BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Climate Control Unit
Studio RSR
      08-11-2019, 11:26 AM   #1
JMatthewK
Drives: F30 328i xDrive
I have a 2015 F30. Been seeing the climate displays but with the lettering/numbering appearing in white. Anyone know where I can get one? Attaching my current with the orange.
      08-11-2019, 12:24 PM   #2
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
eBay.
But your car must have IHKA3 so you'd have to verify it has that. This topic has already been covered extensively in these forums, so do a search.
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      08-11-2019, 03:22 PM   #3
JMatthewK
Originally Posted by ooshnoo View Post
eBay.
How would I find that out?
      08-11-2019, 05:37 PM   #4
John in VA
Drives: 2015 228i M Sport
Try searching using "IHKA3" in the search box. You might find posts in this section:
https://f30.bimmerpost.com/forums/fo...play.php?f=426
Good luck!
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      08-11-2019, 07:55 PM   #5
IK6SPEED
Drives: BMW M3 / AH3
eBay.
If you have orange led and not the switchable white, you do not have IHKA3.
You need to read this entire thread to retrofit everything.
https://f30.bimmerpost.com/forums/sh....php?t=1274250
      08-12-2019, 09:24 PM   #6
JMatthewK
eBay.
So I'm told that I have it (the ability to switch lighting from classic (orange) to sport (white) is what I'm told is confirmation of that.
Is that not the case?
      08-12-2019, 09:27 PM   #7
IK6SPEED
eBay.
Correct.
If you can switch colors on the climate control unit you have IHKA3 in your car.
IHKA units do NOT have that ability.
      09-07-2019, 11:52 AM   #8
Onizukachan
Great Teacher
Onizukachan's Avatar
1086
Drives: 06 e91 325ix
2006 E91 325ix  [10.00]
2006 Mini r53 JCW  [0.00]
2005 Mini r53  [0.00]
you have a 2015 so you should have ihka3 already, you just need to replace the control head for one that has the bicolor leds and code it.
its one of the first things i plan to do when our 2015 arrives along with the LCI panel.
you need to swap back before taking the car to the dealer so dont get rid of the orange one
      09-08-2022, 03:40 PM   #9
Candelstick
Drives: 2014 328d
Climate control and radio panel not powering on
I have don't no modifications on the car I checked the fuses and they are all good. When I turn my car in now the panel doesn't light but but after about 5 min it will turn on.
I also have a weird AC issue where it will work and blowCold air as long as I don't take it past 3 otherwise it blows warm but the low pressure side is high at 50-60 and I can hear it turning on and off. But if the panel turnes on the screen light will blink.
The mechanic that I called said that sounded really weird and asking if it took on water and it did not. Is there anything I should
Check and how do I do it?
