05-06-2018, 08:46 AM | #1 |
Rep 76
Driver Restraint System Malfunction
I resently installed a M Sport Steering Wheel and now am getting this error. Airbag resistance too high error code 930910. Any help would be appreciated. Thanks in advance.
2014 F30 328i XDrive: BM3 Stage 1, Injen Cold Air Intake, Custom Dual Exhaust, and lowered on H&R Sport Springs.
05-06-2018, 10:26 AM | #2 |
Rep 10,473
05-06-2018, 10:30 AM | #3 |
Rep 76
I bought the complete steering wheel on ebay. Here is the link.
https://www.ebay.com/itm/BMW-3-SERIE...53.m2749.l2649
05-06-2018, 02:42 PM | #4 | |
Rep 10,473
05-06-2018, 05:25 PM | #6 |
Rep 76
Does this points to a faulty airbag? I switched back to original steering and no errors so far.
05-06-2018, 06:22 PM | #7 |
Rep 10,473
05-06-2018, 06:33 PM | #8 |
Rep 76
Is there a way to check and see if it's counterfeit?
05-06-2018, 06:36 PM | #9 | |
Rep 10,473
As I am not there, I don't know if you wiring is correct. So just making you aware of possibilities to ask the seller. |
05-06-2018, 07:08 PM | #10 |
Rep 76
Here's a few pics of the airbag.
05-08-2018, 05:10 AM | #11 |
Rep 1,976
Drives: 2020 G20 320i M Sport
Do all the connectors fit properly? I had another customer with a similar issue and he ended up purchasing one from the dealership and we were able to clear the error afterwards.
I'd also check to make sure that this airbag isn't part of this recall. https://www.bmwusa.com/safety-recall...ta-airbag.html
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
05-08-2018, 08:48 AM | #12 | |
Rep 10,473
Only by VIN originally installed in. Which is another reason to be dubious of eBay sellers who have no idea where the airbag came from or are willing to give you a bogus VIN that could be found from a multitude of places, not the least of which, the for sale or lease section of Bimmerpost. I sold my MSport Airbag from my personal 2013 vehicle for $650 to a member here. They stated that they could find a used one on eBay for $100 less. I told them to go ahead and purchase that one if they wanted. After doing the research, they were very glad they purchased mine. This is off topic....but a heads up. |
05-08-2018, 05:10 PM | #13 | |
Rep 76
05-08-2018, 05:12 PM | #14 | |
Rep 76
05-10-2018, 12:39 PM | #15 |
Rep 76
Update!
Brought it to BMW as am still under warranty and they replace the Steering Column Switch Cluster/Clock Spring.
05-20-2018, 09:32 AM | #16 |
Rep 1,953
Drives: 2013 328i xDrive
Huh.. Interestingly enough I had the exact same issue as you, fixed the exact same way, with a steering wheel light from the exact same seller on eBay. Not sure what to think on that. I will note that I didn't get the error until half a year after installing it though.
05-21-2018, 01:06 PM | #17 | |
Rep 76
05-07-2019, 09:19 AM | #19 |
Rep 142
05-07-2019, 11:33 AM | #20 | ||
Rep 1,953
05-07-2019, 08:06 PM | #21 | |||
Rep 142
Guess I won't use my horn anymore! |
05-07-2019, 08:22 PM | #22 | |
Rep 1,953
