12-22-2019, 08:43 PM | #67 |
Rep 205
Drives: 14 F30 335i xDrive
You're probably right. I never measured the ones that came on the car. When I saw the bushings that where originally in the arms that VAC sourced, while developing these, they didn't look offset.
12-22-2019, 08:49 PM | #68 | |
Rep 205
Regarding maintenance and downsides; if you read my posts and the ones from the others, other than a little more NVH, there's not much of a downside. Personally, I didn't hear much more noise, maybe a little on some rough surfaces. Mostly just more feeling through the steering wheel. If you can live with that, it's a transformative part for your car. |
eleven11374.50 |
12-23-2019, 06:32 PM | #69 |
Rep 1,433
Awesome. Thanks for the reply.
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
12-24-2019, 12:34 AM | #70 | ||
Rep 1,649
12-24-2019, 10:50 PM | #71 | |||
Rep 205
Happy Holidays!! |
09-30-2020, 01:35 AM | #75 |
Rep 194
02-02-2021, 02:30 PM | #76 |
Rep 1,372
Little late to the party here but are those Millway control arm bushings for the front straight control arms or for the 'wavy' thrust arms? You might think "If it's called a control arm bushing it's for the control arm, not thrust arm." But look around and you will find someone claiming they inserted these bushings into the thrust arm. Look around even more and find people calling the thrust arm the upper control arm or upper wishbone (which is odd since wishbones are for a different type of suspension, not MacPherson Strut type suspensions, the type used in the F30).
Even better, the bushing size is different for the thrust and control arm. Imagine pulling off the wrong arm to discover the size difference. Sure would be nice to get confirmation the control arm bushings are for the straight shaped lower front control arm. Thanks in advance. |
02-02-2021, 05:37 PM | #77 |
Rep 8,511
The Millway sealed monoball bushes are currently only for the tension struts - see item 6 in the attached diagram. Millway does not yet have a bush for the wishbones.
pkiledj46.00 casualDIYer447.50 |
02-03-2021, 02:11 AM | #78 | |
Rep 1,372
Good old BMW. Wants to sell me a USD$1500 'performance' steering wheel for my xDrive, but won't sell me two monoballs bushings from their M car line plus a couple of spacers to make them fit. Lovely. I didn't see too many reviews on the Millway bushings. Are you using them? If yes, how do you find them? I am considering the street bushing as I prefer not to chatter my teeth to dust. Then I'll need dentures or implants and have to put back the OE parts. |
02-03-2021, 03:37 AM | #79 | |
Rep 8,511
I'm going to do a more in-depth review of SuperPro components on my car, as I've not been impressed. That said, the poly bushes in the radius arms have lasted a few years and have not worn. I've had quite a bit of contact with Samuel at Millway over the past couple of years regarding its camber plates (a long, but positive, story) and he emailed me to let me know that he'd see my reply back to you clarifying where the current Millway sealed bushes are used. Millway is now developing a sealed bush for use in the lower control arms, which I will get fitted when they are released for sale. The sloppy OEM hydro bushes (required due to the need for significant isolation of the NVH generated by the runflat tyres) rob the chassis and steering of precision and feel. The benefits of re-bushing the front suspension far outweighs the increased firmness of the suspension on these cars. I far prefer the feeling of tautness - with a good suspension setup (i.e. including decent coilovers) it's not jarring. Just my opinion, of course.
