BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Experience with 10.25" android 7.1 HU's
      08-12-2019, 09:26 AM   #2685
babagurgur
Drives: 2014 328xi 2.0T
Originally Posted by __fred__ View Post
Yes, it’s for 7.1. You can use it.
Hey Fred, is it possible to modify MCU so rear cam stays active for longer?
      08-12-2019, 03:42 PM   #2686
ErikE87
Drives: BMW E87
Originally Posted by koutsouk View Post
Well i managed to do it !
I modified the mapApkLst by adding the two app ids .
I went to factory settings and update the apk list .
Of course i put the mapApkLst into OEM folder and into a usb stick first.
So i think that you can have success by deleting app ids and updating the list.
You can try it .
I managed to do it as well by updating the /data/local/mapapklst.txt file.
I only struggle with the volume settings of my device. The navigation output from the left speaker is now very loud and when I get a call (it also only comes from the left speaker) the volume is very low although I set the volume in the audio settings to max for calls. Do you have any idea how to set all the volumes correctly?
      08-13-2019, 01:19 AM   #2687
freddy_kruger
Drives: BMW 320d E90
Originally Posted by babagurgur View Post
Nope not really, YouTube is hard to control for stuff like this.
If you want to watch downloaded videos, you can use MX Player to set screen aspect ratio if video is not in our aspect ratio which is 2.39:1 I think.
Thank you . I'll try
      08-13-2019, 06:25 AM   #2688
floc
floc's Avatar
Italy
73
Drives: BMW M2
2017 F87 M2  [0.00]
any way to enter the recovery of these unit? I need to do a full wipe, it doesnt recognize my screenlock pin anymore... The back reset button does only a soft reset
      08-13-2019, 07:30 AM   #2689
Kri
Austria
1084
Drives: E87
Recovery mode does not help because it has no hardware buttons to move through the menu.
only way would be via ADB, has usb debugging been activated at some time by you ?
Chri
      08-13-2019, 09:40 AM   #2690
smahel
Drives: MINI Cooper, 2020 X1
There is one way: if you have Android 7.1 rename px3.img to px3_reset.img, if you have Android 8.1 rename px6.zip to px6_format.zip. Upload to USB flash drive, insert into slot. If you have an SD card inserted, remove it. Connect power to the unit. The factory reset should be complete. Unfortunately I don't have Android 9, so I can't help with it....
px6.zip:
hxxps://mega.nz/#!VRkSCSpT!1TiqSoyrnT0DBrj52lilb3GRcv3yH3tIlQsbrfE Uz1Y
px3.img:
hxxps://drive.google.com/drive/folders/1mWtI61GU8GReGQ-PjwcjBjFXM34EGaoE
Kri1083.50
      08-13-2019, 11:16 AM   #2691
Pondaire
Drives: 2013 328i
px6.zip:
px3.img:
But this is not for all MCUs, right? Or is it universal?
      08-13-2019, 11:31 AM   #2692
smahel
In my opinion it has nothing to do with MCU, it's an android daugther board thing: hxxps://github.com/chinesebmwheadunits/chinesebmwheadunits.github.io/wiki/Hardware
however, each android daugther board has its own firmware, eg you cannot use px3 for px6 and vice versa, even if they are mounted on the same MCU !!!
      08-13-2019, 02:26 PM   #2693
floc
floc's Avatar
Italy
73
Drives: BMW M2
2017 F87 M2  [0.00]
once in recovery, scroll should be brief press of reset, select long press.
Anyway, my platform is NOT px3 nor px6, it's a "newer" snapdragon 625 , not a rockchip. So no way for me with the well known zip in the wild, I need the recovery to format and do a full wipe, or do anyone have the correct zip for snap 625 android 9 headunit?
It happened I set the screenlock pin (my google account is under mdm so I need it) and now the unit doesnt recognize it :/
      08-16-2019, 04:02 AM   #2694
wacky007
wacky007's Avatar
Drives: F30 2012 320i
px3.img - 20190122
Does anyone have that image?
Please reupload so I can add it to Google Drive collection
      08-16-2019, 12:32 PM   #2695
Kuj0n
Poland
Drives: F31 LCI 320xdA B47
I have e91 with CCC but i will share...
I have installed new unit
Kri1083.50
      08-16-2019, 04:06 PM   #2696
Kri
Austria
1084
Drives: E87
Uhh nice a newer version, you maybe have a download / source of it ?
Chri
      08-16-2019, 05:55 PM   #2697
Frankly30
Seems like this Firmware is only for Snapdragon units..
      08-17-2019, 02:21 AM   #2698
Kri
Austria
1084
Drives: E87
Yep it is, i also have a Snapdragon HU now, and There are still Bugs at 2.0.5
Chri
      08-17-2019, 03:21 AM   #2699
floc
floc's Avatar
Italy
73
Drives: BMW M2
2017 F87 M2  [0.00]
any chance to get these files for snapdragon headunit?
      08-18-2019, 08:23 AM   #2700
Kuj0n
Poland
I just received and installed unit, don't have any update files.
For now I have problem with
- not working simcard
- bluetooth can't connect with my iphone
- I can't choose any custom navigation app to make a "navigation" shortcut (except googlemaps.. but I am not using it)
- My usb DAC is not working with this unit... sound is dissapearing after connecting do USB port
EDIT. I have fixed problems with USB DAC by removing internal AUX connection between android and CCC.
      08-21-2019, 02:46 PM   #2701
rafaelSorel
Drives: BMW X1 F48 116d
Welp, I received my unit today and was about to install it... I kept getting No Signal, so I checked the connectors and everything but it still kept "No Signal". Until I came to the idea to unplug the retrofit Nav from my glovebox and directly hooked upthe LVDS cable from my Head Unit. It showed up now. But I would't be able to use that Navbox anymore
I already tried messing with the Factory Settings but no luck. Any ideas?
Hello guys , I have got the same issue as described above, "no signal" on BMW OEM interface.
Any clues of what may cause this kind of behaviour ? I have check the LVDS connector which is correctly plugged.
      08-21-2019, 02:50 PM   #2702
adrien78
France
52
Drives: BMW F30 335i
On BMW interface? Long press MENU on idrive, see if it switch to BMW side.
      08-21-2019, 04:20 PM   #2703
rafaelSorel
That is what I did, I have got no signal on Bmw oem side:
      08-22-2019, 02:27 AM   #2704
adrien78
France
52
unplug/replug all of the connectors, be sure they are properly connected, I had this problem too, due to a bad connection.
      08-22-2019, 04:05 AM   #2705
rafaelSorel
Ok I will try to this, in the meantime, I have seem somewhere that may be the car type is not well configured in the android settings menu ?
      08-22-2019, 09:34 AM   #2706
rossjmccarthy
Drives: BMW F30 330e
Hoping someone can help here as google has let me down.
A firmware update has left by 7.1 AVIN unit dead. MCU is fine but SOM has lost its image and when I swap to the android screen, I get "No Signal" Reversing screen is working away fine, as is the idrive, so the underlying MCU looks ok.
I have tried bootable USB, booting SD, renaming PX3.img to PX3_reset.img, format etc
I have concluded that the SOM is wiped completely.
Does anyone know a source for a replacement SOM? Mine is a ZXW_870 and Ver_03 with 2 rows of pins on both the top and bottom of the module.
Any pointers would be much appreciated.
