Fem_body is the main module, but REM usually controls rear functions like rear taillights and windows. |
12-18-2016, 09:52 PM | #8 | |
Rep 191
figured it out in addition to the FEM codes, you need to also code the SM module 3000 SA_MEMORY_ZEIT - > Set to Wert-Dauer cheers!
12-18-2016, 09:53 PM | #9 |
Rep 8,364
