05-06-2019, 03:07 AM | #23 | |
Coding ECU's remotely
445
Rep 1,176
Go to the connected drive menu and see if you can access the connected drive store
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
05-07-2019, 10:06 AM | #24 | |
Rep 50
I guess it could tell you if your telematics unit is back on the old 2G service that has been shut down, but if it's 3G or higher it will call 911. Last edited by cjsansom; 05-07-2019 at 10:11 AM.. |
05-08-2019, 12:46 PM | #25 |
Rep 535
I have recently done the retrofit and can confirm this will work. It will give your exact location and correct VIN (not ATM vin).
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors Past: 2013 750i xdrive, 2008 535xi |
05-10-2019, 08:50 PM | #26 | |
Rep 25
Basically, trying to do something that relies on the sim card working. But hey, he's in Sri Lanka, who knows how communications are over there |
07-18-2019, 02:59 AM | #27 | |
Rep 6
Nbtevo atm
Eu atualizei o meu idrive para NBT evo(com GPS interno) mantive o velho TCB (mas gostaria de atualizar para ATM ) consigo com esta configuração fazer mirror miracast (android). , com Iphone só fica disponível Apple Carplay Good Morning I upgraded my idrive to NBT evo (with internal GPS) I kept the old TCB (but I would like to upgrade to ATM ) with this configuration it's possible miracast mirror (android). , with my wife Iphone only available Apple Carplay |
07-18-2019, 08:34 AM | #28 |
Rep 36
Hi guys,
I'm thinking to retrofit the NBT EVO ID6 + ATM with same donor car. There is a listing on eBay who is selling the full retrofit kit with all required stuff. My question is: 1. I have NBT with TCB (active 3g sim) from factory, If I but the EVO and ATM should I keep the donor car vin in both or change to mine in both? 2. What will be the difference between both? 3. Yes seller said he can change vin to my car in both EVO and ATM (is that possible as my understanding was you can’t change in ATM vin?) 4. I guess I only need the ATM emulator only if I change VIN in EVO and keep donor VIN in ATM? 5. IF I go with my car VIN in both EVO and ATM will I'll be able to access all services or will that restrict any apps or options? 6. If I go with Donor car VIN in both EVO and ATM, will that create any issues or access restrictions at any stage? Please if you can help, as I can’t make my mind due to unclear of above and also it will cost me around 1200 Euros Many thanks |
07-18-2019, 09:51 AM | #29 | |
Rep 59
I have researched the same upgrade as you guys -- ID3 (NBT/TCB) to ID6 (NBT EVO/ATM). My goal is a full seamless upgrade, without loss of any functionality. From reviewing all relevant threads and posts, it was clear that transplanting the head unit, touch display, HSD (video) cable that connects the two, and touch iDrive controller (if you choose) is the easy and straightforward part. The main issue is the ATM and related wiring. After contacting a bunch of sources, I have finally found a guy who can provide both solutions! His name is Sanel, you can reach him here: https://f30.bimmerpost.com/forums/member.php?u=298647 The cleanest way is to swap chips from your TCB into an ATM, thus making it 'native' -- both NTB EVO and modified ATM can then have your original VIN. You then need additional wiring to make it all work, and figuring out what exactly was involved here and where to buy/how to build my own adapter harnesses was another challenge. Sanel offered to sell me the correct style ATM, all necessary wiring, and instructions, including which ICs you'll need to transfer between the boards, for a very reasonable cost. My friend is a circuit board designer, so swapping chips is not an issue for me, but if you're uncomfortable with it, perhaps Sanel would be willing to do this for you as well. The wiring he would provide is for connecting the ATM to the new headunit. To quote him: At the moment, there is a HSD wire that goes from the headunit to the TCB for USB communication. You will ditch that and will connect it via the new harness that connects to the EVOs OABR connector and then back to the ATM for Ethernet communication (this is how the ATM informs the HU of GPS location). This involves transferring pins between connectors but it is not very difficult (all covered in the instructions). For the GPS, you'll have two options: 1. Use a Fakra extension cable (I will provide) that will plug into the blue GPS connector that goes into the headunit and lead that back into the pink connector on the ATM. It would route the GPS signal that currently goes to your headunit, instead to the ATM (just like from factory). 2. You can use a generic GPS antenna and connect that to the pink Fakra on the ATM.' For coding, I'm going to use Steve Ma at codemybimmer.ca -- a great guy: https://www.codemybimmer.ca/ My sister's F15 X5 still has a few months left on the factory warranty, so I haven't yet pulled the trigger. But now that I have a complete 2-stop solution between Sanel and Steve, I'm finally comfortable proceeding with the upgrade. |
07-19-2019, 01:19 AM | #30 | |
Rep 10,473
Why does that matter? Most of the TCB units are 3G. And TCB was used in the NBT units up until roughly mid year 2015. If your TCB unit is a 3G unit (again, most are), even if you move the Chip/SIM over to an ATM, it will be a boat anchor at that time. So it comes down to a decision on how long you intend to keep your car. If it's over 2.5 years, moving the Chip may not be the best option. Last edited by IK6SPEED; 07-19-2019 at 01:21 AM.. Reason: You |
Wood11221.50 imperfectluck425.00 |
07-21-2019, 05:29 PM | #31 | |
Rep 535
This is the cabling I used - ebay seller topdonas1 BMW F SERIES NBT EVO ID5/6 ATM RETROFIT WIRING LOOM + CAN FILTER PLUG & PLAY Make sure you have a full oabr connector unless you buy a preprogrammed nbt evo hu. I learnt that the hard way. Last edited by sj22; 07-21-2019 at 06:57 PM.. |
07-22-2019, 09:09 AM | #32 |
Rep 14
hey sj22 , what do you mean by 'full oabr connector'?
I've been reading about this for weeks, I thought I had it all figured out, I talked to Steve and he offered to help - and today I went ahead and ordered a retrofit package (head unit, screen, idrive controller, atm, wi-fi antenna). I was aware I would eventually need a new harness for the ATM - but I wasn't sure which one exactly, so thanks for the details. so one question answered, another one raised: how can I tell if I have a full oabr connector - and what are the implications, if I do not? edit: I just realized, I've never considered using the donor ATM vin. what does that imply? I would like to avoid swapping the chips between my TCB and the donor ATM, but not sure what that means. Last edited by born2lose; 07-22-2019 at 09:16 AM.. |
07-24-2019, 04:25 AM | #33 | |
Rep 36
HI flipper325, Thank you very much for a detailed information and it is well clear now what needs to be done. I'm getting a goo deal with NBT Evo ID6 with ATM from same donor car and with all retrofit wiring kit. I might keep the donor car VIN on both to ensure I can access all functionality. I just finished my reverse OEM camera retrofit in my car so hopping to kick start EVO project early next month will keep you posted. Thanks! |
07-24-2019, 04:05 PM | #34 | ||
KendrickOak
359
Rep 201
07-27-2019, 04:15 PM | #35 |
Rep 14
ok, I bought an id5 unit with a matching ATM. now I need to choose between the 2 options:
- transfer the esim from my tcb to the atm. I can’t find any instructions on how to do that, can anyone help? I read some people have been succesfull, I would really appreciate any assistance; - keep using the donor’s vin - in which case, I should use a can filter. I’m not sure what to look for, can someone recommend such a filter? |
08-14-2019, 01:55 PM | #36 | |
Rep 14
08-14-2019, 11:36 PM | #37 |
Rep 535
08-17-2019, 12:51 PM | #38 | ||
Rep 590
08-21-2019, 07:34 AM | #39 |
Rep 159
Hey Bobfish is it possible to install NBT EVO with ATM to the car that has no navigation from factory? I guess if I keep donor VIN in both units with emulator I can continue using Connected Drive with donor VIN?
11-21-2019, 02:05 PM | #40 |
Rep 73
Hello all, I am undergoing a ATM retrofit, I am however encountering one persistent problem. The Update services icon is grayed out, Ive scoured the internet looking for help. It appears the common consensus is either Vin mismatch (which its not per tool 32 both are the same vin). Or antenna cable / no signal, Tool32 reports 2 on signal so that leads me to believe antenna is fine. I also reinstalled the tcb into the car and verified 3g operations. Now too what is working, Sirius XM, navigation, gps, apple car play apps ect... Whats not working is Wiki, Weather, RTTI pretty much anything that rely's on the internet isn't working.
As previously stated the update services is grayed out, so I suppose thats expected. My understanding is the car proxy's all traffic on the ATM too BMW. The atm also pings a BMW dependent server once the packet makes a successful round trip the update services icon goes white and you can click. Im more or less at a loss as too what the problem can be here as im getting conflicting results. One would think if it had a problem talking with the LTE network tool32 would report a signal level of 2. If I had a problem with cabling (obar) then GPS wouldn't work nor would xm id also receive a sos malfunction if obar wasn't working. Which only leave Vin mismatching and per esys they match my actual f32 2013 build vin. I found that surprising as everywhere on the internet refers to donor vins for ATM, so either im not pulling the vin right in esys or Bimmer retrofit figured out a way to change the vin. Lastly this unit was coded by bimmer retrofit, so pretty sure that portion was not messed up. I have done no writes too any ECUs so shouldn't be locked either, all ive done is reads to atm and hu for troubleshooting steps. |
11-21-2019, 05:21 PM | #41 | |
Rep 10,473
That's why people use the VIN of the vehicle the ATM came out of. Furthermore, the HU VIN must match the ATM VIN to work together. That would explain to me why some of your items work but connected drive does not. |
11-21-2019, 05:43 PM | #42 | |
Rep 73
11-21-2019, 05:49 PM | #43 | |||
Rep 10,473
Once you (or bimmer retrofit) coded your car's vin to the HU and ATM, the original VIN of those units are gone. They were written over. So you will most likely never find the original VIN of the ATM. Bimmer Retrofits does not know the ESN or eSIM of your TCB if you never gave it to them. But that's immaterial in the issue you have as one cannot duplicate your eSIM or ESN. Quote:
Likewise, you apparently have no idea if the ATM was locked to the original owner's account as just about all are, meaning even if you had the original ATM VIN, the ATM still would not have worked for you. https://f30.bimmerpost.com/forums/sh....php?t=1664887 |
12-25-2019, 03:57 PM | #44 |
Rep 5
Hi, good night! sorry for bothering.
My car f30 14/14 cluster 6wa and retrofit EVO - ATM with emulator, all online and remote services worked! I put a new 6wb cluster and the remote services stopped working. I do not receive the verification code to activate in the app. can you help me with any tips? I am from Brazil, I am not unable to solve. Help me, please ! Obs.: I installed the 6wa cluster again and the remote service did not work again. |
