BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 420i F36 M Package, pushing 300+hp without damaging the engine
      05-24-2024, 01:25 PM   #1
YurisBMW
Drives: BMW 420i F36
  [0.00]
Hi everyone, i own a 420i f36 with a b48 as engine, is it possible to tune it up to 300+hp without shortening the lifespan of my engine/damaging it in general? thanks in advance
      05-24-2024, 06:03 PM   #2
autoAER
Drives: Monaco Blue 335i
2011 BMW 328i  [0.00]
2006 BMW 330i  [7.75]
Hi,
You’ll need a tune and aluminum charge pipe. I recommend these:
Charge Pipe
JB+ Tune
With these you’ll safely be around 300 at the crank, provided the rest of the engine is up to date as far as maintenance. I would recommend going through the cooling and ignition system first (all coolant hoses, reservoirs, spark plugs, ignition coils.
Current: 2006 330i Mystic Blue 6MT, 2011 328i Coupe Titan Silver
Ex: 2006 330i Barrique Red, 2008 335i Monaco Blue, 2011 335i Deep Sea Blue
      05-25-2024, 01:57 AM   #3
YurisBMW
  [0.00]
Originally Posted by autoAER View Post
Hi,
Charge Pipe
JB+ Tune
what about launch control? is it possible to install it on my car? sadly i dont have the option
      08-19-2024, 03:22 PM   #4
f36user2708
Drives: F36 420i Gran Coupe 04/2017
I don't think so, I've seen alot of threads about b48b20a engines having weak pistons. The issue seems to be the high compression rate of 11:1 that doesn't alow for safe tuning in general. Even going for 20% more power could be risky.
cfm56d7b6355.00
      08-19-2024, 08:16 PM   #5
cfm56d7b
My suggestion would be to proceed with extreme caution and consider the consequences if the engine decides to retire early.
B48a20a engine is used in many Mini models and 320i and does have a higher compression ratio. It _could_ be tuned to 260 hp and even that would be a stretch.
b48b20b is the engine you want to tune. It's used in 330i and Mini JCW/GP. It has lower compression ratio and stronger pistons.
