BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > Classic BMW (Pre-2005 Models) > My 520iA Road to 528iA '91
      06-16-2024, 09:49 AM   #45
zener
BMW enthusiast since 2004
604
Drives: E65 730d, F10 520d, E34 520i
Took the oil pan out and found problems... Guess it's time for a new engine.
      06-20-2024, 03:44 PM   #46
zener
604
Got armrests back and they look very nice.
Im looking for e39 528ia to take engine and transmission for this.
      06-20-2024, 05:01 PM   #47
Tambohamilton
Drives: E91 330d
Damn...
      06-28-2024, 12:34 PM   #48
zener
604
Bought 5hp18 from e39 and made a deal of m52b28.
s_ribs122.50
      06-28-2024, 08:18 PM   #49
IcewaterPete
IcewaterPete's Avatar
Drives: 2020 F33 M Sport, 2021 M2C 6MT
Sorry to see the engine issue, but glad to see you are not quitting. Keep going!
      06-29-2024, 02:50 AM   #50
zener
604
I was planning to do swap anyways but not this summer... Did not wanna spend the money yet on engine, but as engine was found localy and cheap I had to buy it.
      07-08-2024, 12:26 PM   #51
zener
604
I found same color trunk lid that looks really nice condition and seller says it's rust free. Very good find for 120bucks.
I will get the engine this weekend.
      07-13-2024, 10:39 AM   #52
zener
604
M52 powered alpina trailer.
Mani5917104.50
      07-13-2024, 12:50 PM   #53
Tambohamilton
Drives: E91 330d
      07-26-2024, 04:51 PM   #54
zener
604
Not much have happened. Engine is somewhat stripped down and somewhat clean. Tried to change valve stem seals with compressed air but pretty much all cylinders had one or two valves leaking because of carbon build up. So it was nada. Now engine is at my home garage on engine stand. Gotta try the rope trick for valve stems. And order all the parts to get it ready for the swap.
I'm having hard time finding E38 728i m52 oil dip stick tube which should perfect for this. New one costs a bit too much for my taste.
Back on the road summer 2199?
Been fixing E65 lately. First starter broke down and now electric fan. Without it ac did not work. So money that was itended for this when't in to "dailies"
      07-27-2024, 02:34 AM   #55
Tambohamilton
Drives: E91 330d
Ah, the joys of older BMWs...
      07-27-2024, 05:14 AM   #56
zener
604
Well, it has over 400 000km already, so not bad. I also had to replace f10 windshield so more money in to daily cars.
      07-31-2024, 01:15 PM   #57
zener
604
Let's see how it turns out after some wash and polish.
      08-01-2024, 01:09 PM   #58
zener
604
Turned out pretty nice.
      09-22-2024, 07:48 AM   #59
zener
604
Valve stem seals replaced on the B28. Next step is to do the rod bearings. Then put new timing guides in and timing cover with new gaskets back on. Then it is pretty much ready to start swapping the engine as many parts are needed from the old engine so cant really do more for B28.
I will also use cam trays and new lifters from M50. So... let's turn it around.
      09-23-2024, 01:12 PM   #60
zener
604
Opened two rods and looks ok to me for and old engine. Crank also looked good.
Gotta get plastigauge and install new bearings if clearences are ok.
